Smaller P'kal
ZrowsN1s
Re: Smaller P'kal
Post by ZrowsN1s »
dd61999 wrote:
ZrowsN1s wrote:
Thu Apr 08, 2021 11:05 pm
Might work. You should sketch up what you have in mind.
I’m not known for drawing skills
But a scaled down baby p'kal is what I’m thinking
sal wrote:
Sat Apr 10, 2021 4:49 pm
I'll think about a smaller P'Kal, or maybe ask Roque, or proto guy to cut a P'Kal down for me to play with. I don't think that taking off a half or even 3/4 of an inch would make that much difference. I'll try to draw one up with a 2.0" blade.
I had a spare moment this evening so I drew something up just to see what it would look like.
Lil' P'kal. What do you think?
Reject
Re: Smaller P'kal
Post by Reject »
Could the same result be achieved by modifying the blades on a couple of existing models?
Adding a wave to the Wharncliffe blade of the Delica or the Dragonfly would get you fairly close to what you are after.
Plus, :o The Delica and Dragonfly a little more friendly looking than the P’kal.
Shouldn’t take too much to modify the cutting edge to match the P’kal.
Putting a tail on the Dragonfly would aid with grip. The stubby lanyard can be held in the hand or dropped between the fingers.
Now; :D if Spyderco is going to start downsizing knives. :) How about a down sized Ronin?
How much can a Koala bear?
Re: Smaller P'kal
This thread makes me wonder what a pikal swick would be like.
:unicorn
ZrowsN1s
Re: Smaller P'kal
Post by ZrowsN1s »
You may very well be able to mod a P'kal to a lil pkal. The issue with modding other knives is 1. The handle 2. The blade shape and orientation 3. Wave 4. Lock .
The P'kal can penetrate material better than just about any knife I've tried. This is from a combination of the handle, blade shape, and orientation.
Using a dragonfly or Delica handle for reverse edge in grip just doesn't work. And you could mod a wharncliffe blade but it wouldn't have a wave. And the waved knives are all saber grinds. The P'kal is the only full flat grind waved knife. There's also the issue of the lock. For a blade that is that rapid stab oriented, the CBBL lock is the ideal strong lock for the job.
Sumdumguy
Re: Smaller P'kal
Post by Sumdumguy »
Sat Apr 10, 2021 11:04 pm
The picture on page one is almost identical to what that would be. Just a slightly different handle shape.
-Thomas Jefferson
ZrowsN1s
Re: Smaller P'kal
Post by ZrowsN1s »
If I could reiterate my last post a little better, part of what makes the P'kal an effective stabbing tool in RGEI is the positive blade angle.
If you hold a wharn-delica in RGEI what you get is a very negative blade angle. This causes stabs to land mostly on the tip and spine of the blade. Resulting in very little penetration.
If you modded the blade to make the angle positive in this grip you would have to grind away half the blade. You'd also end up with the tip near the spine where the blade is thicker on the FFG.
Blue72
Re: Smaller P'kal
Post by Blue72 »
sal wrote:
Sat Apr 10, 2021 4:27 pm
You mentioned "grappling". Are you a LEO? Where do you carry your Clinch Pick and how do you deploy it?
The handle on our P'Kal is not quite 4.5", A 3" handle would be only for 3 fingers and might be hard to hold onto in a situation? The "Clinch Pick" shown has a Perrin Finger Ring which certainly helps with retention. Have you seen a "Swick"?
Our P'Kal has a large indent next to the spine of the blade to help with retention. Are you thinking to keep the indent, but just make the blade and handle shorter?
I can't find any information or reference to the "Clinch Pick" shown above. All I can find is Southnarc's original version. Can you point me to any?
Grappling as in Brazilian Jiu jitsu and wrestling.
The clinch pick is designed to be worn on the front of your belt, for easy access during tight clinch positions. Situations that drastically reduces your range of motion while deploying.sometimes you can’t even move your arms, you twist your hips to assist in deploying.
The smaller blade also helps in these extreme close quarter situations in not only deploying but also working within the tight spaces of the clinch.
The smaller handle is easier to pull out of your pocket or waistband then the larger p'kal in various grappling positions. Such as sitting in the car. Which Craig Douglas teaches in his shivworks classes.
I am not a LEO. I’m a business executive, so carrying a clinch pick would be exposed when wearing a tucked in dress shirt. In addition it’s not as comfortable as having a folder in your pocket or waist band.
A three inch handle is small. But the clinch pick handle is even smaller. However, the swollen scales allows a secure grip in the hand.
I think keeping the indent is important to use as a hand stop. However a hand stop could be incorporated into the blade like the clinch pick below.
Blue72
Re: Smaller P'kal
Post by Blue72 »
Here is a great video on Craig Douglas (south narc) explaining the design of the small clinch pick and demonstrates how it’s used in extreme close quarters situations
I think a smaller p'kal would work better in this situation rather then the standard size p'kal. Especially for those who rather have a folder instead of a fixed blade, for various reasons I mentioned earlier
https://youtu.be/AwNFvOaqh94
Blue72
Re: Smaller P'kal
Post by Blue72 »
ZrowsN1s wrote:
Sat Apr 10, 2021 9:37 pm
Love it, but maybe a narrower blade since you are “stabbing and ripping” in a defense scenario
Blue72
Re: Smaller P'kal
Post by Blue72 »
Reject wrote:
Sat Apr 10, 2021 10:52 pm
I love the dragonfly, but it doesn’t work because the finger choil gets caught in clothing when using it reverse grip edge in. But the size does make it easier to deploy
Re: Smaller P'kal
Thanx DD,
Craig knows his stuff. I worked with him quite a bit while working on the folding P'Kal. At least a year in the designing. I can see where the Perrin finger Ring would be an asset to a "Clinch Pick". In my opinion, the most important thing about a self defense knife is that you don't drop it. The downside of the finger ring is that you have to already have a finger in the ring before you have to deploy.
I agree that the indent would be a critical necessity in a smaller P'Kal.
Blue72
Re: Smaller P'kal
#32
Post by Blue72 »
sal wrote:
Sun Apr 11, 2021 4:45 pm
Thanx DD,
Optimally I prefer no Perrin finger ring because it will be much harder to deploy
Re: Smaller P'kal
#33
We'll make a proto and I'll test it. I've called for 2.0" blade. We can mod from there.
JRinFL
Re: Smaller P'kal
#34
Post by JRinFL »
I'm not a fighter, but I would be wary of any knife with a metal ring around one of my digits. It seems it would be easy to get your finder trapped and broken or de-gloved. Neither of which would be an asset during a crisis.
Sumdumguy
Re: Smaller P'kal
#35
Post by Sumdumguy »
dd61999 wrote:
Sun Apr 11, 2021 4:46 pm
Thanx DD,
I disagree with this 100% and suspect that you have never handled one. Locating the ring is a new element, yes. But, it is in no way difficult. With almost no practice, it becomes second nature.
-Thomas Jefferson
Blue72
Re: Smaller P'kal
#36
Post by Blue72 »
Sumdumguy wrote:
Mon Apr 12, 2021 8:37 am
Thanx DD,
When grappling I prefer the handle of my clinch pick or TDI knife over my Emerson Lagriffe. Especially when your opponent has control of your wrists or you need to grab with your opposite hand. Your findings may vary
When your talking about a folder like the p'kal, it’s an extra step when using the shivworks method of RGBI. You have to deploy, roll the knife and insert your finger into the knife
ZrowsN1s
Re: Smaller P'kal
#37
Post by ZrowsN1s »
dd61999 wrote:
Sun Apr 11, 2021 4:42 pm
Re: Smaller P'kal
#38
If you deploy the P'Kal as designed, simply closing your hand after deploying ends up in RGEI.
Re: Smaller P'kal
#39
The 2.0" drawing seemed too small so I'm going with a 2.25" blade.
Blue72
Re: Smaller P'kal
#40
Post by Blue72 »
sal wrote:
Tue Apr 13, 2021 8:09 pm
That sounds about perfect. It’s about the same usable length of the Craig Douglas clinch pick after you palm the knife
