1. Leatherman Wave+
Specifications:
- Dimension: 10 x 6.5 x 4.5 inches
- Number of tools: 17
- Weight: 8.5 oz or 9.5 oz with case
- Material: stainless steel
- Color choices: 2 (steel & black)
- Warranty: 25 years
Leatherman Wave+ is the best-rated multi-tool for different purposes. It has 17 tools in a lightweight design that comes in just 8.5 ounces of weight. Its stainless steel construction gives the device a premium look while its body is specially built of heat-hardened steel to ensure sturdiness. Your Wave+ tool has all features that you need: a can/bottle opener, scissors, wire cutters, pliers, two saws, two blades, and a few screwdrivers.
We like this Leatherman Wave + because its screwdriver is customizable, allowing us to use it on different tasks with ease. Plus, its wire cutters are replaceable, which means the tool is highly convenient to use. So if we were asked: “what is the best multitool”, we would say the best one should give users flexibility and versatility. The current price of Leatherman Wave+ on Amazon is around $90, making it an affordable model for most shoppers.
2. Leatherman Surge
Specifications:
- Dimension: 8 x 6 x 2.5 inches
- Number of tools: 21
- Weight: 12.5 oz
- Material: 420HC stainless steel, Black Oxide
- Primary Blade Length: 3.1 inches
- Closed length: 4.5 inches
The materials of Leatherman Surge are thick, stiff, and robust. So Surge is, unsurprisingly, ranked as the highest-rated multi-tool for heavy-duty tasks. If you’re thinking of using this multi-functional tool for tough jobs like bending sheet metal or extensive wiring, you’ve got the right choice! One disadvantage of Leatherman Surge is its weight. With more than 12 oz, it’s not the most portable tool for daily carry, but a better fit for a toolbox.
➜ RELATED: https://thekinglive.com/looking-for-the-best-multitool-find-your-one-in-a-thousand.html
3. SOG Sync II
Specifications:
- Closed length: 3.1’’
- Number of tools: 12
- Weight: 5 oz
- Blade steel: 5Cr15MoV
- Finish: Bead Blasted
- Sheath included: no
- Assisted opening: no
It is built from solid metal in a compact shape of 3.1 inches in length. SOG Sync II is a perfect tool to keep in your pockets for unexpected events. However, it doesn’t mean it does not have many tools. It has 12 devices, and some of the most common ones are the wirecutter, a ruler, a pair of pliers, a small blade, and scissors.
4. Gerber Dime Multi Tool
Specifications:
- Dimensions: 2.75 x 4.00 x 0.60 inches
- Overall length: 4.25 inches
- Closed length: 2.75 inches
- Weight: 2.24 oz
- Materials: HC stainless steel
5. Gerber Suspension Multi Tool
Specifications:
- Dimensions: 4.00 x 1.00 x 6.00 inches
- Weight: 9.0oz
- Closed length: 3.5 inches
- Materials: stainless steel
Are you worrying if you can use the knife blades of this tool with one hand? Fret not! With just a little practice, you can use it with one hand, thanks to an easy-open tab. Also, its spring-loaded main pliers automatically open. Last but not least, Gerber Suspension can be taken separately with ease, in case you need to clean it up. Doesn’t it deserve to be on your shortlist?
6. Victorinox Swiss Army Spirit X
Specifications:
- Weight: 9.0oz
- Number of tools: 24
The bottom line
The best multi-tool on the market lets you cut, saw, sand different surfaces and materials conveniently. House maintenance, installation, restoration jobs; camping and outdoor tasks would be much more comfortable with the help of multitools. If you’re keen on great tools with lots of functions, then Victorinox Swiss Army Spirit X or Leatherman Surge would be ideal. However, if you prefer a small tool to keep in your pocket, then SOG Sync II would be a great option. Regardless of which tool you decide to purchase, all six above tools were carefully and reviewed. We hope our post was informative. Click share if you like it, and leave us your comments below.
