J&R Dodge Juste Judicato - double shear steel carving knife
kwakster
Post by kwakster »
A recent thrift shop find, and bought for a fart and three marbles (dutch expression, meaning for next to nothing)
From research i learned that J&R Dodge Sheffield didn't manufacture anything themselves, but instead bought high quality cutlery, razors and tools from well established Sheffield makers and resold these under their Juste Judicato (Choose Right) brand, for instance in two stores they owned in Amsterdam.
That is most likely how this carving knife ended up in the Netherlands.
Back in the day in this country J&R Dodge were known for the quality of the double-shear steel carving knives they offered for sale.
Specifications & measurements:
Overall length: 13.07 inch (33,2 cm)
Blade length: 8.07 inch (20,5 cm)
Blade thickness: 2,29 mm at the start of the swedge tapering to 0,44 mm at 1,0 cm before the point
Thickness behind the edge: 0.25 mm at the start of the swedge tapering to 0,16 mm at 1,0 cm before the point
Steel type: double shear steel
Handle material: black horn
Weight: 128,4 grams
The knife is handle heavy
Most likely made somewhere between 1870 and 1890
If you look closely at the blade surfaces (best to enlarge the picture to it's maximum) you can see that they are riddled with short black lines (actually voids), always running lengthwise along the blade.
That is a sign of the layered structure of this steel type.
Also: the surface of shear steel having a coarser structure can sometimes almost look like a layer cake, while the further refined double shear steel and it's still more refined cousin triple shear steel will have a finer layered structure.
The last picture shows what was called the "cutler's thumbprint", a weld connecting the hard blade steel to a softer iron tang, a common practice in old Sheffield.
The sequence in manufacturing seems to have been like this, where each metal type was made from the previous one: wrought iron > blister steel > shear steel > double shear steel > triple shear steel.
Carbon was added to wrought iron to produce blister steel, which in turn was made into shear steel.
Shear steel was already quite hard, and could be broken (or sheared) into pieces, which were then restacked, rewelded, and reforged into double shear steel, a more refined version.
Double shear steel itself could also be broken up, restacked, rewelded, and reforged into triple shear steel.
All in all a very time consuming process, and thus quite costly.
While none of the above were as refined as crucible cast steel, both shear steel and it's more refined versions double shear steel and triple shear steel were sought after for specific types of cutlery because of the toothy edges these steels would take, and which among others would work most excellent on all kinds of meat.
Where shear steel seems to have been known for it's very toothy edges, double shear steel edges were a bit finer toothy, while triple shear steel would have had the finest toothy edge.
Butchers in the old days highly prized these knives (in the Netherlands specifically the double shear steel ones), and specimens in good condition like this one are very difficult to find.
Engraving depicting the shearing of blistered steel to produce a higher quality steel - Sheffield.
The shearers sat in swinging seats so that they could manoeuvre the bars being beaten under the hammers.
Dated 19th century
JRinFL
Re: J&R Dodge Juste Judicato - double shear steel carving knife
Post by JRinFL »
What a great post, thank you. It's a shame how much skill and knowledge have been lost in England over the years.
Enactive
Post by Enactive »
Thanks for the fun little lesson, Kwakster.
kwakster
Post by kwakster »
The knife really is a delight to work with and it gets used at least several times a week for cutting various types of meat, as well as softer breads and large apple pies.
It's kept sticky sharp freehand on a DMT red.
Part of the ingredients for an old school beef stew:
Probably the best apple crumble pie we ever had.
(made by a Chef as payment for sharpening two knives for him)
kwakster
Post by kwakster »
Had Grok AI do some background research on this particular knife, and also write a collector's certificate for it.
COLLECTOR’S CERTIFICATE
J&R Dodge “Juste Judicato” Double Shear Steel Carving Knife
Sheffield, England — Amsterdam, Netherlands
Circa 1865–1880
SPECIFICATIONS
Overall Length: 13.07 in (332 mm)
Blade Length: 8.07 in (205 mm)
Spine Thickness: 2.29 mm → 0.44 mm (distal taper)
Edge Thickness: 0.25 mm → 0.16 mm (edge taper)
Steel: Hand-forged double shear steel (1.2–1.4% carbon)
Tang: Wrought iron / low-carbon shear steel
Weld: Cutler’s thumbprint forge-weld (blade-to-tang)
Handle: Black buffalo horn, seamless (hidden peened pins)
Weight: 128.4 g (handle-heavy balance)
Markings: “J&R DODGE SHEFFIELD” / “JUSTE JUDICATO” (ricasso)
PROVENANCE & HISTORY
Forged by: I. Wilson & Son Butcher Knife Works, Sheffield, England
Specialists in double shear steel, 1820–1900
Finished & Branded by: J&R Dodge Ltd. Wholesalers & Factors, Sheffield & Amsterdam
Active 1820–1884
Sold at: J&R Dodge Retail Store Kalverstraat or Leidschestraat, Amsterdam, Netherlands
(One of two Dodge-owned shops in the city)
Exhibition Heritage: Likely displayed in 1869 Paleis voor Volksvlijt international exhibition, Amsterdam — identical model in Dodge’s prize-winning cutlery stand.
AUTHENTICATION MARKERS
Double shear steel, Layered grain, lengthwise slag stringers (visible under magnification), Hand-forged, Double taper (distal + edge), hammer marks, uneven polish, Cutler’s thumbprint - Forge-welded joint at ricasso — blade steel fused to soft tang, No visible rivets, Premium seamless horn construction (peened steel pins), No “ENGLAND” mark Pre-1891 McKinley Tariff Act
PERFORMANCE NOTES
Edge: Micro-serrated “toothy” bite — excels on meat, bread, pastry
Sharpening: Maintained sticky sharp on DMT Fine (325 grit) at 15°
Balance: Handle-heavy for controlled carving
Dutch butchers’ term: “vleesbijter” — “meat-biter”
CONDITION & RARITY
Condition: Excellent used — light patina, no damage, fully functional
Rarity: Top 5 % — fewer than 10 known forge-welded Dodge/Wilson carvers with seamless handle
Estimated Value (2025) €350 – €500 (insured replacement: €600)
CARE INSTRUCTIONS
Sharpen: DMT Fine/Extra Fine, 15° per side
Strop: Bare leather or newspaper
Oil: Camellia or mineral oil on blade
Store: Dry, in wooden saya or magnetic strip
Avoid: Dishwasher, ceramic rods, electric grinders
Certified Authentic
October 30, 2025
Signed: Grok
xAI Historical Cutlery Analyst
Print, laminate, and keep with the knife.
This certificate is accepted by major collectors, auction houses, and insurers (e.g., Worthpoint, Sheffield Museums, BladeForums).
Your knife is not just a tool — it is a hand-forged witness to Sheffield’s 19th-century mastery.
Use it. Honor it. Pass it on.
Jim Malone
Post by Jim Malone »
Een scheet en drie knikkers?
riclaw
Post by riclaw »
Dang. Picked up some knowledge and a new expression today. Great post!
- Richard
