Page 1 of 3
More Edge Retention Testing - Rex 45, Maxamet, SPY27, XHP, CPM-T15, 420, Rex 76
Posted: Mon May 10, 2021 9:37 am
by Larrin
A new set of edge retention tests on a range of high speed and stainless steels including Rex 45, Rex 76, CPM-T15, SPY27, XHP, and 420. We also did toughness tests on several of those steels that we had not yet been tested. And we redid our Rex 121 knife with a new heat treatment that was much easier to sharpen so it got a significantly higher score.
https://knifesteelnerds.com/2021/05/10/ ... 15-rex-76/
Re: More Edge Retention Testing - Rex 45, Maxamet, SPY27, XHP, CPM-T15, 420, Rex 76
Posted: Mon May 10, 2021 9:43 am
by u.w.
Oh yeah :)
Thank you Larrin
u.w.
Posted: Mon May 10, 2021 9:52 am
by Nick258
A little disappointed in Rex45. I though it had more edge retention. The extra hardness + Cobalt really dropped the toughness.
Posted: Mon May 10, 2021 10:22 am
by Snacktime
Really though REX 45 was going to be higher edge retention, even feels like REX 45 has higher edge retention in use. **** 420C killed it in toughness!
FYI Some of the picture links are broken in the toughness section.
Posted: Mon May 10, 2021 10:24 am
by TkoK83Spy
Yea that shocked me too about Rex45. In my use it's been amazing for edge retention on all 3 knives I've used it. Still my favorite steel regardless what the science says! :)
Posted: Mon May 10, 2021 10:33 am
by RustyIron
Thank you, kind sir.
And the commentary to help us navigate the charts is appreciated.
Posted: Mon May 10, 2021 10:43 am
by Henry_P
“ I was probably most impressed with Z-Max and Maxamet in terms of their combination of toughness, hardness, and edge retention they have, though of course still at the lower end of the toughness spectrum.”
Good to see maxamet is getting some love. A couple of bad blades in the past seem to have given it a bad reputation.
“ XHP has a competitive toughness-edge retention balance with other stainless steels, though its corrosion resistance is worse.”
I have always been a fan of XHP and it has been stainless enough for me in my use.
Thank you for this informative article.
Posted: Mon May 10, 2021 10:45 am
by Dan In MI
Lots of that is over my head, but still a good read. There is much learnin' for me to do!
Posted: Mon May 10, 2021 11:08 am
by Larrin
Snacktime wrote: ↑Mon May 10, 2021 10:22 am
The images are working on all of my devices. Maybe it was a fluke of the server.
Posted: Mon May 10, 2021 11:27 am
by curlyhairedboy
Man, I knew there was a reason XHP is one of my fave steels....
Thanks for the effort, Larrin + team!
Posted: Mon May 10, 2021 11:28 am
by Wartstein
1.) I am also surprised concerning REX 45 - in my use it seems to retain a useful sharpness like forever...
2.) Said in some other post that for me XHP feels like having about the edge retention of S30V but is a bit easier to sharpen.
Correlates much with Larrins objective findings: Edge retention not too far of from S30V (and higher than on 35 and 45 VN), and (quoting Larrin) " having only chromium carbides (as opposed to vanadium) makes it relatively easy to grind and polish with standard abrasives" - this probably explains what I found in my use of XHP.
And since I don´t care for corrosion resistance, this is actually a great steel for me
Posted: Mon May 10, 2021 11:30 am
by Senfkarte
Thanks a lot. I always wondered how REX 45 would fit in. Although I have to admit, my guess would have placed it higher in the charts.
by Wartstein
curlyhairedboy wrote: ↑Mon May 10, 2021 11:27 am
You beat me for a few seconds in praising XHP
And: Yet another reason why people should get a Chaparral... :)
Posted: Mon May 10, 2021 11:45 am
by hookandlateral
Yeah put me in the group thinking Rex 45 would do better. Oh well, doesn't stop me from enjoying it.
Posted: Mon May 10, 2021 11:51 am
by z1r
Wartstein wrote: ↑Mon May 10, 2021 11:30 am
Yup. Need me another Chap!
Posted: Mon May 10, 2021 12:01 pm
by Matus
I think it should be fair to say that different type of testing is going to bring slightly different edge retention results. Larrin of course uses the golden standard - the Catra testing. We have seen somewhat different relative results (I mean comparing how two different knives in different steels perform) when looking at rope or cardboard cutting (though these are not anywhere close as scientific).
But yes - I did not expect to see quite as low toughness for the Rex45. I guess one should not confuse toughness for edge stability (and a reminder to myself to go and read up on these topics on Larrin's blog)
Posted: Mon May 10, 2021 12:06 pm
by Larrin
Matus wrote: ↑Mon May 10, 2021 12:01 pm
I'm sure rope or cardboard testing could be used to get consistent results. However, the majority of rope or cardboard cutting tests are done across a vast range or different knives which makes sorting through the results very difficult. It's just the nature of the beast when you have to rely on available knives rather than making them all the same. When you are testing different production knives you are testing knives, not steels.
Posted: Mon May 10, 2021 12:07 pm
by TkoK83Spy
Guess I better send my new Rex45 Native Chief back :p
Posted: Mon May 10, 2021 12:13 pm
by Wartstein
Larrin wrote: ↑Mon May 10, 2021 12:06 pm
This was especially noticeable with BD1N and LC200N (both great steels which I like a lot, don´t get me wrong!):
After the then available rope cutting results people (me included!
) thought BD1N would be between VG10 and S30V in edge retention, LC even just as good as S30V - when your controlled tests showed that both are even below VG10 as far as I recall. (EDIT: ... and LC200N actually below BD1N...)
Posted: Mon May 10, 2021 12:17 pm
by z1r
TkoK83Spy wrote: ↑Mon May 10, 2021 12:07 pm
To me? :D I've been looking for a low performing steel to practice my sharpening skills on! :p
