Mule Z-Wear PM initial impression and experience
AlexRus
Re: Mule Z-Wear PM initial impression and experience
Post by AlexRus »
defenestrate wrote:
Sat Oct 30, 2021 10:19 pm
Thanks, nice review! the Z-wear is a great overall option as a mix of edge retention and toughness. If more people were used to/comfortable with high carbon (non-stainless) steels I think it would be very popular, especially when they realized it's basically Cruwear.
Thank you, defenestrate!
Of course it's not stainless, but it's really a very good and balanced steel!
:respect
AlexRus
Post by AlexRus »
Coffee time! :cheap-sunglasses
DerRock
Post by DerRock »
Thank you, it was interesting to read and see. Congratulations on your flawless victory over the box and chicken :)
AlexRus
Post by AlexRus »
DerRock wrote:
Wed Nov 03, 2021 10:50 am
Thank you! :respect
AlexRus
Post by AlexRus »
Sharing with you my experience with the paracord Mule handle wrapping.
Removed the G10 scales and wrapped my Z-Wear Mule handle with Olive Drab paracord.
There are lots of paracord handle wrapping techniques on the forum and on the net in general. I chose this one I saw on YouTube. It creates texture, a bit of thickness and looks quite interesting.
I like the result so far.
And I also decided to finish the wrapping with a wrist lanyard-loop.
What do you guys think? :thinking
I can't view this thread, the pictures are galacially slow to load.
AlexRus
Post by AlexRus »
Bolster wrote:
Tue Nov 09, 2021 10:02 pm
Hi Bolster! It's faster to see them here I guess:
https://ibb.co/album/t8Zb64
https://ibb.co/album/5BtgRx
AlexRus
Post by AlexRus »
MagnaCut Mule made it all the way around the world to Russia to join his Z-WEAR brother
Manifestgtr
Post by Manifestgtr »
Looks like we have matching mules…this is my test maggie
Crucarta: Shaman (x2), Manix 2, Lil Native, Delica, GB2 & PM2
Favorites: Shaman, Sage 5 lightweight, Sheeps Caribbean, Manix, Endela and all things Stretch
AlexRus
Post by AlexRus »
Manifestgtr wrote:
Tue Jan 18, 2022 5:41 am
And the Green Paracord wrapping just like on my Z-Wear Mule )
Manifestgtr
AlexRus wrote:
Tue Jan 18, 2022 6:04 am
Paracord actually feels pretty nice on these. At some point, I’m sure I’ll end up getting some scales but in the meantime, you could definitely do a lot worse.
AlexRus
#32
Post by AlexRus »
Manifestgtr wrote:
Tue Jan 18, 2022 9:01 am
Agreed!
Crox
#33
Post by Crox »
AlexRus wrote:
Tue Jan 18, 2022 5:14 am
Have you had a chance to compare them much?
AlexRus
#34
Post by AlexRus »
Crox wrote:
Thu Jan 20, 2022 7:53 am
Not yet. I use Z-wear and MagnaCut wasn't used yet. But I noticed that factory sharpeness on the Magnacut Mule was much duller than on the Z-wear one. I guess it's just that factory edge thing, it's always random/different and doesn't say anything about the steel properties)
Worm
#35
Post by Worm »
Here is my first ever self-made Mule Team handle (purple stabilized poplar wood by raffir) and kydex:
everything done by hand (I skipped some grits so you can still see grind lines from initial filing)
I did an impact test on the factory edge
(almost factory; you can see I left a secondary bevel after first reprofiling/cleaning of the factory edge):
I tried to baton through a shimano shifting cable.
It did not separate the cable (maybe shimano uses some high quality hardened steel wires ...)
The edge took some damage but sharpened out nicely.
Z-Wear is very similar to Cruwear and Magnacut: gets scary sharp easily with an polished edge
Edge retention seems similar to my S45VN Mule in my EDC use.
I plan to thin out the handle as it is currently too thick for the Spyderco leather sheath.
after reprofiling and sharpening
edge damage on factory secondary bevel after batoning on steel wires
boltaron sheath
boltaron sheath
purple poplar wood handle with carbon pins
legOFwhat?
#36
Post by legOFwhat? »
She's a 'beaut, worm! I wrecked a df2 hb pull cutting some rubber gasket that had a stranded steel cable hidden in it. Looks like you turned it around nicely!
-Larry
MNOSD #0049
