Metal recommendations
What do think is best
CPM S45VN
2
8%
CPM 3V
16
64%
CPM 9V
1
4%
M390
6
24%
Total votes: 25
StillSteelNoob
Post by StillSteelNoob »
I'm about to start a new project creating a collection of edged tools. 1 hunting spear, 1 knife, and atleast 1 long bladed tool.
Primary consideration will be toughness, then wear as tools will be impacting items from wood to stone or even other metals.
So far i'm considering CPM S45VN, CPM 3V, CPM 9V, M390. Any others that will fit the bill I'm missing?
Opinions welcome, thanks for responses.
Re: Metal recommendations
Hi StillSteelNoob,
Welcome to our forum.
JRinFL
Post by JRinFL »
Welcome aboard.
From the ones you listed I would choose 3V as it has good toughness and still holds an edge. 9v is new to me and I have no knowledge of it being used in knives.
Ric
Post by Ric »
I would say cruwear.
LC200N might also fit.
spydergoat
Post by spydergoat »
If toughness is your most important need by far, either 3v or another steel you haven't listed in the poll could be best for you. I suggest for you the article linked below from Larrin Thomas' Knife Steel Nerds Website. He has lots of helpful info including charts showing the toughness of all of these and many other steels. Some of the steels that got a very high rating are 3V, 52100, AEB-L, and LC200N.
https://knifesteelnerds.com/2021/10/19/ ... esistance/
metaphoricalsimile
Post by metaphoricalsimile »
S45vn and M390 are both just about as tough as most other common powder metallurgy stainless steels, maybe even on the relatively low end as they both prioritize edge retention and stain-resistance over toughness. LC200N or Magnacut will both have better toughness than your listed options, as well as having *very* high degrees of corrosion resistance (LC200N can't really be hardened over 60 so its edge stability is only adequate though). Cruwear or 4v are both more commonly available than your listed options if toughness is more important than corrosion resistance. May I ask how you generated this particular list?
Airlsee
Post by Airlsee »
Of your listed options, CPM-3V seems like the only legitimate choice.
It's also the most available in the tools you're looking for, assuming we're considering all makers.
Welcome to the forum!
4V, Cruwear, AEB-L, A2, and presumably MagnaCut are also worth looking into... I suggest diving deep into the rabbit hole! 🐰
I wouldn't rule out M4 or Rex45 blades and would not be at all concerned about all 3 tools sharing the same steel...1095 would serve well in a spear or chopper.
So it goes.
RevMike
Post by RevMike »
From your list I'd stick with the 3V and the S45VN.
How and why is 9V an option on your list?
Spyderco has never made a production knife with 9V. They may have played with it but I somewhat doubt that. I don't think anyone is using it for knives. On paper it's doesn't look to me like good choice for a knive blade at all. It would be quite difficult to harden, very prone to corrosion, and a nightmare to sharpen.
404 :bug-red-white s in 81 steel flavors.
thewoodpecker
Post by thewoodpecker »
OP - How are you planning to shape and heat treat the tools you are making? This may play a big factor in your choice.
Spyderco Caly 3.5 Super Blue user, Astute enthusiast, and geometry advocate.
Wandering_About
Post by Wandering_About »
3V, from that list. Although if you're going to be in contact with bone, rocks, and steel a lot via impacts, I'd probably suggest something tough and easier to sharpen, as you'll be doing that a lot.
MNOSD member #0035
Airlsee
Post by Airlsee »
Oh wow! From the nature of the question and options given, I assumed OP meant accumulating/curating a collection.
If they are truly looking to "create" this collection then I recommend a life-raft, and a deeper dive into blades, steels, & methods.
So it goes.
Deadboxhero
Post by Deadboxhero »
StillSteelNoob wrote:
Thu May 19, 2022 1:35 pm
Just use a 40dps and you'll be good to go.
Big Brown Bear
Triple B Handmade Knives
Wandering_About
I was thinking 8670 with a thick edge!
MNOSD member #0035
Woodpuppy
Post by Woodpuppy »
Last time I made a tool (pocket hatchet), I used a worn out mower blade. Had to torch anneal the area I wanted to drill holes in, and sharpened the edge on a bench top belt sander.
https://bushcraftusa.com/forum/threads/ ... st-4647952
https://bushcraftusa.com/forum/threads/ ... st-4745617
bdblue
Post by bdblue »
80CRV seems to be popular for swords. Among the ones listed I would choose S3V if toughness is the primary goal.
zhyla
Post by zhyla »
Remarkably few steels deal well with stone contact.
Post by JD Spydo »
I put a bold X on the M390 selection. Mainly because my M390 Military model has been such a great EDC folder for 5 years plus. I also voted for "3V" because for quite some time now I've wanted a fixed blade with 3V.
I believe both blade steels are an excellent selection for hard EDC uses. For me M390 should be viewed as the new VG-10. And 3V is just made for abuse IMO.
You could do this with far less expensive steels, how are you making them? Some people use old truck leaf springs.
