Any idea when next PM2 Tanto will be out?
- Manixguy@1994
Re: Any idea when next PM2 Tanto will be out?
I believe the blade is a Blade HQ exclusive , totally a big guess . MG2
- kennethsime
If they do an M4/Micarta version, I’ll probably break down and buy one.
Best PM2 version by far.
Ask BHQ, they might be the only source, to answer this question.
Theoretically Spyderco could also provide this information, but they don't announce exclusives of other shops.
Eric said in his interview with Tom and Jason from MilliePM2P3 Club that they're working on a batch right now.
Edit:
Tanto pm2 talk starts at 1:03:45:
Edit:
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
17 Spydies, 14 steels
13 Maxace, 9 steels
13 Maxace, 9 steels
I really appreciate you sharing the interview!
So it goes.
I still haven't used my tanto M4 but I really like the idea. I am really interested in a tanto Military 2, assuming they can work the same magic and keep the blade tip in the same place in the open position as the regular blade shape. My biggest gripe with tantos is the tip is usually very high up relative to the handle, but the Para tanto managed to put the tip in the same place so un use it doesn't require you to crank your wrist to make cuts with the tip. If they do a Military 1 or 2 like this it might be my first EDC tanto.
I'd buy another. Maybe some day I'll get the courage to actually use mine. I just play with it.
- curlyhairedboy
I need to nab one in M4 some time. S30v sees some use.
A military 2 tanto is my dream grail knife man - it would be so good! I use my PM2 S30V tanto all the time and it is a wicked knife, just a bit short. A 4” plus version would make my year.Evil D wrote: ↑Mon Apr 17, 2023 10:17 amI still haven't used my tanto M4 but I really like the idea. I am really interested in a tanto Military 2, assuming they can work the same magic and keep the blade tip in the same place in the open position as the regular blade shape. My biggest gripe with tantos is the tip is usually very high up relative to the handle, but the Para tanto managed to put the tip in the same place so un use it doesn't require you to crank your wrist to make cuts with the tip. If they do a Military 1 or 2 like this it might be my first EDC tanto.
- Al
Work: Jumpmaster 2
Home: DF2 K390 Wharncliffe/DF2 Salt H1 SE and K390 Police 4 LW SE/15V Shaman
Dream knives -
Chinook in Magnacut (any era)
Manix 2 XL Salt in Magnacut
A larger Rockjumper in Magnacut SE
Work: Jumpmaster 2
Dream knives -
Good to know at some point, there will be more. A PM2 Tanto is on my must have list.
