If you print out this picture in 100% you should be good to go.
I re-scaled it from the scan jpm2 according to his measurements,
so better double-check before.
That's the GB1
The issue is that the original hollow grind follows the curvature of the original edge. If you shorten the blade and regrind the edge so that the tip profile is the same, the tip ends up right in the middle of the hollow grind. That causes the edge to grow and grow all the way to the tip, which ends up looking a bit odd. The “right” way to do this would be to redo the hollow grind as well so that it matches the new curvature to the tip, but as zhyla said, most wouldn’t have the equipment to do so.jpm2 wrote: ↑Mon May 25, 2020 4:16 pmI'm not sure that tip placement isn't much different from the original, which would make it the same thickness.Ez556 wrote: ↑Mon May 25, 2020 3:44 pmThis would be my worry. If you bring the edge up at all, it’s gonna end up being significantly thicker and the edge is gonna end up looking really odd at the tip. I’d just bring the spine down to the edge somehow rather than bringing the edge up at all, that’ll also prevent any issues with the edge ending up above the scales when closed.
I don't have a GB2, anyone post an image for comparison?
