Does Spyderco Loctite their pivot screws?
normal
Post by normal »
I just got a new Spydiechef and was not a fan of the new black hardware so I got some blue titanium replacement screws. Well, the pivot screw will not loosen. Anyone else have this problem? If so, how do I get it loose?
VooDooChild
Re: Does Spyderco Loctite their pivot screws?
Post by VooDooChild »
Pretty sure tha answer is sometimes but on the chef and many others the answer is yes. Watch some disassembly videos online. Might have to take a hair dryer to it.
JonLeBlanc
Post by JonLeBlanc »
If I'm not mistaken (and I often am) wasn't there a change from red to blue on some models, like PM2/Para3 etc...? Within the past two years?
Also sometimes pivot screws are kinda tricky; sometimes one has to hold the other sides screw in place whilst one removes the first screw all the way (if that makes any sense).
JuPaul
Post by JuPaul »
If you can't get the screw loose no matter what you try, or you're just worried about damaging it, you can send it into spyderco repair. They will do it for free, but you do have to pay for shipping both ways.
- Julia
Michael Janich
Post by Michael Janich »
It's also important to remember that the female side of the pivot pin is a "D" pin, which means it has a flat side machined on it (instead of a circle, its cross section looks like a capital letter "D"). It fits into a corresponding D-shaped hole in the reverse-side handle scale. Although the female side of pivot has a Torx head to provide a symmetrical look to the knife, it will not turn. If you succeed in turning it, you will have succeeded in destroying the D-shaped hole in the reverse-side scale.
The actual screw for the pivot is on the obverse side of the knife. This is the "show" side, as typically shown in photos of knives--edge down, point to the left.
I hope this helps.
Stay safe,
Mike
jdw
Post by jdw »
I have a PM2 at Spyderco warranty and repair right now for screws that wouldn't budge, that I stripped just trying to flip the clip. The clip is supposed to be reversible but it is still costing me $25 for Spyderco to 'fix' it.
--Wovoka
I just had to use a rather extreme amount of force to free the pivot screw from my new K390 PM2. Inside it looked like a healthy amount of BLUE loctite. I've taken apart more PM2s then I can count and this was the most difficult to date. The clip screws were less challenging.
koenigsegg
Post by koenigsegg »
jdw wrote:
Tue Oct 08, 2019 7:22 am
They charged you? I don't think I've ever been charged by them for work
sok
Post by sok »
abbazaba wrote:
Tue Oct 08, 2019 9:12 am
Same here.
Sumdumguy
Post by Sumdumguy »
If you sent a check, they usually send the check back with the knife.
-Thomas Jefferson
normal
Post by normal »
Thanks for all of the info and suggestions. I will try again tomorrow and see what I can do with my newfound knowledge. I have a dozen Spydercos and have never run into this before, but this is my first Taichung model.
