Misadventures with My Military
Postby kennethsime » Sun Apr 18, 2021 3:15 pm
Carried my Military for the first time in awhile today, and ran into a couple of hiccups.
The first came when I opened an Amazon package at work. Using what I swore was just the tip, I slit the sides of the packaging tape, then ran it right down the center. *boom* “Whoops,” I thought - wonder what that could be?
Turns out, I sliced right through a can of coffee. “Well, ****,” I thought, having never sliced threw a can before. “Is my edge ok?”
Yup, looks good. I proceeded to cut up 3-4 boxes of cardboard, Military sliced like a dream. After I emptied out the can, I noticed this little plastic insert in the can - any idea what it is?
Well, with work done, I cleaned of the blade and put out my trusty Millitary away. All is well, right? Almost, but not quite.
I noticed the scales of my Military (and maybe other knives, but I tend to carry my Military with these pants) has slowly been wearing a hole in my 5th pocket (or watch pocket), right where it bumps into my AirPods case.
Well, that’s a bummer. But I don’t think this happens with my jeans, so I guess I’ll blame it on my pants. Maybe I should carry the AirPods in the bottom of my pocket, and my Dragonfly in my watch pocket.
Lost to the Ages: C90GRE Stretch 1 ZDP-189 British Racing Green | C28GRE2 Dragonfly 2 ZDP-189 British Racing Green
C12BK2W Matriarch 2 VG-10 Emerson Open | C81G2 Para Military 2 S30V
Currently Rotating: C81GPRGR2 Para Military 2 K390 Ranger Green | C223GPRGR Para 3 K390 Ranger Green
C90FPIV2 Stretch 2 Straight Spine, VG-10 Rit Dye'd Dark Apple Green | C223GP Para 3 S30V Green Canvas Micarta
C41BORE5 Native 5 Lightweight REX 45 Burnt Orange | C223BORE Para 3 Lightweight REX 45 Burnt Orange
C101GY2 Manix 2 Lightweight Maxamet Gray | C28GFG Dragonfly K390 Swap Foliage Green
MT27 Mule Team 27 Micro-Melt PD#1 Ranger Green | C36GPGR Military 204p Dark Green
C229MZW Shaman Z-Wear Brown Canvas Micarta
ChrisinHove
Re: Misadventures with My Military
Postby ChrisinHove » Sun Apr 18, 2021 3:21 pm
I think at very least that should be a problem for the Apple warranty people....
ZrowsN1s
Postby ZrowsN1s » Sun Apr 18, 2021 3:22 pm
🤣Reminds me of the Z-Cut I gifted my friend. She proceeded to open a case of bottled water with it. Before I could get the word 'careful' out she cut through a few bottles.
If Im not mistaken that little insert in the can is where the Nitrogen is stored.
I ❤ The POLICE :spyder:
Postby PeaceInOurTime » Sun Apr 18, 2021 3:23 pm
Haha! You split that can right open :) Not sure what that plastic thing is. Is it pressurized?
RustyIron
Postby RustyIron » Sun Apr 18, 2021 5:07 pm
I might have to try that nitro-coffee. The little widget in the can is an aerator. You'll notice a couple tiny holes along the outside edge. Keep in mind that the coffee is just like Pepsi or beer in that it contains dissolved gas under pressure. In the case of your coffee, the dissolved gas is nitrogen. The widget also contains the coffee/nitrogen mix. When you pop the top, the gas comes out of suspension, and the mix gets squirted out those tiny holes. The widget starts spinning, just like Hero's aeolipile, agitating the rest of the coffee, and causing more nitrogen to come out of suspension. The result is a delicious foamy drink with tiny nitro bubbles.
Postby vivi » Sun Apr 18, 2021 6:19 pm
I like using this grip with larger folders for slicing tape on a box. Lets me control the tip really well and avoid over penetration ;)
Join us at the Spyderco Swap!
Current favorite: M4 Native Chief
Postby PeaceInOurTime » Sun Apr 18, 2021 7:29 pm
I didn't realize cans of coffee could be so complex. Thanks for the education RustyIron :)
standy99
Postby standy99 » Sun Apr 18, 2021 8:55 pm
Yep, that’s a Apple design fault.
A deep carry clip will sort that mark on your pants out. ;)
Postby Doc Dan » Sun Apr 18, 2021 11:01 pm
That is a good reminder to be careful with that long Military blade. I have mine sitting next to me waiting on a package to arrive so I can open it.
https://www.facebook.com/fallplanet Author page
Telegram Channel: https://t.me/dandocthomas
Postby Evil D » Mon Apr 19, 2021 2:33 am
This happens so much in retail you just wouldn't believe it. It's part of why most stores won't allow people to use pocket knives, because utility knives at least limit how deep the blade can go and even then it still happens.
Postby Doc Dan » Mon Apr 19, 2021 3:40 am
yes, and this is why I like the Roadie so much.
Jefke
Postby Jefke » Tue Apr 20, 2021 1:01 pm
When opening any kind of package I always flip the knife upside down, i.e. the spine touches the package and the edge faces away from the package. This way the risk of damaging whatever is inside the package is minimal, unless you use a knife with a straight spine like the the Military/PM2/Para3. With a curved spine you then have much better control of how deep the tip goes, and If you angle the blade right then the spine will hit the contents before the tip does. This post explains how this technique is used by hunters: viewtopic.php?f=2&t=89141#p1504357
That's why I think a blade shape like that of e.g. a mantra or a delica is better suited for general EDC. Frankly I don't get it why some people always want a straight spine. If the PM2 had a slight curve to the spine (it doesn't have to be much) then I would be using it a lot more, it might be my favorite knife then (maybe I should modify my PM2 :rolleyes: ).
James Y
Postby James Y » Tue Apr 20, 2021 2:55 pm
I do something similar when opening packages with the Military or PM2, but I like to pinch both sides of the blade near the tip, leaving the last .5” to 1” or so of the blade exposed. I keep my ring finger partially in the Spydiehole to push the handle side up and hold the knife in the proper position, so the tip points downwards.
Airlsee
Postby Airlsee » Tue Apr 20, 2021 3:38 pm
Yeah, I grab the whole blade and put my finger all the way out to the tip of the blade when opening most boxes, if possible of course.
So it goes.
Postby kennethsime » Tue Apr 20, 2021 8:40 pm
Funny enough Vivi, that's precisely what I was doing - only 1/4" or so of the tip was exposed. It just so happens that the can was directly underneath the tape.
chuck_roxas45
Postby chuck_roxas45 » Wed Apr 21, 2021 6:15 am
That's exactly what happens when it's "just the tip". FUBAR. :D
donutsrule
Postby donutsrule » Wed Apr 21, 2021 7:42 am
Cans of Guinness have similar nito capsules to give them the tiny bubbles.
Users browsing this forum: attila, barkbark, cali, Eratus, GiftedMisfit, Majestic-12 [Bot], ThomC and 51 guests
