Boltaron sheaths and Paracord
Tvrdy91
Post by Tvrdy91 »
Hi everybody! Newbie here, caught the bug for the spy 27 off of YouTube. I’d really like to practice different para cord wrap techniques on a blank, and I’m very partial to Boltaron or Kydex. Has anyone else had experience with the factory Boltaron sheath and a para cord wrap? Will a knife that doesn’t have the G-10 scales attached fit the sheath snugly?
Stok drop point, dragonfly 2 Wharncliffe.
Suburban dad, lbk enjoyer, wire clip enthusiast
No pasaran!
Erion929
Re: Boltaron sheaths and Paracord
Post by Erion929 »
Tagged….had same questions, also from a financial standpoint, from a newbie mule buyer 🤔
cholla_remover
Post by cholla_remover »
Just tried a paracord wrapped mule in the factory Boltaron sheath and it retains fine. *Possibly not quite as well as with the scales, but if I shake it upside down the knife doesn't fall out. The molding of the sheath indexes on the quillion/ricasso/guard just behind the sharpened portion of the blade, whatever it's called. The Paracord wrap doesn't affect that.
If you wrap your mule thicker than the factory Halpern scales then you might run into some fit issues, but you'd have to do double or triple wraps.
JestersHK
Post by JestersHK »
These both retain just fine. The straight spine sheath was actually really tight and had to break in a bit.
cholla_remover wrote:
Wed Jul 19, 2023 3:07 pm
...The molding of the sheath indexes on the quillion/ricasso/guard just behind the sharpened portion of the blade, whatever it's called. ...
I think, technically, it's called the 'uvula.'
cholla_remover
Hi Tvrdy,
Welcome to our forum.
Tvrdy91
Post by Tvrdy91 »
JestersHK wrote:
Thu Jul 20, 2023 7:21 am
Thanks! Beautiful wrap job. Something to aspire to.
No pasaran!
JestersHK
Post by JestersHK »
Thanks, look up Yablanowitz's guide here in the mule section and it's pretty straight forward to do.
He def put together a great tutorial for all of us.
Tvrdy91
Post by Tvrdy91 »
sal wrote:
Thu Jul 20, 2023 3:19 pm
Hi Tvrdy,
Thanks Sal!
No pasaran!
