Page 1 of 2
Salt knives pivot lube ?
Posted: Fri Sep 18, 2020 3:47 am
by johnson
Hey everybody.
I'm curious to hear some opinions please.
Do you lube your Salt knives pivots and what lube do you use ?
Thanks, John
Re: Salt knives pivot lube ?
Posted: Fri Sep 18, 2020 5:20 am
by VooDooChild
Not really
Posted: Fri Sep 18, 2020 5:26 am
by M Sea
Hey everybody.
Thanks, John
All of my Salts were fairly rigid before they broke in to perfection. I am hesitant to lube anything on a knife until the metal to metal mating surfaces have worn naturally. Once that occurs, I disassemble if needed, flush out any debris left and use a small amount of a very light lube that leaves a trace of teflon behind. That has always worked well for me. Good Luck, the Salts are awesome!!
Posted: Fri Sep 18, 2020 7:20 am
by prndltech
Nope
Posted: Fri Sep 18, 2020 8:32 am
by steelcity16
I've never lubed any of my knives. I don't really worry too much about action or flick-ability though.
Posted: Fri Sep 18, 2020 8:36 am
by Cambertree
I don’t think I ever have.
Although I suppose water is technically a lubricant. :p :D
Posted: Fri Sep 18, 2020 11:08 am
by Buddafucco
I use reel oil on any knife that i oil. I don't know the brand off of the top of my head. It was cheap off of Amazon though.
Posted: Fri Sep 18, 2020 11:16 am
by soulspy
Fresh water rinse.
Posted: Fri Sep 18, 2020 11:40 am
by araneae
Not really
Posted: Fri Sep 18, 2020 11:44 am
by VashHash
I usually oil them with whatever oil I have around. Can't really hurt them.
Posted: Fri Sep 18, 2020 12:23 pm
by cabfrank
I have read that many people think it isn't necessary, and that the FRN is sort of "self lubricating". Still, I find them smoother with a bit of occasional oil, especially after rinsing them out. I use Ballistol. It works great, and keeps them food safe.
Posted: Fri Sep 18, 2020 12:24 pm
by ladybug93
i've dropped some reel oil in my pac salt once or twice, but i don't think it's necessary at all. the blade is riding on the pivot and between plastic scales, so there's not really a need to oil it. i've had my pivot full of both fine and gritty sand and the knife still works just fine. there's something wonderful about the simplicity of it all.
Posted: Fri Sep 18, 2020 1:20 pm
by NorthShoreBoiBoi
I think it depends on what you're doing with it. If I know i'm going to be on a boat or in the water with the knife then I usually don't bother oiling because its just going to come off. Maybe if i'm around the house, but most of the time the only oil is the remainder after a cleaning and disassembly
Posted: Fri Sep 18, 2020 1:38 pm
by James Y
I don’t really lube my Salts. The only time the action has ever felt a bit less smooth (other than some grit) is after I’ve had one immersed in the water for a long time; the FRN seems like it temporarily swells a bit from submersion in water, so the action feels less sharp/less smooth for a while. Then after the moisture dries out, everything’s fine again. I don’t know if anybody else has ever experienced that?
On rare occasions, I might apply a tiny amount (one drop) of Tuf-Glide, not on the pivot, but on the part of the blade tang that’s exposed when the blade is closed; the part that rubs against the backspring. I work it in by opening and closing the blade a few times, and that’s it. But I hardly ever do that.
Posted: Fri Sep 18, 2020 2:00 pm
by Lumpy
I drop a little KPL in if I’m doing a full disassembly and cleaning, but I really doubt it’s necessary. Just the same thing I would do to any other knife.
Posted: Fri Sep 18, 2020 2:18 pm
by Evil D
I use Phil Wood bearing grease in all my pivots, more so for better pivot action but I've also found that it creates a nice physical barrier that blocks crud from getting into your pivot.
Posted: Fri Sep 18, 2020 2:31 pm
by JRinFL
Like many, I never use lubricant on my Salt knives. They get rinsed under the faucet or in the pool then left to dry.
Posted: Fri Sep 18, 2020 10:10 pm
by Takuan
Frog Lube is slick, corrosion-resistant, and food-safe. I use it on my knives and firearms.
Posted: Fri Sep 18, 2020 10:24 pm
by cabfrank
Frog lube would be great too. As you said, also food safe, like Ballistol.
Posted: Fri Sep 18, 2020 11:30 pm
by prndltech
+1 for ballistol. I use that stuff for everything, like I said earlier I don’t really live my salt knives, maybe a drop of ATF or motor oil but if I plan ahead ballistol is where it’s at.
