Page 1 of 2
Profile mod scales
Posted: Tue May 10, 2022 11:45 am
by Josh Crutchley
I've been tinkering with the idea to make profile mod scales for the Mule Team. No tang modifications needed. This is just a rough alpha to get some input on the design.
Re: Profile mod scales
Posted: Tue May 10, 2022 12:03 pm
by ykspydiefan
That awesome. I sure like the skeletonized look.
Posted: Tue May 10, 2022 12:09 pm
by Josh Crutchley
ykspydiefan wrote: ↑Tue May 10, 2022 12:03 pm
Thanks, it's far from a finished scale. I plan to contour it in some way.
Posted: Wed May 11, 2022 7:36 pm
by Bemo
Love that look! Skeletonized G10 would make this a great lightweight fixed blade.
Posted: Thu May 12, 2022 12:39 pm
by cholla_remover
Yep, I like this idea. I often wish that my Spyderco's had a less-pronounced relief area where the index finger rests behind the blade. More meat there would be great.
Posted: Thu May 12, 2022 4:39 pm
by RustyIron
Josh Crutchley wrote: ↑Tue May 10, 2022 11:45 am
It looks cool, for sure. Many of the "bolt on" scales that I've seen pictures of, all seem to be undersize. It would be great if you could make them to fit the blade properly. Although it wouldn't be as obvious, the holes should all match up perfectly, as well. That's just my take on it.
Posted: Fri May 13, 2022 8:38 am
by Josh Crutchley
RustyIron wrote: ↑Thu May 12, 2022 4:39 pm
Not sure what you mean? Are you talking about my scales? The holes are lined up perfect in the render.
Posted: Sat May 21, 2022 11:26 am
by Bolster
I like the Manix-like shape of your model, and I think it would go a good way toward dealing with the large-radius issue around the index finger area. The way the mule handle is designed pushes my index finger back (more pronounced on thin scales), which is why I sometimes re-radius the area behind the guard so it's a smaller, more comfortable radius. I think your Manixification will solve the same issue: it'll make a happier home for the index finger.
Did you exaggerate the pinky hook?
Wow, Josh, tip of my hat, "you're always thinking." (Famous quote by Marvin Dorfler in Midnight Run)
Posted: Sat May 21, 2022 11:27 am
by Bolster
Josh Crutchley wrote: ↑Fri May 13, 2022 8:38 am
He must be viewing the 3D image as if it were a 2D image?
Posted: Sat May 21, 2022 5:20 pm
by Josh Crutchley
Posted: Mon May 23, 2022 2:55 pm
by Josh Crutchley
Here it is if anyone wants to try it out. No mounting hardware needed but it probably wont stay together without glue. I'm working on a ball and socket type retention method for the final version.
https://www.thingiverse.com/thing:5393227
Posted: Wed May 25, 2022 12:45 pm
by JRinFL
Very nice work. Is still have not setup my printer, too many house projects in the queue before I get to do fun stuff.
Posted: Fri May 27, 2022 8:27 pm
by legOFwhat?
Fantastic work! If I can catch one of our printers free, I may try that out!
Posted: Sun May 29, 2022 6:35 pm
by Josh Crutchley
legOFwhat? wrote: ↑Fri May 27, 2022 8:27 pm
Let me know how it goes. I can't test most of the stuff I model but this is based on the same drawing/.dxf I used for my other Mule scales. The other scales fit pretty good so I just went with that.
Posted: Sat Jul 16, 2022 2:24 pm
by Araignee
I really dig the skeleton scales
Perhaps you could create two sockets for the purpose of inserting screws, one in the front and one in the back.
Sure, it'd remove some of the design's attractivity, but it'd make switching scales much more convenient.
Posted: Sat Jul 16, 2022 5:07 pm
by Josh Crutchley
Araignee wrote: ↑Sat Jul 16, 2022 2:24 pm
Thanks, if I find the time I'll make a version for you.
Posted: Sat Jul 16, 2022 7:48 pm
by Bolster
I'm not one who wants to see the handle "embiggened" (to borrow a phrase from the Simpsons) so if I got my hands on a pair of these "XL Manix" scales I'd be sanding off the tail end. I much prefer the first pattern you listed at the beginning of the thread.
This will be the cue for someone to brag about how big they are, and how they need XL handles and XL condoms, etc, but I wear L to XL gloves and I find there to be a lot of Mule handle already. Y'all have seen me shorten the handles and I like 'em better that way.
Posted: Sat Jul 16, 2022 8:42 pm
by Josh Crutchley
Bolster wrote: ↑Sat Jul 16, 2022 7:48 pm
I might have saved the original but it's simple enough I can make them available on Thingiverse. I'll just size it for the Spyderco/Halpern hardware.
Posted: Sun Jul 17, 2022 12:16 pm
by Bolster
Thanks Josh, but don't do it for me. I don't have a printer. I'm old-school!
Posted: Tue Jul 19, 2022 5:33 am
by Araignee
Josh Crutchley wrote: ↑Sat Jul 16, 2022 5:07 pm
That'd be very nice, cheers !
Nothing pressing of course, myself I don't devote too much time thinking about knives these days.
