Cara Cara 2 very stiff.
Grjfer
Postby Grjfer » Wed Mar 27, 2019 1:59 pm
Just got a new Cara Cara 2 FRN, and it is very stiff opening. I have flushed out the pivot with 70/30 isopropyl alcohol, then blew it out with compressed air, and oiled it. I have lossened the pivot screw to the point it has a lot end play in the blade. I have also found the lock to be very tight.
Wondering if it is worth sending it back for warranty, or just use it in hopes it will break in?
For what it's worth I got a Meadowlark in G-10 at the same time and it is a night and day difference.
bgcameron
Re: Cara Cara 2 very stiff.
Postby bgcameron » Wed Mar 27, 2019 9:15 pm
I wonder if the lock spring is too tight? How is the stiffness when you depress the lock while opening it?
Grjfer
Postby Grjfer » Wed Mar 27, 2019 11:51 pm
It's virtually impossible for me to depress the the lock and open the knife at the same time. When I can gey positioned in a way that I can open it anf hold the lock, it opens pretty well. May be I'm just expecting to much based off my Endura's and Delia's.
bgcameron
Postby bgcameron » Wed Mar 27, 2019 11:57 pm
Hmm, maybe it just needs some breaking in. It sounds like the stiffness is from the lock bar.
anagarika
Postby anagarika » Thu Mar 28, 2019 3:34 am
Check if the lockbar pivot is too tight or the lockbar has burr that rubs the liner.
Chris :spyder:
Grjfer
Postby Grjfer » Thu Mar 28, 2019 9:29 am
I have adjusted the lock bar pivot screw. I'll check for a burr.
Grjfer
Postby Grjfer » Fri Mar 29, 2019 12:32 pm
Well I decided to break it down, I gave it a good cleaning and minor polish. I figured no more than it cost I really wouldn't be out much one way or the other. Much improved now, as it was pretty gummed up.
anagarika
Postby anagarika » Sat Mar 30, 2019 3:01 am
Glad you got it resolved. Very nice design and you’ll enjoy it!
Chris :spyder:
Return to “byrd Knife General Discussion”
Users browsing this forum: No registered users and 2 guests
