Sal, Can we get CPM 15v?
Deadboxhero
Re: Sal, Can we get CPM 15v?
#461
Post by Deadboxhero »
Wed Sep 28, 2022 8:20 pm
For sure! Materials being cut plays a big factor. High grit finishes in the warehouse were a terrible idea. For those tasks, I haven't sharpened above 600 grit in a couple years now, with much better results and less time spent sharpening. Win/Win.
Most definitely, when you first get started sharpening you got to get that mirror edge then you start seeing the limitations of it and you go to the dark side of the coarse edge.
As time goes on, you start trying to find a way to ride that line to get the best of both finishes with the least amount of detriment.
That's why you'll find guys like myself have a huge Stone collection of mostly medium grit stones you're chasing the medium grit that gives you the best blend of properties for a given steel etc.
Big Brown Bear
Triple B Handmade Knives
Steeltoez83
#462
Post by Steeltoez83 »
What about the guys who edc a cheap tube of chapstick and a hank? And dab their non stainless steels with the most pocket friendly rust inhibitor I can think of. I suppose there's a downside to a knife that smells like cherry lip balm but it's a risk I'm willing to take. A simple swipe, a quick rub down with a hank or some kind of cloth and rust becomes a non issue. I've never used 15V it's attributes at the edge is what peaks my interest. Whether I get the manix or the collab offering I plan to drive it like I stole it. And then regrind it.
weeping minora
#463
Post by weeping minora »
WilliamMunny wrote:
Wed Sep 28, 2022 7:18 pm
weeping minora wrote:
Wed Sep 28, 2022 2:28 pm
WilliamMunny wrote:
Wed Sep 28, 2022 1:53 pm
I am bring back this thread with the upcoming release of the Manix 2 in 15v. This should have a lot of good info.
I have two questions, I have not read this whole thread yet so if it’s been answered already sorry.
1. How is 15v vs S90V? They have similar toughness and edge retention but S90V is stainless. Why wouldn’t you always go with S90V?
2. What kind of corrosion resistant can we expect from this? Rust spots, patina, will it just rust in the pocket, etc?
I don't think enough people have experience with 15V to even post a definitive comment to your requests. I don't want to sound like a rear-end, but you keep posting questions regarding minute differences on the same subject from thread-to-thread, seemingly dismissing any discussion or information specified in said threads as it is. It gets kind of muddied when you just keep posting, "what about A vs B?", "now what about A vs C?", "now what if A was treated like C vs B for people who think like D?". I understand the quest for knowledge and understanding is great, but there are vast resources on the subject that span far and wide. If you are into these super steels, you should do yourself a favor and start to research and decipher what alloying contents do what within a steel to form an idea on the overall performance of the matrix from the perspective of possibility given an ideal, or different heat-treatment.
S90V is to 15V, as apples are to oranges. The only comparable trait being low toughness, or in other words, they are both fruit. 15V will certainly rust in the pocket for most who perspire, or live in a humid environment, as has S90V for that matter, for a select few. 15V will have much higher attainable hardness and wear resistance. I assume the edge will yield much higher strength (due to hardness), be much more aggressive (due to Vanadium Carbide content) and will hold that aggression for a long time (again, high Vanadium Carbide distribution), given that you are cutting materials that are not very hard in their abrasiveness.
Why add REX 76 to the stable when REX 45 is marginally lesser alloyed? They should behave like the exact same steel, right? As always, Spyderco seems to ask the question of, "why not?", when offering a new steel to their line-up; which has pushed my understanding on what steel can do, beyond a mere "in-use" perspective. It bridges the "why", to the experiences in use.
I hope this doesn't come off too abrasive, it just seems there are too many of the exact same questions being asked all over this forum; sometimes literally post-after-post within the exact same thread, even if answers (experiences or opinions) have been submitted. Research is your best resource (and there are a whole lot of resources), following experience.
No it’s never too abrasive, thank you for the information. That is how I got to this old thread, trying to do research to learn more. With so many threads and topics things can get missed or mis-read. I do understand that the hardness of the steel effects edge retention but it’s not even across every type of steel.
When you speak to the edge as being aggressive does that mean having micro serrations when sharpened with a courser stone like CBN? Or aggressive mean that it will hold that razor edge before breaking down to a working edge?
Someone made the post stating finishing with a CBN stone gave them better results. I can’t remember the steel but maybe K390 or Maxamet.
I'd look at it as the hardness affects edge characteristics more-so than retentive capability. The Carbide Type (which can be reflective in Hardness), Volume (Amount), Size and Distribution (Homogeneity) will affect edge retention and edge aggression, which is of course in turn further affected by the overall hardness, which in heat-treatment terms is essentially a manipulation of Alloying content to come into solution (with a goal of "entrapping" Alloyed clusters, or, causing the grain formation of Carbides [Carbon fused to an Element] into the matrix), or not. This will give a better understanding of how and why an edge behaves in the manner that it does (which many factors are involved). It dives deeper than simply "edge retention for edge retentions sake".
As a side note, CarboNitrides will form when Carbon and Nitrogen are present and Nitrides will form when Nitrogen is used as replacement for Carbon. For the sake of my limitations of understanding (and longevity), I will only discuss Carbon based steels.
Without delving too deeply, Carbon content will allow higher hardness to be achieved. Chromium is complex in that it can form Carbides within the matrix, affect stain-resistance (if the content is in the 11/12%+ range freely-roaming to reduce surface oxidation and not soaked into the solution as Carbide), or it can act as a secondary hardening element when used in lower concentration and in conjunction with Harder Carbide Formers (which will assist in the hardness needed to form Harder Carbides in place of softer Cr Carbides, given a heat-treating process that favors such; typically in applications where stainlessness may not be a goal). Too much Chromium, needed for stain-resistance, places limitations on the addition, or formation of, aforementioned Harder Carbide Formers (for example; Vanadium Carbide); inhibiting heat-treating capabilities.
Vanadium will form Vanadium Carbides, which are extremely hard and offer great wear resistance and aggression. This capability in hardness also lowers toughness (the ability of the Carbide clusters bound within the matrix to resist fracture). The higher attainable hardness and the hardness of VC formed during heat-treat increases the amount of force needed to cause that deformation to begin to occur (Yield Strength), when in comparison to "tougher" steels with a lower yield strength (when relating to a lack of Hardness). Tougher steel will therefore resist permanent deformation better, though that deformation will start to be noticeable (much) sooner. Please note that the larger and the harder the Carbides are, the less toughness will be present. The volume of the Carbide (and Type) will describe just how brittle the steel will be; the higher the volume being more brittle. This is why S110V seems much chippier than its S90V counterpart.
The Powder Metallurgy process mitigates this lack of toughness within Highly Alloyed steel by creating very homogeneous, finely grained Carbide boundaries within the matrix, which will allow the harder Carbide Types to keep a reduction in size in hardening, thus increasing their toughness when relative to Ingot Metallurgy. The drawback being that Harder Carbide Types (as with Vanadium Carbide) are not necessarily tough to begin with. The increase in Carbon within the PM process allows a greater distribution of these smaller, harder Carbides to form in solution over higher temperatures (which many Hard Carbide Types require for formation). Carbide formation is essentially a "dog-eat-dog" atmosphere, where certain (harder) Carbides will form in place of other potential (softer) Carbide, given specific treatment in hardening, regardless of the steel composition. This is where differential heat-treatments are most critical. There are also interactions that can occur between Alloying Elements, binding to form Complex Cardbides, which obviously further change the behavior beyond singular Carbide Types.
Please note that I am not the most knowledged resource when it comes to the subject of steel (within the context of cutlery, or otherwise) and this is not an in-depth comprehensive understanding on the whole process, but a collective potential overview on what possibilities there are amongst Elements and how they interact and play roles in the formation of steels used for knives. I chose to place hard emphasis on Vanadium (Vanadium Carbide) as an example so frequently, because VC makes up the bulk of Carbide volume formed within CPM 15V. This is my layman understanding (and terms) and I am sharing what of the process I have come to know to the best of my understanding, whilst trying to remain understandable in relaying that info. Shawn, or anyone else can freely address and correct any miffed information at will.
IME, the edge aggressiveness is most noticeable in experience on softer abrasive materials (flesh, fruits or vegetables, cardboard, etc.). I'd describe it as such: following the "three-finger" Murray Carter sharpness testing method; the aggression at the edge is sort of like you're frozen upon contact, feeling the imminent cut if you were to apply pressure, or slide your fingers along that apex... Almost as if you were a bug that landed in a spyder's web, still, out of fear of the "bite" that will incur ;). Kind of reminds me honestly of how a very sharp saw will catch your finger with its teeth, however in this instance the cutting character is clean, calculated and sadistic in intent, instead of barbaric, shredding, or tearing. The bite itself is not toothy (as-in regarding actual "teeth", or extreme unrefined coarseness at the edge), but it grips you in a way that when you know, you know not to push your bounds, or you will be cut (quickly and aggressively). It has a feel all its own and I think Shawn summed it up nicely with the description being unquantifiable "sharpening geek speak".
As vivi had stated, this edge characteristic can be achieved from both coarse, or medium-grit finishes. I prefer a bit more refinement in my edges, as I find the longevity to increase quite noticeably, IME. You just have to pick-and-play with an array of gear to find what combination you prefer. Not all sharpening abrasives are created equal, even amongst the same abrasive materials themselves.
Regarding a "working edge"; any edge will fall into a working edge after use, though the details behind just what behavior that entails can be quite different from steel to steel. Some steel will act very similar, though, too. This is again, where the overall characteristics of the steel will tell the tale of how and why a steel degrades in the manner that it does. This is also where you will experience what that heat-treatment has done to the Carbide Type drawn out in hardening and will relay the information of Carbide Volume (increasing aggression, in higher Volume, IMO). In sharpening; the abrasive used to restore the Carbides (*which must be hard enough to cut the Carbide Type within the matrix), along with the abrasiveness of the abrasive itself, will contribute to how that working edge develops, in-and-of-itself.
I would recommend at the very least Silicon Carbide abrasives for sharpening K390, or Maxamet. I've had good results with CBN and my last sharpening of K390 was finished at a coarse 400 grit SiC stone, followed by a strop on leather with 4 and 1 micron diamond suspension. Edge is aggressive with a touch of refinement (not quite to the level of sticky, as Shawn has described it), which was to my surprise after such a huge grit jump from stone to strop. As stated, I typically prefer more refinement to my edge, though I am really seeming to like this lower grit finish so far, so I may have to eat my words regarding that preference (at least on these Higher Carbide Volume steels).
Make Knife Grinds Thin Again.
#464
we are pleased to have the opportunity to work with Shawn on"his" heat treat.
RustyIron
#465
Post by RustyIron »
Deadboxhero wrote:
Wed Sep 28, 2022 8:29 pm
For the past couple years, I've packed away my traditional stones and have been using a half dozen diamond matrix stones almost exclusively. After reading what you said, this afternoon I decided to open one of my boxes of long-neglected stones. I put them to use on both REX45 and K390 blades. The result is an edge that feels coarse and uninspiring, but it grabs fingertips in a very satisfying way.
All I've used the newly sharpened blades for is to slice tiny slivers of paper. I can't wait for morning when I'll slice up some celery for breakfast. You know you're obsessed when you start planning your meals around which knives you want to use in the kitchen.
Deadboxhero
#466
sal wrote:
Thu Sep 29, 2022 10:14 pm
Thank you Sal!
Big Brown Bear
Deadboxhero
#467
RustyIron wrote:
Thu Sep 29, 2022 11:14 pm
Attaboy, yeah it's a ton of fun playing with different Edge finishes on different steels. What was your progression and edge angle~?
Big Brown Bear
RustyIron
#468
Post by RustyIron »
Deadboxhero wrote:
Fri Sep 30, 2022 5:55 pm
I do most of my sharpening on an EdgePro, and I'm lazy, so I leave it set up to 13 degrees for almost everything. After it's all said and done, I would guess about 28 degrees total.
Of the two "experimental" blades, I took them to 650 on Columbia Gorge Stone Works diamond matrix stones. That gave me a starting point. Then I went at it very gently with a 400 grit Nubatama stone. Under magnification, the finish was very pretty... at least by my standards.
This evening I carried the REX45. It's a Native 5, if that matters. I used it to cut up an expertly prepared piece of filet mignon. It's not the most taxing cutting task, but the knife behaved exactly as I expected. It wasn't the most tortuous of tests, but it's real life.
Deadboxhero
#469
RustyIron wrote:
Sat Oct 01, 2022 12:13 am
That would be fun to see your edge with magnification, maybe get one of those budget usb microscopes.
Big Brown Bear
RustyIron
#470
Post by RustyIron »
Deadboxhero wrote:
Sat Oct 01, 2022 9:25 am
Had I known I was going to take pictures and share them, I might have finished with a little more consistency. On the other hand, these are honest examples of what I normally do when I'm sharpening a knife that I'm going to take out and use. If you see something where I'm goofing up, you won't hurt my feelings by pointing it out. These pics are from the "low-budget USB scope." Click on them to zoom in a bit, and hopefully enough detail will remain to see something.
This is some REX45, finished at about 28 degrees. First step was with CGSW 650, to give me flat surfaces to start with. Then I just made a couple light passes with a 400 grit Nubatama. You can seen that I've increased the angle ever so slightly for the finish passes. This knife was used a little at dinner last night but I can't see any degradation as a result.
This is some K390 that got the same treatment as the previous blade.
I have some thoughts on different stones that stems from my experience comparing some nice diamond matrix stones and some cheap diamond plates. The idea will apply to all types of abrasives, regardless of cost... I think. For the purpose of conversation, we'll call our abrasive size 40 microns.
On my cheap diamond plates, the abrasive particles are deposited onto the surface. The result is particles sitting about 30 microns high, above the underlying substrate. Think of it like setting cobblestones onto smoothly finished cement surface.
On the matrix stones, the diamond particles are all mixed up into liquid epoxy. The particles are more integrated with the surface, and might be sitting only a few microns high. Think of it like tamping the cobblestones down into the cement. The resulting surface is smoother, but the cobblestones are the same size.
I came up with this analogy after noticing my diamond matrix stones cut slowly and leave a smooth finish. The diamond plates, at a supposedly similar particle size, cut much more quickly, but leave a ragged surface. My intention by going back and experimenting with some of my traditional stones is that I will discover a magical sweet spot between smooth and ragged.
Woodpuppy
#471
Post by Woodpuppy »
So, surface deposited grains (plates) for reprofiling, and matrix stones for routine maintenance.
Wandering_About
#472
Post by Wandering_About »
Woodpuppy wrote:
Sat Oct 01, 2022 2:02 pm
Depends what kind of edge finish you prefer, but this is what I have been doing and the results have been much to my liking.
MNOSD member #0035
GT99
#473
Post by GT99 »
I know this is an old thread and we all have seen the 15v by now but was wondering if we could get 2 updates from Shawn
any word on the collab folder or if its still in the works? Also its been quite some time now so can we get an update on how the 15v gyotu has been performing in the kitchen...pros and cons, any chipping from hitting bones or have you cut anything frozen etc, all stuff they tell you to avoid with the higher hardness japanese knives
