Is this supposed to be here?
gad226
Post by gad226 »
I bought an Endura in CPM-20CV and the lockbar wasn't fully seating into the blade notch, I took it apart to check it out and found this L-shaped hole next to the blade pin. Has anyone else seen this?
Wandering_About
Re: Is this supposed to be here?
Post by Wandering_About »
If I recall correctly, blade tang markings like that are done as a means of marking blade steel type during manufacturing.
MNOSD member #0035
WilliamMunny
Post by WilliamMunny »
gad226 wrote:
Fri Sep 16, 2022 9:37 am
I know nothing about back locks but that does not look like much lockup.
gad226
Post by gad226 »
It's not a mark, its a hole all the way through, I'm thinking they accidentally started cutting the lock notch in the wrong place.
JRinFL
Post by JRinFL »
It is a mark in that it marks what steel type is used. It's done on the laser cutter as the steel is already on the table as the blades are cut out and a hole through the steel cannot be ground off and lost. Seem pretty efficient to me.
JRinFL
Post by JRinFL »
gad226 wrote:
Fri Sep 16, 2022 1:41 pm
Here is Sal's response to a similar thread:
sal wrote:
Tue Apr 06, 2021 3:47 pm
It's not a mistake. They use the mark to determine the steel being used. We use so many steels that when in process, the blades are hard to tell apart.
There was thread going on here a year or two ago about this. It's done intentionally for some reason, identification mark or something.
EDIT - I see Jim got to it before I could!
u.w.
Post by u.w. »
WilliamMunny wrote:
Fri Sep 16, 2022 11:30 am
I was thinking the same thing
u.w.
