serration aggression
Is the variability in serration aggression luck of the draw? Or are certain models less aggressive? I just got a hawkbill ladybug SE which probably has the best serrations I've seen. It's amazing, and I think I might be converted to a serrated lover.
Then I looked at my endela SE which has been sitting in a bag I take into the woods, and it's also nice serrations.
Then I look at my dragonfly SE and those serrations are very very aggressive, and snaggy. If I were to get another serrated knife, what would I expect?
Dragonfly (top), Endela (bottom)
Dragonfly (top), Ladybug (bottom)
Re: serration aggression
Am I the only one confused by the question? You seem to indicate that all the SE are great and ask what you should expect. If you had a “bad” one I’d get the question, but even then I don’t know what would be bad, or good for that matter.
I should have been clearer. The dragonfly is snaggy and awful. Gets caught every time I make a cut and I hate it. It’s because the serrations are so aggressive.applejuice54 wrote: ↑Fri Jun 10, 2022 10:43 pmAm I the only one confused by the question? You seem to indicate that all the SE are great and ask what you should expect. If you had a “bad” one I’d get the question, but even then I don’t know what would be bad, or good for that matter.
There’s variability in the aggressiveness across my 3 examples and I’m wondering how one would predict how aggressive (and therefore bad … for me) a purchase will be.
There certainly are differences between SE models right from the factory as far as I can tell:
- I am obvuously not the only one feeling that the Endela SE has perfectly non-aggressive serrations - the kind that for me are the "better PE" in almost any folder task
- While my H1 Pac Salt is great for "ripping" things apart, but too aggressive to be absolutely perfect for "general EDC" (gets better and better with each sharpening though)
- Same is true for my Salt 2 ffg SE
- And each "old" SE model I had/have (like my Delica, Endura (both sabre grind) and Stretch CE, or Endura sabre grind SE) are way to "snaggy" from the factory for my liking.
- cabfrank
I posted a pic in the SE Performance is More Than Just Teeth sticky. There definitely differences. I find them all to cut extremely well.
I would say it's somewhat luck of the draw in a way because the shape can change as the wheel that grinds them wears out, so for example if the number of knives that it takes to wear out the wheel is 10,000 then the first knives off that wheel are probably going to be more pointy and prone to snagging while the ones towards the middle or end of the life of the wheel will be more mellow in shape.
Then there's also just the difference in the knives you're comparing, the Ladybug is ground on a different wheel than larger knives because it's so small, and then the hawkbill version may even have its own wheel too.
This could be a topic for another thread, but do you guys think they use a different grinding wheel for each model? I ask because David’s theory makes sense, however my se k390 Police has less aggressive serrations and I know it’s from the first run of that model, with that steel in serrated form.
OP, I don’t think there is a way to know what you’re going to get. You may need to take some time to sharpen down the aggressiveness on the df. It may also have to do with what you’re cutting too.
blueblur wrote: ↑Sat Jun 11, 2022 4:33 amThis could be a topic for another thread, but do you guys think they use a different grinding wheel for each model? I ask because David’s theory makes sense, however my se k390 Police has less aggressive serrations and I know it’s from the first run of that model, with that steel in serrated form.
I think the K390 knives are different either because of a challenge with grinding K390, or from user feedback regarding aggressive serrations. Or both.
A friend of mine had an SE H1 dragonfly and it didn't cut as well as other SE knives. Even when it was sharp it would still snag. I guess the serrations were too pointy. I think the thin stock on the ladybug really helps with the performance. My H1 ladybug hawkbill cuts very well.
I've found that it can be model-dependant. IMO, the best serrations that cut easily and don't seem to snag much, or at all, are my saber-ground SE Delica 4, SE SS Harpy, SE Endela, SE Ladybug hawkbill Salt, and SE SS Police. Those are the best ones I have, anyway. My SE Tasman Salts aren't bad either, but aren't as smooth as the ones listed above.
My SE Dragonfly Salt is probably the worst SE cutter I have. I may have to sharpen the serrations down a bit, even though it doesn't need sharpening.
Too-pointy serrations can be fixed on the Sharpmaker, using the diamond or CBN rods. It takes time. You want to both push and pull so the pattern remains symmetrical.
K390 delica you think is less aggressive too?Evil D wrote: ↑Sat Jun 11, 2022 6:14 amblueblur wrote: ↑Sat Jun 11, 2022 4:33 amThis could be a topic for another thread, but do you guys think they use a different grinding wheel for each model? I ask because David’s theory makes sense, however my se k390 Police has less aggressive serrations and I know it’s from the first run of that model, with that steel in serrated form.
I am curious from sal and folks if they intentionally vary the aggressiveness by model or if it’s just how worn down the wheel is at the time or related to the steel or what.
sethwm wrote: ↑Sat Jun 11, 2022 11:10 amK390 delica you think is less aggressive too?Evil D wrote: ↑Sat Jun 11, 2022 6:14 amblueblur wrote: ↑Sat Jun 11, 2022 4:33 amThis could be a topic for another thread, but do you guys think they use a different grinding wheel for each model? I ask because David’s theory makes sense, however my se k390 Police has less aggressive serrations and I know it’s from the first run of that model, with that steel in serrated form.
I'm guessing it will be, I don't see why the Police would be any different.
- cabfrank
I think it has to be both. I know Sal has definitely mentioned wheel wear as a factor.
I'm pretty pleased with the Byrd serration patterns. The Low hollow serrated Hawkbill is not snaggy. The new serrated FFG Wharnies are equally impressive. The teeth look a little pointier than the Hawkbill, but they don't seem predisposed to snagging. I like the way the serrated FFG Byrd Wharnies cut. (Harrier & Cara Cara) Even more so than my serrated FFG LC200N Pac Salt 2. Go figure.
The Dragonfly teeth are the most aggressive of any of my serrated knives.
And that's not necessarily a bad thing.
It depends on what you're cutting. A lot of us like to make serrations much closer to a wavy Plain Edge. Because you can make clean cuts with it while still having some of the aggression you get from a serrated edge.
Others like coarse plain edges for the same reason.
Some like polished plain edges for the ultra clean smooth cuts and push cuts.
And aggressive toothy serrations are good for sawing through tough or fibrous materials.
If I had a combo edge, I'd want toothy serrations so I could have the best of both worlds. Might even be fun to take a full serrated knife with toothy serrations and smooth and round off the front half and leave the back half toothy. Make a full serrated combo edge.
