Sal: How about a Chaparral with 2.5mm blade thickness?
nativeleek
Postby nativeleek » Sat Nov 16, 2019 1:07 am
Hi Sal.
Chaparral is pretty much a perfect EDC folder for gentlemen's carry or for people with small to medium sized hands. The only thing that possibly needs to improve is the thin lock-bar, which may become a hot-spot when being pressed.
A simple way to solve this problem is to make the blade a little thicker, let's say from 2mm to 2.5mm. This will make the lock bar a lot more comfortable to press and also make the blade a little bit stronger, with absolutely no impact on the carriability.
If there is a plan for Chaparral 2, is it possible to make this change happen? Every other thing about Chaparral needs no change. Just make the blade a little thicker and keep everything else the same as the present Chaparral.
Thanks!
Delica 4, Dragonfly 2, Native 5, Sage 5, Chaparral, Techno 2, Positron, SpydieChef, Para 3, Lil' Native lockback
Users browsing this forum: KillaCaltron, Majestic-12 [Bot], Ratamaque, skeeg11, Sumdumguy and 26 guests
