Sal asks you to design a Spyderco.
Fixed or folding, it's up to you.
Share your design here!
Get as detailed as you want...sketches encouraged!
Re: Sal asks you to design a Spyderco.
manix 2 in stonewashed lc200n with a titanium handle and exposed ceramic ball bearing like the marlin spike on the tusk or dodo.
500Nitro
Post by 500Nitro »
Serrated Catcherman in H1, Silver or Black blade, Yellow Handle.
And possibly a Plain Edge version as well.
Here is my design....
The Spyderco Companion
The Companion is the newest fixed blade from Spyderco. Designed by forum member "Vivi," the Companion is meant to be an every day carry. The design is as compact as possible while retaining a full sized knife feel. The scales are fully contoured linen Micarta, with a shape meant to adapt to any hand size. The deep integral guard and generous palm swell ensure a secure grip in any conditions.
The blade is full flat ground from 2mm stock for unrivaled cutting performance. The M4 blade exhibits excellent toughness and edge retention. The leaf shape blade features a distinctive negative angle, giving the user enhanced leverage while slicing. The spine is fully radiused with no jimping for all day working comfort.
The Companion comes complete with a fold-over style boltaron sheath & Spyderco G-clip. Alternatively, a chain can be attached to the bottom two rivets, allowing the Companion to function as a neck knife. The hollow pin at the rear end of the handle functions as a lanyard hole. At a mere 3.1oz with sheath, the Companion is meant to be by your side at all times.
Here's some additional photos.
The companion next to two fixed blades it drew inspiration from:
In hand photos:
Compared to a Pacific Salt:
An idea of what it would look like on my belt:
Guys I'm not asking for which sprint run would you like of an existing knife. I'm asking for original designs. My post is more what I'm going for with this thread.
(For the record I fully support any Catcherman revivals :D)
500Nitro
Post by 500Nitro »
Vivi
I understand but Jesus, haven't we got enough problems getting what we want without adding to it ?
Daveho
Post by Daveho »
Don’t ppl get paid for this?
I assume I would be excellent at this
500Nitro
Post by 500Nitro »
Daveho wrote:
Sat Oct 27, 2018 2:02 am
Yes, they do.
After they get everyone to sign Non disclosure agreements!
Jazz
Post by Jazz »
- best wishes, Jazz.
The Meat man
Post by The Meat man »
Hmm...I would make a design based off of the Advocate. I'd make the handles partially lined G-10 with a bigger thumb hole cutout, and a linerlock after the Military style (or compression lock; either would be fine with me).
Also, I'd either bring the blade edge down closer to the finger guard, or else dispense with the flipper entirely. Probably the latter, and put a small index finger choil there instead.
Oh, and also dispense with the ball bearing washers, replacing them with PB. Keep it simpler.
For blade steel, LC200N, and I would be open to other options as well. S110V, maybe serrated H-1, or for non-stainless Cru-Wear, M4, Maxamet, K390, etc.
- Connor
Nate
Post by Nate »
Vivi wrote:
Sat Oct 27, 2018 1:14 am
I like it, reminds me of a fixed Sliverax:
h/t Mr. Blonde
:spyder:
knivesandbooks
Post by knivesandbooks »
I've got a little design I've been working on. I'll have to find it.
Small and pretty neutral. Handle sort of like the Double Bevel. Blade is slim and sort of like a Higo. Bulbs out in the top for studs or hole.
I was trying out a design on a knife that would be a spyderco ibspired slim line trapper but it didn't flow. Look jumbled.
dreadpirate
Post by dreadpirate »
Sal asks me to design a Spyderco; and then I wake up.
Halfneck
Post by Halfneck »
Jazz - I really like that Bowie lockback design.
I wouldn't so much design something new as much as modify an existing model.
Lil' Temp 3 LW
Contoured FRN scales with the Caly Jr Fish Scale texture.
VG10 or CTS-BD1N steel to keep cost down
SpyderScout
Post by SpyderScout »
Jazz wrote:
Sat Oct 27, 2018 4:00 am
Quite like that one.
RH only wire clip, coyote brown FRN and its good to go in my book. :spyder: instead of maple leaf as well, pls :D
dreadpirate wrote:
Sat Oct 27, 2018 8:56 am
Seriously, would be a dream come true! :spyder:
I actually have a number of designs that I'm reluctant to share just yet, I'd like to make physical models of each design before I do so. I'll most definitely share when I do though!
Woodpuppy
Post by Woodpuppy »
Oh yeah. That’s the stuff.
Pelagic
Post by Pelagic »
Imagine the native chief with a 4.75" blade (slightly longer, slightly taller, and EVER so slightly thicker), a pivot that's twice as big, oversized phosphor bronze washers, full liners, and a Tri-Ad lock. Available in Cruwear, XHP, and K390.
Yep. That'll do.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Stuart Ackerman
Post by Stuart Ackerman »
Whilst I do like the designs that are presented here. to post them means that they have less chance of ever been considered by Spyderco.
Any factory could make these designs before Spyderco has a chance to tool up, and that would be a huge risk to investment, only to beaten by someone else.
The less folk that see the design, the better for Spyderco.
If, however, you are merely showing off what you like to design, and are not even thinking about a collaboration, feel free. :)
JRinFL
Post by JRinFL »
This one, made in Canada, Earth.
