Swick 2 and 4
Polecat
Swick 2 and 4
Post by Polecat »
Gang, I have older leaf blade Swick, not sure if its 2 or 4? Need to measure. My question is how are the current swick 5 and 6 scales attached? Do all Swicks share a common handle dimension? Lastly, who makes custome swick scales? Or can I purchase new ones from factoey like those on the 5 and 6.
Thanks,
Dave
JRinFL
Re: Swick 2 and 4
Post by JRinFL »
I don’t have my older models handy at the moment, but I can tell you that the handle dimensions have changed between models. I bought aftermarket scales that do not fit the two models I have. I’d have to check, but I think I have a Swick 1 and two Swick 2.
The Swick scales that are/were available at Halpern only fit the exact model specified.
Re: Swick 2 and 4
The Swick model concept has changed with each variation over a 22 year period. It was mostly in the Ergos that the refinements developed. The 5 & 6 were the models that I felt were where I wanted them to be. The sheaths are challenging as a neck knife must be secure.
I did speak with Eric on future production and they will probably not made again until after the construction is complete. We have a lot of models on which to catch up.
