Yojimbo 2 blade pivot area grind marks
AH80s
Post by AH80s »
Hi, I was wondering if anyone had seen this sort of thing before, or had any ideas as to why this area has the coarser finish. It’s not like it on the other side Just curious as it looks intentional, and I’ve never come across it before.
Thanks.
Andrew
Giygas
Re: Yojimbo 2 blade pivot area grind marks
Post by Giygas »
I've never seen coarser, but I've seen a finer finish there on quite a few compression lock models.
I assume the finer finish is to make it smoother for the detent ball to glide over. No idea why it would be coarser.
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
AH80s
Post by AH80s »
Ok thanks. I said coarser because of the more visible grind lines, though in reality I couldn't really distinguish much of a difference in feel. I've put it back together now so can't recheck. Maybe you are right and it's finer and just looks coarser.
Andrew
Giygas
Post by Giygas »
Here's my Yojumbo, for comparison:
It's definitely normal to have a different finish there, in my experience.
13 Maxace, 9 steels
AH80s
Post by AH80s »
Awesome, Thank you.
Andrew
Probably some post finishing done to clean up an edge or something. You can always polish this area yourself and make the pivot smoother, just don't get too aggressive with sanding or you'll create blade play. I've polished a bunch of tangs and detent paths.
AH80s
Post by AH80s »
Cheers, Thank you. Action is pretty smooth so will leave it as it is.
Andrew
