Scales with lanyard hole?
sethwm
Post by sethwm »
Anyone know of mule scales that support a lanyard? Having trouble finding one.
Josh Crutchley
Re: Scales with lanyard hole?
Post by Josh Crutchley »
You could always add a hidden lanyard like the 3d printed scales.
Fireman
Post by Fireman »
hidden lanyard hole is best imho
:winking-tongue Mule Team Army 001
MNOSD 008 :usflag
Image Stable Mules; Z-Max, Z-Wear, Magna Cut, SRS13, Rex 76, Rex T15.
sethwm
Post by sethwm »
Any pointers to what you all mean by that?
standy99
Post by standy99 »
sethwm wrote:
Tue Jun 21, 2022 2:43 pm
There are some printed scales with a hidden lanyard hole…
If you want a lanyard hole it would not be hard to drill one in any scales you buy. Just drill from one side with One scale removed and then put the scale back on and do the other side through the hole of the one side already drilled.
Be sure to clamp the scales on to the blade tight for the first drill hole with one scale missing.
PM me if you need a hand or better instructions….
cholla_remover
Post by cholla_remover »
In addition to the 3d print models created by forum members (and to drilling your own scales), Hazy Design Studios does mule scales with lanyard holes.
viewtopic.php?f=15&t=92180&p=1615169
sethwm
Post by sethwm »
Hazy Design Studios was the winner here. Real high quality. Doesn't quite fit the same in the boltaron sheath (it's smaller), but I like it a lot.
Couldn't you just drill holes into whatever scales you have to match up with whichever hole you want to use for a lanyard? Even the hidden style could be done by modifying the factory/Halpern scales.
sethwm
Post by sethwm »
Evil D wrote:
Fri Jul 22, 2022 6:02 pm
I didn’t want to risk cracking the g-10
sethwm wrote:
Fri Jul 22, 2022 6:28 pm
Hm. I'm guessing a G-10 crack, which would be rare, could result from a dull bit, an overly aggressive downfeed, or possibly a bit with a smaller than usual web. However, I'd have zero fear of cracking G-10 with a center cutting end mill bit run at a high speed. Especially a 4-flute. They're not expensive. Would give you an exceptionally clean hole. Be certain to give the G-10 a backing of some sort while drilling: plywood or what have you.
sethwm
Post by sethwm »
Bolster wrote:
Tue Jul 26, 2022 10:06 pm
Funny this exact phrase came up earlier today, but in a different sorta conversation...
sethwm wrote:
Tue Jul 26, 2022 11:16 pm
Where? Missed it...
