In the name of mule science
- standy99
Re: In the name of mule science
Can do lemon juice and salt water.
Got the Z-wear and can do all the science in one hit which will be easier.
Battery acid is a good test for the future robot wars of 2050.
A sweaty gym shirt in a zip lock for 24 hours is a great test.
Mule Team Army 001
MNOSD 008
MNOSD 008
How about a drop of blood, if you're willing to go that far? I don't even know if it affects steel at all. I just know it's hard to get off of fabric.
Michael
- legOFwhat?
lol, Like curtains and carpet?
-Larry
MNOSD #0049
MNOSD #0049
Fabric like in what your clothes are made of. Apologies if I used a wrong word.
Michael
- legOFwhat?
Nothing wrong here
-Larry
MNOSD #0049
MNOSD #0049
Okay then.
But, to the subject: does blood leave (permanent?) stains on steel if not wiped off? What say you, CSI watchers?
Michael
- standy99
So you want me to cut myself……. Your a tough bunch.
Ok I will work on it.
Got to be worth a mule team patch
https://livebloodonline.com/ph-of-urine-and-blood/
Save your blood… unless you are a vampire
use your morning urine to get the same results because or similar PH levels.
This is getting into weird territory.
Mule Team Army 001
MNOSD 008
MNOSD 008
Don't do it if you feel it's not right. There's no problem!
Michael
If you're a knife guy, the question is not if you'll cut yourself, but when you will.
Wait for the next opportunity and capitalize on it.
- standy99
Butcher for 20 years, don’t cut myself often.
Not hard to stick a pin in my finger and squeeze. Will do lemon juice first when I get some time.
- standy99
Spat my coffee out reading this, this morning……
Sigh - SAME DAY I make this post, I cut myself on a Benchmade. Gave it a lil spin as I picked it up... blade broke the detent just long enough to come out a quarter of an inch, made a 2 millimeter cut on my palm. Should I ship you the blood?
- standy99
Might have to do my favourite Cranberry juice
As seen on my maxamet Native 5 (10 days hotel quarantine in Hawaii led to the below experiment)
I'm not a watch guy, but if I were... I've admired enough of them to know that I would buy THAT Omega and be done. Perfection!
@ckc_knifemaker on Instagram.
For my food prep blue#2s and super blues, I get the blades good and hot under tap water and use yellow mustard on the carbon edge. Continue running spine under hot water for 5 min or so, with mustard on edge facing up, then rinse off mustard and dry. Gives the edge a cobalt-bluish color, often with a little red in there. The color stays a long time as long as subsequent cleanings are with cold water.
Haven't tried with any spydies, your results may vary.
-burly
-burly
: H1, M4, 4v, 10v, Hap40, s90v, s110v, BD1n, Maxamet, Magnacut
MT; Z-max, Z-wear, Magnacut, SRS13, Rex76, M398, T15, K294, ZDP-189, HIC, AEB-L, SPY27, 15v
Other: D2, White#1, Blue#2, SuperBlue, VG-10, 204P, 20cv, s30v, s35vn, s45vn, s90v, HIC, TC71
