Community Sharpening Journal
Re: Community Sharpening Journal
#1241
metaphoricalsimile wrote:
Mon Apr 11, 2022 4:45 pm
Also check out my dremel job for using the Sharpmaker Precision Adjust with spyderco knives. I cut out one side of it and left the other factory. The knife is just as easy to center in the jaws but being able to hold the blade like this means the bevel angle is more consistent front to back.
Pardon my ignorance, but what did you Dremel?
metaphoricalsimile
#1242
Post by metaphoricalsimile »
kennethsime wrote:
Mon Apr 11, 2022 9:59 pm
If you look at Tkok83's picture of the CRK in the worksharp precision adjust, you'll notice the side plate on the clamp has a small V cutout to help center the knife in the jaws of the clamp. It looks like that on both sides from the factory. I dremeled out a slot on one side to let spyderco blades fit deeper into the jaws.
Ramonade
#1243
Post by Ramonade »
I personnally just put it sideways and clamp it as hard as I can. I think I'm gonna use the dremel too, thanks for the idea @metaphoricalsimile !
Robert Ptacek
#1244
Post by Robert Ptacek »
olywa wrote:
Tue Apr 05, 2022 11:22 pm
Smooooooooth..... How are the corners on your Diamond rods holding up?
Please school me.I thought somewhere I read(heard) that they didn't advise using the corners on the diamonds or am I misrememberiing.
bbturbodad
#1245
Post by bbturbodad »
Robert Ptacek wrote:
Tue Apr 12, 2022 10:55 am
The corners on the diamond or CBN rods are the best way to reprofile an SE edge. You need to take your time and use very light pressure or they will wear out quickly.
-Turbo
#1246
Mon Apr 11, 2022 11:05 pm
Ahh, gotcha! I have the same sharpener, may have to try this.
#1247
That crowned spine on the Sebenza doesn't do many favors with the clamp in this system. Thankfully it clamps enough that I haven't had any issues with the knife moving during sharpening. Still working at that knife, lost a bit of motivation the past few days though!
metaphoricalsimile
#1248
Here are closer pics of my WS PA clamp mod. The advantage is that it's easier to set up the edge on tall spyderco blades a consistent distance from the pivot of the sharpening stone slider, hence giving your bevel a more consistent angle across the whole blade. I found that leaving the blade sort of half-out-of-the-clamp made the system too flexy for my liking, considering it's already a fairly flexy sharpening system.
#1249
I like that. May need to copy it. Great Improvement!
Robert Ptacek
#1250
bbturbodad wrote:
Tue Apr 12, 2022 11:44 am
Gotcha,Thank You.
Ramonade
#1251
Post by Ramonade »
Just bought myself a 220 DMT Dia Sharp.
I have some 220 and lower with venevs and work sharp, but I wanted a bigger stone to try some stuff out.
I'll make a 220 edge on one of my folders (or the MC Mule if it needs sharpening fast enough).
Soanso McMasters
#1252
Post by Soanso McMasters »
Ramonade wrote:
Fri Apr 15, 2022 2:42 am
Which one is the 220? I have a coarse/fine and a fine/extra fine currently and I have a coarse/extra coarse on the way.
#1253
I have the coarse/extra coarse stone myself and that thing is awesome. Extra coarse side when new, I'd break it in with a cheap knife first. When I used mine the first time, the knife was hopping on the stone with very light pressure.
Ramonade
#1254
Post by Ramonade »
Soanso McMasters wrote:
Fri Apr 15, 2022 3:08 am
The extra coarse is the 220. They even have a extra extra coarse code (silver color) wich is 120 grit, but I don't know if it exist in their diasharp line, I have their small 4" whetstone in 120 grit and 8000 grit ^^.
Ramonade
#1255
Post by Ramonade »
I like double sided stones, but I often use the diasharp stones in my hand close to my face, I like to have the smooth side under it ^^
Rymanz
#1256
Post by Rymanz »
Bit of a tip to make the Worksharp PE less flexy during use:
Purchase a V-Clamp support to hold it up. I purchased the one linked below, but any of a similar design will do the trick. Made a HUGE difference in consistency and stiffness on my system, and I'm able to get much better apexes. Only downside is that it takes longer to flip the knife over because you have to remove the support before rotating the clamp. A worthy sacrifice IMO for increased stability.
https://www.gritomatic.com/collections/ ... ion-adjust
:bug-red
Ramonade
#1257
Post by Ramonade »
Yep it's pretty useful to have something supporting it ! I personnally use commemorative coins from the soccer world cup of 1998 and a stiff eraser :squinting-tongue
olywa
#1258
Post by olywa »
Just picked up a DMT 10x4 DuoSharp in Coarse/Extra Coarse. I have had the Fine/Extra Fine for some time and really appreciate the extra real estate on these 10x4 DMTs.
cholla_remover
#1259
Post by cholla_remover »
Loving this Precision Adjust Dremel mod.
I got a Worksharp clamp adapter from Gritomatic, it fits a KakBritva clamp - wide with a split in the middle and a bolt on each side for adjustment. Holds the FFG blades perfectly. It does put the blade out farther from the sharpener, so you have to use an angle finder.
Soanso McMasters
#1260
I used my benchstones to sharpen my Stretch 2 K390 and was really pleased with how easy it sharpens. The burr formed quickly and removed quickly on the stones. Stropped up very sharp.
