Pink Knives
Pink Knives
Are there any pink knives in the pipeline? My girlfriend just bought her first Spyderco and tried to dye it pink unsuccessfully, and she’s pretty bummed about it considering how excited she was. I’d hate for this first experience to turn her off to it. I’m aware the native exists (I bought my sister one) however my girlfriend works near the ocean and likes the idea of a rust resistant or rust proof knife. Thanks for the input :spyder:
- VooDooChild
Re: Pink Knives
Your best bet is to buy a pink native 5 lightweight, and a native 5 salt and swap the blades out. This will give your girlfriend a rustproof pink native 5 and you will have a yellow one with s30v that you could dye black if you wanted.
I mentioned in another thread a while back that I thought it would be cool if the pacific salt 2 and salt 2 would get a neon pink and black treatment. Or neon green also. But it probably wont happen.
Re: Pink Knives
There was a thread recently about a desire for pink Delicas and Dragonflies. I seem to recall Sal was hip to the idea.
Re: Pink Knives
I would recommend the Jumpmaster 2 and dying the handle pink with Rit dye.
Re: Pink Knives
Yes, in fact I'm pretty sure he said he was planning to put the pink delica back into regular production. It'd be vg-10, so not totally rust-proof, but definitely an easy-to-maintain stainless steel.
- Julia
Re: Pink Knives
There are also some pink PM2s out there.
-Thomas Jefferson
-Thomas Jefferson
Re: Pink Knives
If you do buy a Native Salt and a Native LW to do a blade swap, I think it is best to swap the spring and lock bar too.
Re: Pink Knives
Thank you for the input everyone. My question to you now is, can you dye a yellow salt pink? Like JohnAPA suggested?
Re: Pink Knives
You can dye yellow FRN pretty much any color. It will wear off over time, but it's an easy thing to repeat on a Salt knife.
Also, I cannot reccomend LC200N enough. It is a stupidly, ridiculously awesome steel. I love it!
Don't forget the Caribbean
-Thomas Jefferson
-Thomas Jefferson
Re: Pink Knives
It might take trial and error since it's not a white handle. The yellow may come through and make a florescent orange color. As someone stated before a blade swap with a pink native would work better. You can always go from a lighter handle to something darker but using a lighter dye it's more likely to tint the handle with the base color.
Re: Pink Knives
The almost-white ivory straight spine Stretch should work great for dying into another color.
PM 2 size, awsome knife
In this thread viewtopic.php?f=2&t=86358 you can see an original ivory colored as well as a green dyed SS Stretch
Re: Pink Knives
Keep on the search. Good luck! I have 3 daughters (and a wife). I did manage to score a gently used pink Delica. Pink Squeaks are also still around.
- Mini2white
Re: Pink Knives
The Squeak isn't H1 or similar but it is readily available.
