Goniometers
Goniometers
I'm looking for suggestions for a laser goniometer that can show me the angles of my edges.
I currently have one of these and it isn't ideal for measuring knife edges, as I've come to find out.
:unicorn
Re: Goniometers
Hi Vivi,
CATRA makes a number of them at different price ranges that are quite effective. I have a portable one at my home and we use a large one in the Factory. Many of my teachers, like Cliff Stamp, Wayne Goddard, Ed Schempp and others have taught me that edge geometry is really more important than just about anything else when it comes to cutting performance. So we've always paid special attention to the edge and a Goniometer is essential for measuring that consistency.
It's not something that most knife users are involved with, but for Edge Junky's, it's a valuable tool. I'm sure that others will also be able to offer useful information.
Re: Goniometers
Funny this topic comes up; just yesterday I went on Amazon for a look. There is a $50 laser gonio under the name "Laser Knife Edge Reader" on Amazon with 4 ratings currently, and it's rating 3-1/2 stars.
Re: Goniometers
sal wrote:
Sun Jan 03, 2021 12:48 pm
Hi Vivi,
Sal,
The focus Spyderco places on geometry and cutting ability is one of the reasons I've been such a loyal fan all these years. When using your knives, that attention to geometry shows.
:unicorn
Cambertree
Re: Goniometers
Post by Cambertree »
I have the Gritomatic Laser Edge Lite 2.0 Goniometer.
It’s an inexpensive and useful tool.
Some larger knives don’t quite fit, but I’m talking about wide blades like the ESEE Junglas or kitchen cleavers.
Most knives should be fine in it.
It takes CR2032 batteries and mine came with a spare battery.
https://www.gritomatic.com/products/las ... goniometer
Re: Goniometers
Post by JD Spydo »
When I was still working in machine tool shops I had two brands of tools I really loved. One of them was "STARRETT" and the other was SPI. I'm wondering if STARRETT makes an angle measuring tool like these? I've been out of it for so long that I'm kind of lost on what's new in the tool industry.
There were also a couple of Japanese made machine tool companies that had decent quality as well. But of all the tools in that sector I ever used I never found anything with better quality than that of STARRETT.
Re: Goniometers
A DIY gonio using a laser pointer, a clamp, and a printed scale...
http://bessex.com/forum/showthread.php?tid=338
RustyIron
Re: Goniometers
Post by RustyIron »
Cambertree wrote:
Sun Jan 03, 2021 1:05 pm
Hey, Camber.
My name is Rob and I'm a Toolaholic... a card carrying gadget junkie. I've considered a goniometer, but I'm not sure that it wouldn't be one of those toys that sits on the shelf gathering dust. I need a rational excuse to buy one.
Most of my knives are done on a guided system. I know the angle of the guide, subtract for the angle of the blade, and I can be pretty sure to within half a degree what I'm doing. If I want a blade more acute, I make it more acute. If I want to go more obtuse, I go more obtuse. I'm not sure that knowing the precise angle will be beneficial.
How can the goniometer improve my edges?
Thanks!
GarageBoy
Re: Goniometers
Post by GarageBoy »
Gritomatic has two versions
One is more affordable than the other, both are sold out right now
Rustyiron, a goniometer shows you the edge angle (each side) at a glance. How important that is to you is your call
TenGrainBread
Re: Goniometers
Post by TenGrainBread »
JD Spydo wrote:
Sun Jan 03, 2021 1:09 pm
Starrett is indeed an industry standard for professional machinists. They do not make a laser goniometer but they do make very precise vernier protractors that might work in a pinch.
Deadboxhero
Re: Goniometers
Post by Deadboxhero »
"Hobbigoni" from Catra is the one to buy, order from CATRA in the UK. It will have a slight learning curve since light reflects differently due to edge finish, scratch pattern and convex vs flat vs hollow edges but It should be a rather eye opening tool. It's the only way to accurately measure the edge angle in degrees.
Big Brown Bear
Triple B Handmade Knives
Cambertree
Re: Goniometers
RustyIron wrote:
Sun Jan 03, 2021 1:58 pm
Hey, Camber.
Thanks!
Hey Rusty,
Good question, my friend. At the moment, I’m enjoying being able to check the exact angle of stock factory edges, in the same way I check the BTE measurements.
How useful that is, I guess only you can say.
I use benchstones and the Sharpmaker for most of my sharpening, so it’s probably more handy for that type of approach than it would be with a guided system.
As Shawn said, the laser reflects light differently, depending on the crispness or convexity of the shoulder bevel. You can check for asymmetry of angles.
If you sharpen a lot of knives for other people, it can be handy to know where the edge angle is at, before you start.
Also, if you teach others how to sharpen, they can find it useful and interesting to be able to instantly check their edge angle.
I’m sure there are better goniometers out there, but at $65 IIRC, I feel it was worth it.
Baron Mind
Re: Goniometers
Post by Baron Mind »
Sun Jan 03, 2021 1:04 pm
Hi Vivi,
Sal,
I concur. That being said, I think it could be even better. I propose rule no. 15. Target edge angle should be 15 degrees per side, with a target behind the edge thickness of 15 thousandths of an inch. Rule no. 15 would allow for a tolerance of +- 5, so 10-20 dps and 10-20 thousandths behind the edge. I don't mean to sound ungrateful, but rule no. 15 would make me an even bigger Spyderco fan, and working it into the advertising/literature/edge-u-cation could produce an even greater # of devout, well educated Spydie heads. :)
GarageBoy
Re: Goniometers
Post by GarageBoy »
Ehh, I totally understand if Spyderco has to keep edges thicker on certain models to maintain strength on weaker steels for the average user
toxophilus
Re: Goniometers
Post by toxophilus »
+1 on the Gritomatic
Below is an image of a stock factory edge Stretch carbon fiber ZDP-189 next to a Cruwear Shaman that I sharpened on my Wicked Edge.
I used it in this instance to ensure that the formula that I use to both center the blade vertically in the clamping system as well as getting as close as I can to my target °dps is accurate.
Centering the blade for me + math = even bevels (my target was 18°dps on the Shaman using the WE) :spyder:
Below is an image of the latest Endura K390 that I bought recently, it's almost spot on at 15°dps and when I finally had to resharpen it I set it up for 15°dps...
Vivi I will add that if you're interested in trying this one out I can/will ship it to you so you can try it out, just PM/DM me directly...
nerdlock
Re: Goniometers
Post by nerdlock »
Ooof, sold out! :(
GarageBoy
Re: Goniometers
Post by GarageBoy »
toxophilus wrote:
Sun Jan 03, 2021 10:10 pm
What's your method and formula for doing that?
toxophilus
Re: Goniometers
GarageBoy wrote:
Mon Jan 04, 2021 8:18 am
Oh my, rather than cluttering up this thread (it's long) I sent you a PM with the information :spyder:
msimcoe
Re: Goniometers
Post by msimcoe »
Would you mind sending me a copy of your formulas and method as well. I would really appreciate it. Thank you.
toxophilus
Re: Goniometers
msimcoe wrote:
Thu Jan 26, 2023 2:13 pm
Here is the link to the topic where I describe it.viewtopic.php?f=2&t=91388&p=1584384#p1584384
