Page 1 of 1
Imperfect tri-stones on Sharpmaker
Posted: Sun Aug 23, 2020 11:23 am
by Mako109
I probably should have asked a long time ago. The tri-stones on mine, particularly the Fine (white) feel imperfect.
1. The sides on mine have "pimples". I mean if i run my finger down one side I can feel a pimple or two; and it's like this on two sides per stick, giving me only one side on each stick to use.
2. The corners on some parts are slightly jagged. So slight I can't see it until I run my fingers over that portion, but it's certainly there.
Are these conditions normal? Should the sticks/rods feel perfectly smooth?
Re: Imperfect tri-stones on Sharpmaker
Posted: Sun Aug 23, 2020 12:13 pm
by Wartstein
Sounds not normal to me: Just checked my white, brown and CBN rods: All perfectly smooth (other than being abrasive of course..
) on the flats and the corners, no "pimples" or jagged spots.
The "pimples" on yours are really that bad that you actually can´t use the flats where they (the "pimples") are?!
Posted: Sun Aug 23, 2020 12:34 pm
by Sharp Guy
I have a couple sets of each and mine are all smooth. Have you considered contacting Spyderco?
Posted: Sun Aug 23, 2020 12:41 pm
by The Meat man
The are some bumps on my UF stone flats that will chip an edge if I try sharpening on them. Luckily, there's at least 1 side to each UF rod that is perfectly smooth so I just marked the smooth sides and only sharpen on those.
Posted: Sun Aug 23, 2020 1:32 pm
by Mako109
Wartstein wrote: ↑Sun Aug 23, 2020 12:13 pm
Yes, I feel that's why I've had such difficulty. Like "The Meat Man", I marked the two sides that are perfectly flat and just use those.
Posted: Sun Aug 23, 2020 1:33 pm
by Mako109
Sharp Guy wrote: ↑Sun Aug 23, 2020 12:34 pm
Unfortunately it's been several years since I purchased mine, so I doubt they'll do anything.
Posted: Sun Aug 23, 2020 1:34 pm
by Mako109
The Meat man wrote: ↑Sun Aug 23, 2020 12:41 pm
Yes, that's been my solution too.
Posted: Sun Aug 23, 2020 1:37 pm
by tonijedi
Same with mine. I don't know exactly well but I bought them many years ago, probably more than 10, and they were like that from factory.
Posted: Sun Aug 23, 2020 6:00 pm
by Cambertree
Yes, my Sharpmaker rods are smooth.
It’s obviously a different kind of rod and a different production process, but my diamond rods had a few very large particles - one chunk was so much of a ‘pimple’ that it would catch and stop the whole knife dead in the pass.
Luckily it was near the bottom of the rod.
I ended up knocking the outsized pimple out by tapping it with the side of a plane iron. I wonder if you could do something similar on your caramic rods?
Posted: Sun Aug 23, 2020 6:32 pm
by jpm2
It's pretty common to flatten and lap sharpening stones. This will remove new stone imperfections.
With new diamond plates, I run a scrap piece of steel over them till the surface is even.
