H1 goodness
H1 goodness
I know it’s common knowledge around here, but just wanted to restate what a joy it is to sharpen H1! My PE salt DF2 had been overdue for a touch up. It still has the factory bevel with a number micro bevels on the SM 40 deg position. For the heck of it I marked the edge with my trusty sharpie and put the brown rods in the 30 deg slots. To my surprise there was a near perfect apex within a minute or so and then another 10 passes on the flats had the tip in great shape. Scary sharp.
I know it won’t last too long, but hey! Might H1 be the perfect steel to learn sharpening technique with? The slightest corrections in angle/technique gave near immediate response.
Re: H1 goodness
Hi Bjz,
I enjoy H1 both plain and serrated. Gets very sharp and like a small car with a small gas tank, I don't have a problem sharpening / filling the tank more often.
- Manixguy@1994
Re: H1 goodness
There is a thread called Pacific Salt Talk , it’s on page 2 . I will probably give it a bump this week . Thread deals a lot with H1 steel that you might like to read . Vivi started started it some time ago and is quite familiar with the steel . I agree it is a wonderful steel and also carry the DF2 Salt PE going on three years . MG2bjz wrote: ↑Sun Feb 13, 2022 10:56 pmI know it’s common knowledge around here, but just wanted to restate what a joy it is to sharpen H1! My PE salt DF2 had been overdue for a touch up. It still has the factory bevel with a number micro bevels on the SM 40 deg position. For the heck of it I marked the edge with my trusty sharpie and put the brown rods in the 30 deg slots. To my surprise there was a near perfect apex within a minute or so and then another 10 passes on the flats had the tip in great shape. Scary sharp.
Re: H1 goodness
This steel is overlooked for its well rounded properties.
Easy to sharpen and rust proof make it pretty amazing.
Was never a space cadet, but with LC200N I might be more in space than a cadet.
MNOSD 0009
MNOSD 0009
Re: H1 goodness
Some steels seem to want to get sharp when I sharpen them....others not so much. H1 is definitely in the first category. It's such a pleasure to work with.
Re: H1 goodness
Somehow there is a motorcycle analogy in here as well! If it weren’t such a long day, I’d toss the df2 in my pocket and go burn some fuel on the honda
Re: H1 goodness
My problem with PE H1 (and this is certainly a personal first world problem), is that the dragonfly is the only handle I actually like that PE folders are offered in. I’ll likely end up with an SE saver at some point.
Now if they stuck and H1 PE sheepsfoot into a rockjumper handle, I’d probably be in heaven
Re: H1 goodness
Hi Bjz,
My last bike, (had to give up the canyon racing on my VTR-1000) was one of those that I had to burn some fuel to clear my head. I understand.
Re: H1 goodness
Hi Sal,
I know you said somewhere here recently that you are starting to like both big and smaller knives more nowadays...is there any chance we can get a Lil Native / Lil Native LW in H1?
Re: H1 goodness
I've got an LC200N Lil Native blade, but it's firmly stuck in a glass.
- cabfrank
Re: H1 goodness
Priorities.
Re: H1 goodness
Sal,
My cb500x is much less zippy but it sure does well on all the wildlife-covered mixed surface forest roads way up in the mtns around here.
Re: H1 goodness
Hey Sal,sal wrote: ↑Tue Feb 15, 2022 12:26 am
Hi Bjz,
The VTR is a fun bike and it is great to know you ride. I am about to go out and clear the head right now on a modded Triumph Tiger 955i. H1 Pac Salt SE in the jacket and S110V Native 5 LW in the pocket.
Dan
Re: H1 goodness
I love H1...it's close enough to perfect for me!!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
- cabfrank
Re: H1 goodness
Well put. If there was never anything else, I'd live happily ever after.
Re: H1 goodness
agreed! it's got everything I need in a blade steel. I still try out others, like Rex45 and K390 for fun, but H1 is sufficient to get me through the rest of my years.
Re: H1 goodness
H1 is the perfect steel to keep by the door to open packages. Why? Alcohol and water will not rust it. It takes an extremely sharp edge and gets there very easily. There are many steels that in PE will hold an edge longer, but plastic, tape, cardboard, zip ties, will all dull a knife faster than people realize and then it is a real chore to resharpen many steels. H1, on the other hand, is simply a few quick passes on the Sharpmaker and it is back to atom slicing.
Re: H1 goodness
I carried a serrated H1 salt 2 daily when I lived in southern Florida. However, it seemed the PE portion of that knife's tip was perpetually dull. If I cut anything more than tape, the razor sharpness (achieved with the sharpmaker brown medium stones) would disappear almost instantly along the PE portion. The serrated section always held up just fine. Having a perpetually dull PE tip forced me to switch to a para 3 lw s90v -- only carrying the salt when I'd be in and around saltwater.
I decided to take some advice given here and put a super coarse edge on the salt using CBN --> sharpmaker fine --> and then a .5 micron strop. The difference in edge holding is somewhat staggering. I'd estimate at least a factor of 3 or more improvement on the PE portion (which now slowly loses its razor edge bite) and the serrated section is still as sharp as ever. I wish I had done this sooner. I also applied the same edge to an s45vn mule in the kitchen and noticed superior edge holding with less rolling. I'm not entirely sure why that is though and would appreciate hearing everyone's thoughts. Is it only in my head? It could be that less force is used against a cutting board because the edge cuts more aggressively. My first guess was that the average thickness at the edge is actually thicker with a coarse edge than with a semi-polished edge making it more durable but with less edge retention. However, the coarse edge effectively adds serrations to add cutting aggression that would normally have been lost with the thicker edge. Yet, the edge angle between the semi-polished finish and coarse finish is the same so I'm not yet convinced.
Re: H1 goodness
It's pretty amazing, isn't it? Back when I ran a fine edge off the sharpmaker white stones I'd touch up my PE Pacific Salt 1 every few days when I carried it to work. Now I can go two months without touching up PE H1 folders by changing the way I sharpen them. So much saved time!dlum1 wrote: ↑Wed Feb 16, 2022 9:55 amI carried a serrated H1 salt 2 daily when I lived in southern Florida. However, it seemed the PE portion of that knife's tip was perpetually dull. If I cut anything more than tape, the razor sharpness (achieved with the sharpmaker brown medium stones) would disappear almost instantly along the PE portion. The serrated section always held up just fine. Having a perpetually dull PE tip forced me to switch to a para 3 lw s90v -- only carrying the salt when I'd be in and around saltwater.
Re: H1 goodness
Hi Vivi,vivi wrote: ↑Wed Feb 16, 2022 10:22 amIt's pretty amazing, isn't it? Back when I ran a fine edge off the sharpmaker white stones I'd touch up my PE Pacific Salt 1 every few days when I carried it to work. Now I can go two months without touching up PE H1 folders by changing the way I sharpen them. So much saved time!dlum1 wrote: ↑Wed Feb 16, 2022 9:55 amI carried a serrated H1 salt 2 daily when I lived in southern Florida. However, it seemed the PE portion of that knife's tip was perpetually dull. If I cut anything more than tape, the razor sharpness (achieved with the sharpmaker brown medium stones) would disappear almost instantly along the PE portion. The serrated section always held up just fine. Having a perpetually dull PE tip forced me to switch to a para 3 lw s90v -- only carrying the salt when I'd be in and around saltwater.
I believe it was your thread that got me to try it out. Have you noticed a difference in edge rolling / edge durability between the edge finishes? My H1 used to roll very easily but appears to roll less so with this edge. H1 is tough but not particularly hard -- I managed to roll (bend) an entire tooth of the serrated edge. I ask because the results are better than I anticipated, but I'm not entirely sure why. If the edge is actually more durable, then I think it would imply that an edge with significantly less toughness (such as maxamet or s110v) would likely benefit more from the same treatment. Alternatively, this edge finish may be equivalent to the forever-holding working edge of s110v and maxamet.
