Blade length is not everything
Agree or disagree? I don't think blade length is nearly has important as cutting performance. Even in situations where a longer blade is called for, cutting performance is still the most important. One can even press a smaller knife with great cutting performance into service to do a bigger knife's job. But, no matter how long the blade, if it cuts poorly, it's not worth anything.
- Hopsbreath
Re: Blade length is not everything
I prefer the Caly 3 to the 3.5. It feels more nimble in hand and perfectly balanced at the smaller size. It doesn’t mean I don’t like larger knives but all designs don’t necessarily need a ‘lil or XL.
I agree that I would rather have a sharp Native 5 to a dull Endura. I typically prefer the longer blade just because if needed, it is there. I occasionally use my knife for food prep when away from my kitchen(At work or on a trail). So it is just nice to have the extra length. I prefer a shorter blade when working on projects just for the tip control. I have used a Chaparral to prep a beef brisket at a family member's house because it was what I had on me at the time, and it was much sharper than what they had in the Kitchen. So in that case, I specifically chose a smaller blade to a large blade because of cutting performance. That Chaparral was also the best box cutting knife I owned due to the thinness of the blade. In that case, the thinness played a large role in its cutting performance. If I was looking at a bunch of cardboard to cut up and it just so happened I had a Chaparral and a PM2 on me, I would probably choose the Chap for the cutting performance.
- VooDooChild
For a lot of quick cuts that I encounter duting edc I would agree.
But I also believe in the right tool for the right job.
I love the manbug but I dont want to fillet a fish with it or cut up a pineapple with it. That wasnt a challenge by the way, Im aware it can be done, but a larger knife makes it easier.
Not sure I fully agree. I get the point you're making but there are jobs that a scalpel just can't do regardless of how efficient it is at slicing. On the other end of the spectrum we have a butcher's clever that by comparison has horrible edge geometry vs the scalpel but it better suited for splitting ribs. There is a sweet spot somewhere in the middle for pocket knives where size and cutting performance are balanced and it probably has more to do with your needs than what is "right or wrong" in this debate.
I guess if I had to choose I'd rather have 3.75 inches of average slicing blade over 1.5 inches of excellent slicing blade, but that has everything to do with the situations I find myself needing a cutting tool.
Try slicing up an apple with a Manbug. Then try it with any Endura. There's no replacement for displacement.
Gotta agree. I'd rather have too much blade, than not enough. (As I carry a Military today )
15 's in 10 different steels
I agree, blade length is not everything.
A Manbug would have no problem slicing up an apple. Might actually slice better than some other models because it has a thinner blade stock. It’s when you decide to introduce the caveat of “cut the apple in half in one slice” it becomes more difficult, if it’s possible at all.
-Nick
- Naperville
I don't like trying to hold onto a knife with a handle that is small, and a blade that I have to arch my neck to see what the teeny tiny blade is doing. I have a few knives that are just too small to be useful. I'm comfortable with an EDC that has the right profile and a 4 to 5 inch blade, and due to martial arts training prefer 5 to 20 inches for combatives.
There are reasons for longer blades. Utility to a given task is #1, edge holding is #2, but they are both important.
The funny thing about this debate is there is absolutely no reason we can't have blade length and slicing performance. Most Spyderco's do a great job finding a sweet spot.
Outside of self defense uses, blade length is often determined by handle length and handle length is likely selected for hand comfort. In other words, people often select longer blades due to the larger handle being more comfortable, not because the blade is longer. This is not universal, so no need to follow on with the exceptions that we know are out there.
i use my teeth to slice my apples. they are very short blades and quite thick behind the edge.
to answer the question though, i guess i agree that it's not everything, but i do find it quite important for my tastes. the manix is about the shortest blade i want to carry anymore. i'll carry blades as long as 6" depending on what i'm going to be doing, but my preference for edc is 3.5-4.5".
It’s not everything, but it’s something
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
The apple cutting thing has always cracked me up. Unless you're feeding them to a child, or you have dentures...why are you cutting an apple??ladybug93 wrote: ↑Fri Mar 11, 2022 10:08 ami use my teeth to slice my apples. they are very short blades and quite thick behind the edge.
TkoK83Spy wrote: ↑Fri Mar 11, 2022 10:09 amThe apple cutting thing has always cracked me up. Unless you're feeding them to a child, or you have dentures...why are you cutting an apple??ladybug93 wrote: ↑Fri Mar 11, 2022 10:08 ami use my teeth to slice my apples. they are very short blades and quite thick behind the edge.
Is "because I feel like it" not a good enough reason?
I also cut up my pickles in slices. I just like it that way.
I always slice my apples. Why? Because of an incident back in grade school. At lunchtime one day, another kid had a big red apple, and was taking big bites out of it. As he bit down, I saw a slimy trail of spittle running down the apple. The sight grossed me out so much that, when given a choice (which is virtually all the time), I slice my apples into bite-sized chunks. Plus, I prefer it that wat, anyway.
I suppose that works. Just seems like a lot of extra work, and a sticky knife, when you can just mow through one by hand and teeth.
Hahahahha, that's something else! It's funny how certain things can traumatize us for life. Thankfully for you, it wasn't anything serious.James Y wrote: ↑Fri Mar 11, 2022 10:19 amI always slice my apples. Why? Because of an incident back in grade school. At lunchtime one day, another kid had a big red apple, and was taking big bites out of it. As he bit down, I saw a slimy trail of spittle running down the apple. The sight grossed me out so much that, when given a choice (which is virtually all the time), I slice my apples into bite-sized chunks.
You can mow through a box by hand and teeth too but a knife works better
Well played sir, well played
