Chaparral LW SE
Chaparral LW SE
I’m really hoping this model has the wavy serrations like the Caribbean. It will be a must buy if so. As much as I like the Caribbean, it is too large and bulky to be an around the house/athletic short IWB EDC for me. Are there any other Taichung knives with serrations? Just trying to gauge the likelihood of it being similar to the Caribbean. With the lightweight, thin blade, I would expect the design to favor a more slicy serration pattern as opposed to a “ripper”.
Also, I’ve learned never to base spyderco serrations off of the catalog picture - the serrations are often photoshopped and not indicative of the real product.
Re: Chaparral LW SE
What are the wavy serrations?
Re: Chaparral LW SE
TimButterfield wrote: ↑Fri Oct 20, 2023 10:46 amHere is one guess. See this comparison between Caribbean, Endura 4, and Pac Salt 2.
Compared with the Endura and Pac Salt, the peaks/valleys are much shallower on the Caribbean. So, the Caribbean SE is more wavy, less steep.
Nice picture. I feel like Taichung, Golden & Seki's serrations are all distinctive, with Seki being the most aggressive, followed by Golden, and Taichung being the most subtle. Moki gets the award for most snaggled, LOL!
Just a feeling though...
Subtle serrations on the Chappy LW would be pretty great! Time will tell.
So it goes.
Re: Chaparral LW SE
Thanks, had a feeling that might be it. It’s an interesting difference.
Doesn’t seem intentional to me. Kind of seems like a happy accident as a result from different manufacturers.
Re: Chaparral LW SE
I'm a little surprised this is not yet on the Spyderco site (either in New Product Reveal or searching for 'chaparral'; only PE FRN is there), while it is available for pre-order elsewhere.
Looking at the BladeHQ photo, the SE does look similar to the Caribbean.
Re: Chaparral LW SE
If you ignore the snaggletooth portion of the Masa Ayoob blade, the Moki serrations are even more subtle than the Taichung ones. I'm not near either knife right now, but if I get a chance later, I will post a comparison picture.
Re: Chaparral LW SE
I think I figured out why it's like this on the site. The drop-down item is simply excluded entirely if not available. For example, right now, for the Caribbean, only PE is in the drop-down and SE is not in the drop-down, though that is the image shown.TimButterfield wrote: ↑Fri Oct 20, 2023 11:52 amI'm a little surprised this is not yet on the Spyderco site (either in New Product Reveal or searching for 'chaparral'; only PE FRN is there), while it is available for pre-order elsewhere.
Site suggestion:
It would be nice if the unavailable variations could still be displayed in the drop-down, but with the additional text of 'coming soon', 'out of stock', etc. And, the possible Edge Types could be shown in the technical specs tab.
Re: Chaparral LW SE
Funny we should continue this serrations exchange here...
Unlike you I am convinced this IS intentional (but have no prove of course)
Look at ffg Pac Salt 2 SE, Endela SE, thin line Endura SE: All Seki FRN folders, Same blade height, same blade stock, but different serrations for all three (Endela always having the "shallowest").
Re: Chaparral LW SE
I just did a comparison and noticed a difference even though both are Seki. The valleys on the Lil' Temp are wider than those on the Endura 4. It would seem that if a wheel is used for the edge, the wheel profile would not be affected by blade height, stock, etc. And, as the peak center to peak center widths are different across valleys, I'm not sure that could be attributed to wheel wear.
Edit: Perhaps it could be due to the radius of the blade curve, though I'm doubtful of that also.
Re: Chaparral LW SE
Keep in mind that each model needs it’s own respective serration grinding wheel. That Lil Temp 3 was ground on an entirely different wheel than that Endura 4.TimButterfield wrote: ↑Fri Oct 20, 2023 4:17 pmI just did a comparison and noticed a difference even though both are Seki. The valleys on the Lil' Temp are wider than those on the Endura 4. It would seem that if a wheel is used for the edge, the wheel profile would not be affected by blade height, stock, etc. And, as the peak center to peak center widths are different across valleys, I'm not sure that could be attributed to wheel wear.
https://live.staticflickr.com/65535/532 ... 8f63_c.jpg
Re: Chaparral LW SE
True. I was just verifying/confirming the different serration profiles even when coming from the same location.
Re: Chaparral LW SE
Yes, the “wavy” serrations are exactly what TimButterfield referenced and are very distinctive on the Caribbean.
Re: Chaparral LW SE
Re: Chaparral LW SE
dsvirsky wrote: ↑Fri Oct 20, 2023 6:18 pm
Very subtle
So it goes.
Re: Chaparral LW SE
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
Re: Chaparral LW SE
I want to know how thin behind the edge this is.
Debating this vs the Native Chief LW in SE or CE.
Re: Chaparral LW SE
I would like to know if I could do a blade swap with a non-FRN model (the Raffir Noble to be specific). I can only guess the blades are compatible?
Re: Chaparral LW SE
I am absolutely getting the SE Chaparral. One mean little Jack the ripper. With custom carbon fiber scales I have coming in eventually, this is going to be a little pocket rocket.
... I like weird
Re: Chaparral LW SE
Keep in mind: In the context of this forum I am not an edge / sharpening... pro by any means.
That said: As much as I love Imy PE Chap, I felt it could have been thinner behind the edge from the factory (still a great slicer, don't get me wrong).
Don't know of course if this will be true for the SE too.
Anyway, there is nothing that could keep me from getting this SE variant
Have been hoping for one for quite a long time.
