Lightweight Yojimbo?
Is there a need or desire for a lightweight Yojimbo? Will a back lock work for this design?
I am fully on the S90V CF Yojumbo train but I can’t help but think a lightweight Yojimbo would be excellent. I carried a Civilian for back up for a long time strictly as a self defense knife with a primary knife and I can’t help but think a lightweight Yojimbo would be a good back up knife to an EDC. If the LW Yojimbo was light as a secondary carry, I think a lot of people would carry it. Yes, it would make a fine primary carry as well but I like my back up to be a knife that is always sharp in case the emergency needed it to be.
Mule Team Army 001
MNOSD 008
MNOSD 008
Re: Lightweight Yojimbo?
I'd be very interested. Hope it gets the wire clip and BD1N treatment. And rounded edges more like the Para3 LW rather than the Manix LW or Native. I hope knowledge gained from developing the Para3 LW in regards to centering and what not has made the next gen of linerless FRN compression locks a bit more refined. If priced around $100, it would be amazing.
I think that’s a sound argument from a self defense mindset, though not really for me and my opinions specifically.
Spyderco offers so much variety in service to our preferences, but a lightweight compression lock wharncliffe would be new!
However, if I was going to a buy a Yojimbo, they already sell the version that makes the most sense to me. (I personally feel that solid g10 and inset liners is the ideal for a self defense knife, or lined FRN at least).
To me, the lightweight idea has more merit in linerless construction and the role of a normal cutting, non-self defense, edc carry.
So I support the idea, but not for quite the same reason.
Not sure if the tall Yojimbo blade and a backlock would fit in the current handle..?
That said: Lightweight and backlock would both make the model a lot more intriguing for me.
The Yojimbo 2 has a blade with a lot of weight as part of its design, so I would question the effectiveness of a lightweight one. It would be lighter, but I think it would be less of a difference than in the normal and lightweight Para 3.
Not just a lightweight but also a full rust proof version makes the most sense to me. A knife that's carried close against your body can rust too, we've had this conversation many times. I'm not sure calling it a "Salt" even makes sense, because I think too many people associate that name literally with salt water activities, but I think there's a real value in a rust proof self defense knife. We have the ARK, but being a neck knife meant for the shower is a bit different I guess.
In terms of Spyderco SD products, I'd much rather see a Chief trainer.
I was skeptical if the Yojimbo would work in a backlock version because of the choil-less design, so I checked. It seems that it would work perfectly in a backlock design too.
Back lock - no
Lightweight - yes
Salt - yes
Specifically useful for when you have those missions when you have to immerse yourself in water and breathe through a bamboo straw. "Water"meaning whatever liquid, so yes, it must be a MagnaCut Salt.
Lightweight - yes
Salt - yes
MNOSD member 0011
So basically a whole new knife in the Yo family? Think about it, if you change the lock it becomes a whole new knife. New blade, new lock, new handle.
It’s Michael Janich’s design, if he wants to design one with a backlock or FRN scales so be it. Personally, I don’t think there will ever be a backlock version because there is nothing wrong with the compression lock version. I wouldn’t rule out an FRN version but where these are collaboration models, I wouldn’t necessarily expect it either.
Changing a lock type isn’t as simple as plug and play. It’s difficult to tell but I’m not sure if a backlock would even fit in the Yojimbo or Yojumbo handle with the blade closed. At least not without noticeable handle modification.
- Nick
Good point there, I only checked if it could fall shut safely on the index finger for one-handed backlock closing, I did not consider that handle and blade shape could also influence wether a knife could be made in a backlock version or not.
I really like the idea of a LW Yoji.
Count me on board.
Count me on board.
I was under the impression that the lock choice was a MBC rates strength ordeal, but then they also use Delicas which are back locks. Still, Michael chose the CL for a reason.
Nicks / Mushrooms point is actually exactly what I tried to express in my first post here, reason being that I remember Sal saying that the tall Shaman blade would not fit in the current Shaman handle together with a backlock.
The situation looks pretty similar in case of the Yojimbo.. ?
My bad, I didn’t read all of the replies before responding to the original post. We seem to have had the same thoughts about the idea though.Wartstein wrote: ↑Tue Jan 25, 2022 11:58 am
- Nick
Salt lightweight Yojimbo makes sense.
I happen to think the Emerson Wave feature would be great for deployment in a self defense situation. Will a lightweight FRN handle and compression lock work?
Mule Team Army 001
MNOSD 008
MNOSD 008
duplicate post
Mule Team Army 001
MNOSD 008
MNOSD 008
I have the plain Jane Black G-10, S30V version, honestly I wouldn't change one thing. My particular Yojimbo is THE example of a perfectly manufactured knife!
Incredible action, lockup, centered, just slick as greasy glass, Golden killed it with mine!
But hey, who am I to say no to a new knife model?
No worries, I did not mean to say that you repeated my post. But rather that you could phrase the point better than I did, so people could actually understand it...
/ Anyway, generally for me one of the advantages of comp. lock and liner lock is exactly that they allow designs with very tall blades compared to the height of the handle. If a designer makes full use of this, I think the exact same handle just could never house a blade as tall if the design switched to a backlock (on the other hand: If one made a super thin backlock knife, this design could probably not be changed to a comp. - or linerlock (or CBBL) without having to get a bit thicker too).
(Not a reply to you, but generally): Despite being a backlock - guy: I am not sure why a lightweight Yojimbo should not still have a comp.lock? Constructed just like in the Para 3 LW?
I think especially people who might not actually use - and OPEN (!) - their folder often, but rather carry it for sd, will certainly be quicker and more reliable when having to open a well tuned comp.lock knife than one with a backlock (especially when under stress) - true for thumb rolling, flicking and inertia opening imo.
