What Angle to profile my:
gull wing
Post by gull wing »
Sage 5 Lightweight:
Love this knife, but would like a little thinner edge for better slicing. I don't use it for heavy work (pruning garden, cutting sisal twine, whittle soft pine etc. )
What edge angle do you suggest? (20 deg. 15deg)
Thanks!
SCARAMOUCHE! :bug-red-white
Re: What Angle to profile my:
I'd shoot for 12-14dps if you can. Completely reset the bevel, deburr, then do a few strokes per side at 15dps on the sharpmaker.
That's a little thicker than I run my larger folders, so unless you're using the k ife pretty hard I think you'll be ok.
:unicorn
Traditional.Sharpening
Post by Traditional.Sharpening »
10 DPS is more than enough if you're not chopping, I'd start there. You may need a microbevel at 15-30 DPS depending on what the steel is if you're going to run a high polished apex. What steel is the knife?
Skidoosh
Post by Skidoosh »
I go 15 DPS
gull wing
Post by gull wing »
Steel is S30V.
Thanks again.
gull wing wrote:
Thu Aug 10, 2023 8:23 pm
Steel is S30V.
Thanks again.
I gave an S30V Manix XL a 10dps bevel with 15dps microbevel and it did fine doing light chopping and batoning. Cut through a soda can too. Still sliced paper without a hitch.
:unicorn
Deadboxhero
Post by Deadboxhero »
gull wing wrote:
Thu Aug 10, 2023 4:28 pm
Sage 5 Lightweight:
Thanks!
Well, it's going to depend on what you're using to sharpen. If you are using a fixed angle system, you should probably start with 20° dps
If your freehanding you should aim for around 15° dps
When you freehand there will be some hidden convexity near the apex so you're 15 dps will actually be closer to 17-20dps at the apex.
If you want to know what your angle actually is you need a laser goinometer If you want to quantify the reality of the actual angle you have.
Big Brown Bear
Triple B Handmade Knives
Manifestgtr
Post by Manifestgtr »
I keep my sage 5 lw’s around 15 dps or a tad lower. They seem to do pretty well there. I would take em closer to 10-12 but I feel like the bevels would get a bit wide on me.
Crucarta: Shaman (x2), Manix 2, Lil Native, Delica, GB2 & PM2
Favorites: Shaman, Sage 5 lightweight, Sheeps Caribbean, Manix, Endela and all things Stretch
Steel is S30V.
Thanks again.
10 DPS would be fine, you could also go lower than 10 DPS in the range of maybe 6-7 DPS if you really want the highest cutting ability. In this case I would recommend adding a micro bevel to set the apex finish. If you're going to use a high polish on the apex, you'll want to use somewhere between 20-30 DPS micro-bevel in order to stabilize the apex enough to hold that polish.
If you also want to have the highest performance, adding a relief bevel would be ideal as well to reduce the behind the edge thicknes. Once you reprofile to low angles you'll end up with a very wide edge bevel and it will be quite thick where that bevel meets the primary grind. Adding a bevel at an angle between that 6-10 DPS and the 2-3 DPS primary reduces edge thickness.
