Page 1 of 1
Aftermarket DLC Questions
Posted: Sun Jul 03, 2022 10:24 pm
by Theldraskien
Hi everyone, I have an interest getting DLC put on a K390 SE blade.
I’m wondering if anyone has tried this or if anyone has experiences to share with aftermarket DLC options for their Spydies.
I see the the temp for the process is 500 degrees F, so I’m wondering if that would affect the heat treatment as well.
Re: Aftermarket DLC Questions
Posted: Mon Jul 04, 2022 7:06 am
by yablanowitz
I don't know the heat treatment protocols for K390, but I personally would be very leary about exposing any knife blade to temperature that high. I'm sure Sal could tell you, but I'm a lot less sure he would. Sharing propriatary processes is doing R & D for the competition.
Posted: Mon Jul 04, 2022 8:38 am
by phaust
FWIW, threads on the topic seem to come up with decent frequency (here, bladeforums, elsewhere), and the answer I've always seen is it doesn't matter.
Posted: Mon Jul 04, 2022 1:08 pm
by Theldraskien
Thanks phaust, I’ll do a bit more digging to locate those threads. Appreciate the response.
Posted: Mon Jul 04, 2022 2:07 pm
by Bemo
just a WAG but that 500 degree range is reminiscent of tempering protocols. So it may cost you a point or 2 on hardness but you'll get added toughness. But again it's a WAG and really we need some of our knife makers to weight in here.
Posted: Tue Jul 05, 2022 6:58 am
by Michael Janich
From Alpha Knife Supply's heat treating protocols for K390:
K390 Heat Treat Information:
Preheat: 1,500° - 1,550°, equalize.
Austenitize: Heat rapidly from preheat. For optimum wear resistance, soak for 5 to 15 minutes 2,150°. For balance of wear resistance and toughness, soak for 15 to 30 minute 2,050°. For maximum toughness and minimum distortion in cooling, soak for 30 to 60 minutes 1,975°. Quench in pressurized gas, or warm oil then cool in still air to 150-125°.
Temper: Temper immediately after quenching. Typical temperature range is 1,000-1100°. Do not temper below 1,000°. Hold at temperature for two hours then air cool to ambient temperature. Double tempering is required. Triple tempering is required when austenitized at 2,100°F or higher. Use the chart below to select the tempering temperature.
Stay safe,
Mike
Posted: Tue Jul 05, 2022 4:11 pm
by Theldraskien
Thanks Michael, appreciate the response.
