Chaparral lock bar and spring
- MichaelScott
Got my new Chaparral FRN today. It was fine except for the blade action being a bit stiff (no surprise for a new knife) and the lock bar was also difficult to depress. Doing so would leave a groove in my thumb. Following Sharp Guy’s advice I disassembled it, easy enough, cleaned the factory lubricant, moved the lock bar spring forward so that the hump of the spring rested just behind a similar hump on the lock bar. Maybe an eighth of an inch. Lubed the PB washers and reassembled. Now, it is very easy to depress the lock bar and the blade practically falls free with no play.
I suggest that Spyderco improve the lock bar issue by shortening the spring slot or lengthening the spring.
http://acehotel.blog
Team Innovation
Team Innovation
RazorSharp86
Re: Chaparral lock bar and spring
I know that I may be a minority but I like the stiff spring on the Chap.
Many people complain, but my calloused don’t.
Yep, it's better to keep it this way, the way some like it, and be adjustable the way others like it, instead of just having one way.RazorSharp86 wrote: ↑Sat Apr 20, 2019 6:52 pmI know that I may be a minority but I like the stiff spring on the Chap.
Now what was that about never needing to take a knife apart? :rolleyes:
- MichaelScott
From what I have read the lock bar spring tension is variable. A few are easy, most are difficult to release and a few are just painful. Check Nick’s Chaparral reviews. It’s a gentleman’s folder with a thin, sharply cornered lock bar release. Shouldn’t take excessive force, enough to leave dents in one’s thumb, to operate it.
Best to make it reasonable to begin, then those with calloused thumbs could adjust to whatever pain level they desire.
Team Innovation
Team Innovation
- this_is_nascar
I've owned and own several Chaparral knives. Never an issue for me, but I'm glad there's a solution for you folks.
I'm glad the spring turned out to be adjustable for those who want to go that route.
Mine was fairly stiff it first, but at least in my case I found it broke in nicely on its own without any adjustment. Same story with the Baby Horn.
:spyder:
- bearfacedkiller
Mine was very stiff and had pretty sharp edges on the lock bar. That plus how thin the lock bar is was uncomfortable. I was able to adjust the spring and also knocked the edges of the lock bar down with a stone. It's outstanding now but I wouldn't have carried it as it came and I don't have soft hands.
- steelcity16
My Chap LW felt stiff at first compared to the Natives, but softened up very quickly with use. It doesn't bother me at all now.
Both my Chaps were very stiff at the beginning. The FRN version the most. A bit of oil and opening and closing a lot with a piece of cloth did the trick. They are very smooth now and very easy to unlock. Just need some time to break in.
Sudarshan Chakra
This was a Godsend! Just picked up a Chaparral and can barely unlock it. Took it apart this morning, adjusted as recommended, and voila! Much appreciate the info here. Thanks to everyone who posted!
