Spyderco Chicago G-10 - A short review
Forest Elk
Post by Forest Elk »
Over the years my "love" for smaller knives for urban EDC has been constantly growing...
Last week I received my latest Spydie: The Chicago G-10.
The Chicago is a knife which in my opinion don't get the attention it deserves. After having unboxed it my first impression was: "Wow! It's built like a tank!" Many people compare it with the Squeak, but I was immediately reminded of the feel when handling a Native 5 G-10: A moderate sized package which combines high quality materials with a very robust construction.
The F&F is made very well. Both the G-10 edges as the liners are well rounded, much better than the edges of a Terzuola Slipit I handled some years ago.The same is done to the spine edges. Also the Spyderhole is not too sharp. The G-10 surface is not too rough as to damage the pocket seam.The grind from tip to ricasso is perfectly symmetrical.
Now how does is work?
When being at work or on the way in the city, I personally have no need for a blade to peel apples, slice tomatoes or any other food prep. The short but very stout blade with its flat grind is ideal for opening plastic packages, cutting a rope or similar tasks. It is a little bit more "stretched" than the Squeak's blade, which I like asthaetically more. In spite of my hand size (9+) the handling functions very well: Opening is no problem (perhaps due to the slightly enlarged hole...), only the one-handed closing is a little bit "tricky" for me. But I get trained more and more... I personally don't miss the jimping: I see no absolute need for it on 3 mm thick blade and for me the plain thumb ramp looks better. The choice of CTS-BD1 steel is OK: It has good all-around properties and is easy to sharpen especially in the field, perhaps a reason for the German company "Pohl Force" to choose this steel for their duty knives.
There are only 2 complaints... :eek:
The blade of my exemplar is a little bit off-centered, a point which is often mentioned. It is only a "very little" bit and perhaps in future I will try to install phosphor bronze washers to solve the problem, but in the moment it is no bigger problem for me.
And the other complaint...???
The clip! :mad:
I'm a fan of the Spyderco wire clips. I have 2 UKPKs and 3 Dragonflies in my collection, all equipped with the factory wire clip. The design of the clip allowing deep-carry mount is a huge advantage. But especially the extreme deep-carry design on the Chicago leaving only the "tip" of the butt outside is an improvement (comparable to the UKPK): When clipped to a dress pants pocket the Dragonfly tends to "turn" around its longitudinal axis, perhaps to a kind of "torque moment" created by the considerable more amount of handle being outside of the pocket. On the Chicago I didn't notice this effect.
But the clip itself...???
When having unboxed the Chicago I admired its solid feel and good handling, but then I got terrified... After a closer inspection of the clip I noticed that it, while having good tension, wiggled from left to right! I checked the clip screw but it was tight. Then I unscrewed the clip and tried to increase the tension. OK, it increased but the clip was still wiggling... It's too fragile!
Now what to do? :confused: Send back the knife to the supplier for payment refund and forget the Chicago? No!!
After a few minutes of intensive thinking I found the solution: :rolleyes:
The mounting part of the wire clip is the same on the UKPKs as well on the Dragonflies and the Chicago (I assume on many other models also...). So I took my Dragonfly ZDP (which is retired in the moment due to spinning pivot), unmounted the clip (Dragonfly clips are very stable) and screwed it on the Chicago...
Perfect!!! :cool: Good tension and absolute no side to side play! And additionally in my opinion it suits the Chicago's design and lines much better than the original clip.
Now I have to order 3 spare clips: 1 for the Dragonfly ZDP and 2 for my UKPKs...
In summary:
For me the Chicago is a kind of a "backup knife": Sufficient for almost all EDC tasks and always available for quick use when a larger blade is not at hand or not suitable due to "sensitive social environment"...
:spyder: I like it!! :)
Re: Spyderco Chicago G-10 - A short review
Post by Doc Dan »
I do not have the Chicago, but I do have an older Cat and you are right, the fit and finish are very good on these knives. Mine was perfectly centered, but you can easily fix the centering problem by loosening the pivot (slightly) and all handle screws, push the blade over to center, put a piece of paper between the blade and the liner to hold it in the centered position, then tighten the screws.
I really like the Cat that I bought years ago and it was better than another Taiwan Spyderco costing 2 1/2 times as much. I think I will carry mine to church in the morning.
Woodpuppy
Post by Woodpuppy »
Can you compare the Chicago to the Squeak?
Forest Elk
Woodpuppy wrote:
Sat Aug 18, 2018 12:15 pm
Maybe within the next week... :)
Woodpuppy
Post by Woodpuppy »
Forest Elk wrote:
Sat Aug 18, 2018 12:58 pm
:cool:
They look the same on paper...
apollo
Post by apollo »
Nice Review. The chicago never bin on my list but maybe i do need to look in to it.
Quick question i see there is a blade stamp of taiwan on the blade did spyderco switch makers on this one? I thought it was made in europe or am i mistaken? :)
Forest Elk
Woodpuppy wrote:
Sat Aug 18, 2018 1:37 pm
:cool:
They look similar, but there are considerable differences... I will compare them later as mentioned.
Forest Elk
apollo wrote:
Sat Aug 18, 2018 3:01 pm
The Chicago was always made in Taiwan. I don't know the manufacturer. The Squeak is made in Italy by Fox Knives in Maniago.
Calicoast
Post by Calicoast »
Nice review.
It looks like a nice knife, but its never been on my radar.
Nothing against Taiwan, but a knife named "Chicago" to me should have been made in the USA.
C
ikaretababy
Post by ikaretababy »
As a Chicago resident I feel like I should probably own this knife even if I don't need it. The reason I don't have one is because I already have the squeak. So I'd be interested in a direct comparison when you have the time. I do like fidgeting with a smooth opening knife even if I don't need it to lock open. How do owners feel about the fidget factor of the opening?
Post by Doc Dan »
The Squeak is a slip joint and the Chicago is a linerlock. The Squeak has linerless FRN scales and the Chicago has G10 scales with liners. The Squeak is closed back and the Chicago is flow through construction. The blade on the squeak is very round, while the Chicago tapers more to a point.
Forest Elk
As already promised I will do a brief comparison between Chicago and Squeak... :)
Upside the Squeak, downside the Chicago.
The overall shape is quite similar, although the Chicago is a little bit more "squared" and the Squeak a little bit more "rounded".
Up Chicago, down Squeak.
Please note that as already mentioned the clip on the Chicago is not the original one, but changed with the one of my Dragonfly ZDP. The original one has the same dimensions as the Squeak's one. BTW, as an intelligent detail, the Squeak's clip is so positioned that the touching points are lying exactly on the Spyderco logo (comparable to the Delica FRN and the Dragonfly FRN). This little detail greatly smoothens pulling the knife off the pocket and putting back into.
As already mentioned the Chicago's blade is more "pointy" while the Squeak's blade is more "rounded". The thickness is almost the same, abt. 3 mm. The Squeak's blade steel is Bohler-Uddeholm N690Co, an European steel which is widely used especially by European manufacturers. Though I rate it to have higher properties than CTS-BD1, the Chicago's blade steel is in no way a bad choice. As I mentioned in my review BD1 is used also by duty knives manufacturers.
The Squeak has jimping on both the thumb ramp and the choil, a detail that is useful for blade control of a non-locking knife. I personally don't miss them on the Chicago due to the fact that it locks.
The Chicago is a linerlock with open back, standoffs and G-10 scales, while the Squeak is a linerless slipjoint with closed back and FRN scales. The slipjoint construction makes the Squeak legal for public carry in Germany and UK (in Germany one-handed opening and self-locking knives are partially forbidden to carry in public; in UK all locking knives are forbidden. Remember the UKPK's history... ;)). I personally don't care about this...: I'm 60 years old and normally not in the situation of being controlled by LEOs, but in critical situations I would alway take the Squeak with me, especially due to the fact that I'm also a firearms owner and want not to lose my licenses... :eek:
In summary:
The Chicago is the more robust locking version of a small knife, while the Squeak is the little bit more "tiny" slipjoint version. Undoubtedly the Squeak is also a stout little knife... In short words: I would carry the Chicago from Monday to Saturday and the Squeak on Sunday to church and other celebrations.
I like them both! :cool:
