The poll selections are not about:
- steels
- models
- production vs sprint/exclusive runs
Scale pictures welcome, even if they are not burnt orange or blurple
You had a tough time with cleaning your scales on your Rex45 Military didn't you? I find using a Magic Eraser works the best on cleaning G10 scales of any color. I've tried 3 different products/methods so far, but none is faster or less messy than using the Magic Eraser.The Meat man wrote: ↑Fri Oct 30, 2020 6:49 amBlurple all the way. Not only does it look better in my opinion, it also doesn't show dirt or grime as quickly as burnt orange.
Yeah I did. And I made the mistake of boiling the scales in water to try to loosen up the embedded grime. All that did was give it a washed-out look, like old vomit.TkoK83Spy wrote: ↑Fri Oct 30, 2020 6:53 amYou had a tough time with cleaning your scales on your Rex45 Military didn't you? I find using a Magic Eraser works the best on cleaning G10 scales of any color. I've tried 3 different products/methods so far, but none is faster or less messy than using the Magic Eraser.The Meat man wrote: ↑Fri Oct 30, 2020 6:49 amBlurple all the way. Not only does it look better in my opinion, it also doesn't show dirt or grime as quickly as burnt orange.
:p .. now I understand...
It's amazing the colors they produce, isn't it!
