Caribbean problem
aupiter
Caribbean problem
Post by aupiter »
I received my Caribbean (with black hardware) about a week ago and have since just played with it indoors. Today the opening/closing action suddenly became stiffer with a slightly "grindy" sound to it. I think the extra friction and sound goes away when pushing the lock bar all the way open and that it's coming from the blade tang riding on the detent ball. I can't see any debris in it (and it hasn't been anywhere dirty).
Since this is my first compression lock knife, I thought I'd ask if this is a known issue or if there is a known/easy fix, before I return it to Heinnie (I'm in the UK). I'm a bit concerned about reliability now (compared to lock-backs/Triad), though to be fair the lock still works and the knife is still usable.
Any advice welcome!
Michael Janich
Re: Caribbean problem
Post by Michael Janich »
Dear aupiter:
It probably is the detent ball. A drop of oil or dab of grease on the top of the ball should help.
Stay safe,
Mike
Giygas
Post by Giygas »
If that's the only issue you've experienced and otherwise like the knife, I wouldn't return/exchange it since it's something any knife with a detent ball can develop.
It's not specific to your example, or the compression lock.
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
17 Spydies, 14 steels
13 Maxace, 9 steels
JoviAl
Post by JoviAl »
Mine did that until I lubed it. It took a while to warm to but now I consider it one of the best knives I own.
- Al
Work: Jumpmaster 2
Home: DF2 K390 Wharncliffe/DF2 Salt H1 SE and K390 Police 4 LW SE/15V Shaman
Dream knives -
Chinook in Magnacut (any era)
Manix 2 XL Salt in Magnacut
A larger Rockjumper in Magnacut SE
aupiter
Post by aupiter »
Thanks all. Between posting the topic and having it approved I noticed that the problem seemed intermittent/variable.
I've now applied some Tuf-Glide to it and that seems to have made it much smoother, though I'm not sure if the ball is actually rotating or if the lube is just helping the tang move over a stuck ball. Will see how it goes!
BornIn1500
Post by BornIn1500 »
aupiter wrote:
Mon Sep 25, 2023 12:06 pm
I don't think a detent ball ever rotates. It's supposed to be "stuck".
soulspy
Post by soulspy »
Wash in hot soapy water if strange grinding occurs in the future.
Fireman
Post by Fireman »
The real Caribbean problem is if you don’t have one
:winking-tongue Mule Team Army 001
MNOSD 008 :usflag
Image Stable Mules; Z-Max, Z-Wear, Magna Cut, SRS13, Rex 76, Rex T15.
JoviAl
Post by JoviAl »
Fireman wrote:
Wed Sep 27, 2023 2:06 am
Truth ☝🏻
- Al
Work: Jumpmaster 2
Dream knives -
aupiter
Post by aupiter »
BornIn1500 wrote:
Mon Sep 25, 2023 2:49 pm
Thanks, that seems to be the case here. From Googling it seems some detents do rotate and I think I have a liner lock somewhere where the detent does, but that most don't.
aupiter
Post by aupiter »
I think my current problem is deciding whether it's worth the risk of disassembly to dye the scales.
Also I ended up getting it in SE but I feel I should pick up something in LC200N in PE to get the combination of decent plain-edge edge-holding with salt water resistance.
Coastal
Post by Coastal »
No need to disassemble a Salt knife to dye it.
aupiter
Post by aupiter »
Coastal wrote:
Thu Sep 28, 2023 9:14 am
Even with G10 scales? I think the only examples of dying while assembled I've seen are with FRN, and examples with G10 seem to involve disassembly and applying heat. But would be interested to know the process people have used with G10 while assembled!
FRN seems to take dye at lower temperatures. I have used a hot water tap (for coffee) in my kitchen to dye FRN. G10 I have to boil to get good results.
Coastal
Post by Coastal »
aupiter wrote:
Thu Sep 28, 2023 11:00 am
Well, good question. I'm not sure why it would matter, but it might. The only G-10 scales I've dyed have been "disassembled" because I dyed them before swapping, so I can't say I've dyed an assembled knife with G-10 scales. BTW, I always boil my dye, and then reduce the heat to simmer, so it maintains temp but doesn't bubble.
Coincidentally, I plan to dye a couple of Caribbeans soon, and I do plan to disassemble them. Bit of a pain, but Spydies are pretty easy.
No, it is that it does not have a liner-, but a comp.lock... :winking-tongue ;)
soulspy wrote:
Tue Sep 26, 2023 11:52 am
This, and you could also try washing it under the water tap (while moving the blade around the pivot) and giving the water jet more pressure by partly covering the opening of the tap - or perhaps compressed air could remove potential "gritty stuff" in there (IF this is causing the issue, don´t know).
JoviAl
Post by JoviAl »
Thu Sep 28, 2023 11:43 pm
Heathen! 😂
- Al
Work: Jumpmaster 2
Dream knives -
