What knife do you carry clipless?
I dislike pocket clips. I wasn’t always of that mindset, but things change. The clips mangle pockets, catch on things, scratch things, etc. I also found most clips create hot spots for me when gripping the knife. However, I have been known to clip my PM2 inside my left boot.
I’m curious what Spyderco knives you carry after removing the clip. I know many of you carry Dragonflys that way. I know there’s at least one Delica from searching the forum.
What do you carry clipless? How do you carry it? Back pocket? 5th pocket? Lanyard? Pocket slip?
Re: What knife do you carry clipless?
Hi, GTenn:
Welcome to our forum. We hope you enjoy your time with us!
Kristi
Kristi
Not sure if the bugs count as an answer but I carry my manbug wharncliffe everyday. It doesn’t have a clip option
I carry a dragonfly salt clip less to the beach. I usually use a lanyard and wear it like a bracelet. I do the same with the ladybug hawbill. If I pocket them I just leave the lanyard and bead hanging out so I can grab them.
i carry a ladybug hawkbill salt in my wallet and a squarehead in my pocket when i'm at work. neither of them have clips. i never remove my clips though.
Never actually clip-LESS.
When mountaineering. or skitouring pants feature pockets with zippers, I quite often carry my Salt 2 or Chap un-clipped inside the closed pocket (mainly to avoid the risk of loosing the knife while I am active) - but I never actually remove the clip itself, and when I´ḿ then in a camp or bivouac I might clip the knife to the now (unzipped) open pocket again, for then I´ll reach for the folder more frequently.
I have a lot of stuff in the bottoms of my front and back pockets and, because I don’t want to fight with it, my primary Spydie is stays clipped above it.
I had started that dragonfly thread about clipless carry, and I did experiment with for a couple days. What I realized pretty quickly, and one of the folks on the forum (James Y) helped me put words to, is that the clip, in addition to actually serving as a retention device, acts as a way to orient/grip the knife for quick one hand deployment. I added the clip back but still carry the fly bottom of pocket with it.
It should go without saying that if the knife I’m carrying doesn’t have a clip, I’ll be carrying it clipless. Unless it’s a small enough knife to fit into the 5th pocket of my jeans, any knife I carry without a clip, I just slip into the bottom of my front left pocket.
There are a few knives that I like to remove clips before carrying though. The Dragonfly is the first one that comes to mind, I much prefer to carry that one without a clip.
I’ve taken the clips off of Delica’s as well and I was shocked by how much more comfortable it became in hand. For the most part, I still carry my Delicas with a clip but they are very comfortable knives without the clip.
One more that I just could not keep the clip on is the Pattadese. The scales are crowned and feel really great in hand without the clip. I actually found the clip on that knife to be overly uncomfortable and can’t think of a reason why I would ever put it back on.
-Nick
My favorite Spyderco for EDC is my PM2. But, it has ruined many of my pants. After trying all my aftermarket clips and trying it clipless (too big) it continues to destroy. Everything I own with the wire clip seems golden. I'm thinking the aggressive surface of the g10 could also be a major factor.
I don't even carry my smallest knife, my Chap, clipless.
The clip provides a griping point when operating the locking mechanism, so even if I don't use the clip for it's intended purpose, I keep it on the knife.
I really have to try this!
Especially my Salt 2 (="linerless Delica") gets carried un-clipped in zippered pockets or even inside a pack anyway, so the clip is then not needed as such.
On the other hand: Those rather small knives, as great as they are, see less real us - or better: More occasional. short time use - than my larger Spydies, so ergos are less important to me on the former.
PineyBoy wrote: ↑Mon Feb 28, 2022 10:23 amMy favorite Spyderco for EDC is my PM2. But, it has ruined many of my pants. After trying all my aftermarket clips and trying it clipless (too big) it continues to destroy. Everything I own with the wire clip seems golden. I'm thinking the aggressive surface of the g10 could also be a major factor.
In my use G10 definitely is more of a pocket destroyer than Spydercos FRN, where the clip lands on that smooth logo spot
So: I hope for you that we´ll finally see that PM2 LW: Probably FRN AND a wire clip (if it´s done along the lines of the Para 3 LW)
Most 3" and under I just drop in my pocket with my keys. Removing the clip makes them smaller in pocket and can make for better ergos. However, on some models the presence of the clip really helps with opening and closing the knife one handed, even if I don't use it.
I carried an early Worker clipless for about half the years I carried it, in the mid-90s. Since then, however, if the knife has a clip, I almost always use it. The exceptions are when I'm doing something active enough that there's a genuine possibility of losing the knife, or when I'm using the knife repeatedly, say, in gardening. It's sometimes easier to just put the knife in a pocket between uses rather than reclipping to heavy material like jeans or cargos.
At some point I'll probably try an unclipped Dragonfly.
Oh, one that I never carry clipped is my Catcherman. It just goes in a pack with the rest of my fishing gear.
I have multiple Delicas. Two of them have their clips removed; these are my go-to’s when I want a light, thin, yet capable knife in my pocket.
Anything longer than a delica or native will sit diagonally in my pockets, so anything that size and smaller become my EDC. I left the clips on for a bit, but they bang into my phone screen and add thickness in the pocket (cell phone, wallet, urban in front right pocket, keys in the left) - not ideal but it works for now
A Squeak without the clip, small and super slim, perfect for the 5th pocket.
Many of my Spyderco knives are clipless.
A favorite method is in a Victorinox large nylon belt pouch for Endura sized knives. I also daily carry a Delica in the short Victorinox nylon belt pouch. The Military fits nicely in a Benchmade nylon pouch.
Have no need for "quick draw" and "power snap open" for knife deployment.
Regards,
FK
Regards,
FK
