Ark--new steel in the future?
storyville
Are there any plans to issue the Ark in a new steel? (I would love to see it in LC200N, but other steels could be attractive, too.) I find its design very EDC-friendly and utilitarian, but its H-1 leaves a lot to be desired. I'd pick up another in a heartbeat with a more wear-resistant steel.
If this has already been discussed, my apologies. Didn't find it via simple search. Thanks.
Re: Ark--new steel in the future?
I'd be interested. The PE H1 didn't impress me, and I prefer longer blades for SE so I haven't tried the SE H1 version.
I'd buy one in PE FFG LC200N.
I'd also like to see a better sheath. Mine is a CQI version with the release tab and I can pull it out without pressing that tab with less effort than I unsheath my street beat, aqua salt etc. Its the main reason I don't carry mine. Should make some kydex for it I suppose.
I don't have this model, but have been looking at it. While I'd love LC200N, I can't help but wonder how it would do as a wharnie.
StuntZombie
That's what I was thinking as well. I can only imagine it would be even more effective in its current role with a wharncliffe blade shape.
Chris
BG-ThatsMe
The new swick is your solution for a small (better grip) fb wharnie, albeit at almost twice the price.StuntZombie wrote: ↑Fri Nov 06, 2020 6:58 amThat's what I was thinking as well. I can only imagine it would be even more effective in its current role with a wharncliffe blade shape.
LC200N is really the only other steel that makes sense unless they do a coated version.
I figured this was a case where more belly means a technically longer edge which means more usable edge. Otherwise I too would figure a wharnie is better suited for this knife's intended use. As much as I dislike a lot of belly on my knives it does allow you to squeeze more serrations into a limited blade length.
Question is when will the Swick release? Been eagerly anticipating them since they were announced :)BG-ThatsMe wrote: ↑Fri Nov 06, 2020 9:30 amThe new swick is your solution for a small (better grip) fb wharnie, albeit at almost twice the price.StuntZombie wrote: ↑Fri Nov 06, 2020 6:58 amThat's what I was thinking as well. I can only imagine it would be even more effective in its current role with a wharncliffe blade shape.
Anyways I'm obviously a fan of the wharncliffe Ark idea.....
StuntZombie
You have a point there. I'm likely not the intended market for the particular knife, so my needs and usage are different.Evil D wrote: ↑Fri Nov 06, 2020 10:31 amStuntZombie wrote: ↑Fri Nov 06, 2020 6:58 amThat's what I was thinking as well. I can only imagine it would be even more effective in its current role with a wharncliffe blade shape.
Chris
- cabfrank
I like mine in H1 SE. I think the sheath has always been the weak link, even after the CQI release tab. I know there was a bit of confusion during the design process, but I always thought the sheath should have been made to fit the Spyderco G-Clip, for ease of carry other than around the neck.
BG-ThatsMe
I can see why...little wharncliffe blades are incredibly useful. I was hoping to see the swicks this year, but I'm not going to hold my breath with all that's going on in the world these days. Maybe we will be surprised.vivi wrote: ↑Fri Nov 06, 2020 10:42 amQuestion is when will the Swick release? Been eagerly anticipating them since they were announced :)BG-ThatsMe wrote: ↑Fri Nov 06, 2020 9:30 amThe new swick is your solution for a small (better grip) fb wharnie, albeit at almost twice the price.StuntZombie wrote: ↑Fri Nov 06, 2020 6:58 amThat's what I was thinking as well. I can only imagine it would be even more effective in its current role with a wharncliffe blade shape.
When you're in the shower, the only other place you have available is... what you're guarding...cabfrank wrote: ↑Fri Nov 06, 2020 1:49 pmI like mine in H1 SE. I think the sheath has always been the weak link, even after the CQI release tab. I know there was a bit of confusion during the design process, but I always thought the sheath should have been made to fit the Spyderco G-Clip, for ease of carry other than around the neck.
Not what I would consider an ideal alternative! :p
-Thomas Jefferson
-Thomas Jefferson
If you drill an extra hole the Ark works with a g-clip.
I tried that then decided some paracord loops setup for horizontal carry worked better.
- cabfrank
Vivi, I might try the extra hole. Right now I use a method similar to yours, but zip ties.
Sumdumguy, agreed, but I don't need mine in the shower.
I've never been a big fan of the modified pistol grip with knives, really my only hesitation on a knife that's not even available yet (the Swick). But that's just me.
storyville
So, no new steel for the Ark, I take it? Seems like a good model for it, esp to tweak it from SD mainly to EDC mainly + SD 'on call.'
