Adjusting Boltaron
Ngati Pom
Adjusting Boltaron
Post by Ngati Pom »
I just received a Boltaron Mule sheath and I’m not able to get my Mule to ‘stable’ in there.
Image[/img]
The problem seems to to be where the lower part of the scales butts up against the sheath.
Would applying heat carefully to the area be the solution or do those with more experience have a better idea?
'The future is already here;it's just not evenly distributed'
William Gibson
Ngati Pom
Re: Adjusting Boltaron
Post by Ngati Pom »
Another image.
William Gibson
standy99
Post by standy99 »
Push hard…it’s pretty tight, and it is how you want a Boltron sheath.
It will wear after a few weeks.
Love the click of a lock in on a Boltron sheath…..
RustyIron
Post by RustyIron »
Ngati Pom wrote:
Wed Aug 16, 2023 10:08 pm
Yes. A heat gun will work. I can't remember if I've used a hair dryer. Just be watchful so that you don't get it so hot that the plastic bubbles on the surface.
Heat it up, stick the knife in, pull it out. After the sheath cools off a bit, try it out. If it's still unreasonably tight, do it again. If you goofed up and it's too loose, heat it up again and then poke the material with the blunt end of a chopstick. The material is very forgiving, and you don't need to be a rocket scientist to work with it.
Ngati Pom
Post by Ngati Pom »
RustyIron wrote:
Thu Aug 17, 2023 12:04 am
Thanks for the help.
Very much appreciated.
William Gibson
Ngati Pom
Post by Ngati Pom »
standy99 wrote:
Wed Aug 16, 2023 10:45 pm
The pictures show the result after I tried pushing in the blade with the sheath against a table and
vice versa with the handle resting on the table. I was worried about splitting it to be honest.
I’ll keep trying, maybe a couple of Weetbix will help. ;)
William Gibson
Michael Janich
Post by Michael Janich »
The best solution is to remove the scales and sand a bevel or chamfer on the leading edge of the scales to break the 90-degree angle. This creates a ramped surface that all knives made to fit in Boltaron/Kydex should have. Heating the sheath can work, but if you're not used to working Kydex, it can cause more harm than good. Fixing the scales is a far better solution.
Stay safe,
Mike
Ngati Pom
Post by Ngati Pom »
Michael Janich wrote:
Thu Aug 17, 2023 7:29 am
Stay safe,
Mike
Thanks for the tip, I’ll try it.
Appreciate the help, thank you.
William Gibson
