If you could have a magic knife, would you rather?
silvershade255
Imagine if you could have a knife that could either be any steel/handle etc at a moment's notice, but only one design, *or* could change to any design instantly, but only one steel/handle choice, which would you pick?
"Seven for One"
- kennethsime
Re: If you could have a magic knife, would you rather?
Definitely one design, but any steel blade and any handle material. ****, I probably wouldn't even change the handle material, just OD Green Micarta.
Probably a PM2, maybe a Stretch 2 with the straight spine.
- bearfacedkiller
I would pick just one steel. The design of a knife is 100 times more important than the steel, and this is coming from a steel junkie.
I need edc knives, kitchen knives, hunting knives, fillet knives and field/survival knives. I would never want to do everything with just one type of knife.
Easy choice, one steel/handle material but any design! So much more potential.
- The Deacon
As long as I got to pick the "one steel and handle material", I'd rather have knives for every purpose, so I'm with Darby on this one.
For testing steels, the second. For real world use, the first.
W6Re: If you could have a magic knife, would you rather?
I voted for one steel multiple designs. I would guess this "magic knife" could change blade length and thickness as well with the design.
I'd take multiple designs, and since it's magic, the steel/handle would be the vampire blade, Stormbringer, from the Elric series of books. Would be quite the tactical knife.
Definitely one steel/material for the same reasons Darby stated above. The tricky part would be picking that one steel and one material! Micarta or terotuf? Cruwear for all-purpose...or something like LC200n?
- Julia
The design is, to me, the most important part of the knife. Switching blade steels on the fly however, that would be super neat.
European amateur knife enthusiast
Hikes and outdoors galore
Motorcycle enthusiast
In the knoife box : M4 Millie, Spyderco Perrin Street Bowie, TOPS Tanimboca
In the future : CE/SE/Rex45/MagnaCut Millie, K2, Slysz Bowie, linerlock Sage
- Julia
I practically live both these scenarios at the same time since I almost never use anything but the same knife and the same steel. I could probably live the rest of my life with LC200N and be just fine with it, so having any knife design with that steel sounds pretty cool. Some of us have already lived the "any steel in one model" with all the sprint variants coming out. If we're honest with ourselves, steel options really start to be redundant after a while, so many steels are similar enough to each other that you need to jump to far ends of the spectrum to see differences that really matter in real world use, so I don't see much need for infinite steel options in one model because I would just pick the steel I like most and probably never use the others, just like I already do in real life.
- standy99
I have a magic Knife cupboard that gives me a mix of both choices already
Heap of steel types, Heap of handle materials and heap of designs
Even has a few draws with a heap of sharpening options
bearrowland
An affordable all titanium Autonomy!!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
Are you SEF in disguise?
bearrowland
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
I thought SEF was back, for a second.
- best wishes, Jazz.
