Page 1 of 1
Assembly/Disassembly-Pros/Cons
Posted: Tue Apr 08, 2003 12:00 am
by CKE
How many of you take into consideration the fact that you can "take-apart" your knife when you purchase. I know it voids the warranty but lets face it you don't have to be a genius to put them back together.(although there was the time i took apart another companies knife and the cheap torx screws stripped)Any Hoo. Do you take it into consideration?
It is nice to be able to to get them clean if the get really soiled. I would love to be able to take apart some of my knives(police, calypso, delica), instead of using compressed air and Q-tips to clean them.
"everything else is just a jeep"
Posted: Tue Apr 08, 2003 5:31 pm
by glockman99
I'd love to be able to take my stainless Police model(s) apart so that I could clean 'em and "customize" 'em easier, but with my luck, I'd end-up losing a part or stripping a screw anyway...
Dann Fassnacht Aberdeen, WA
glockman99@hotmail.com ICQ: 53675663
Posted: Tue Apr 08, 2003 5:32 pm
by vampyrewolf
It's one of many things I consider when I buy a knife. If I can't take it apart, I have to spray it out and get an oiled cloth inside every couple weeks.
if it can come apart without too much worry(unlike the new eccentric pivot ones), then it will come apart to get looked at and cleaned at least once.
My Word, My Honour, is my Life.
Posted: Tue Apr 08, 2003 6:17 pm
by Sword and Shield
I've cleaned knives just fine with air, hot water, and Q-tips that I simply wouldn't need a dismantleable (Dude, I made up a word! <img src="tongue.gif" width=15 height=15 align=middle border=0>) <img src="spyder.gif" width=15 height=15 align=middle border=0>. Slipjoints will cure the dismantle reflex pretty fast.
Never underestimate the impossible.
Posted: Wed Apr 09, 2003 12:42 am
by Ted
That's what I love about my Sebenza, so easy to take apart, clean, and put back together, without worrying of stripping screws or to much tension on the pivot.
I really really really hope the ATR can also be disassembled, without losing warrenty.
Posted: Wed Apr 09, 2003 5:46 am
by dialex
Yes, yes and... yes. A great option.
<a href="
http://users.pcnet.ro/dialex"><font color=blue>(my page)</font></a>
Posted: Wed Apr 09, 2003 2:56 pm
by fredswartz
I took the blade out of a rivited Spyderco once and successfully got reinstalled. Once is enought for me!
Posted: Wed Apr 09, 2003 7:55 pm
by Zrexxer
I disassembled a Salsa once and found that you need three hands to get it back together! <img src="smile.gif" width=15 height=15 align=middle border=0>
Posted: Wed Apr 09, 2003 7:59 pm
by vampyrewolf
easiest way to get a linerlock spydie back together(yes, I realize the salsa is a compression lock, but the theory is the same) is to oput the pivot together, and have the lock in "open". then assemble the back bit by bit...
haven't taken my salsa apart yet, but I might out of boredom to see if I can tweak the lock back towards left..
Posted: Sun Apr 13, 2003 3:37 am
by zardoz
I think for some it's a major consideration. It's a strong selling point on Sebenzas. It makes the knife more personal to me, if I can idly sit and strip it, clean it, polish out tiny pivot marks etc.
I've had a Large Dyad apart, that was fun! And the recent aquisition of a "R", despite it's relative rarity, just had to be stripped to polish out the overspill of the Almite that was showing on the inner edges. Personally, I tend to shy away from the Spydies that you can't dis-assemble.
Posted: Sun Apr 13, 2003 8:44 am
by Robby
In regard to the comment that it is difficult to disassemble - assemble an eccentric pivot knife -- there is nothing mysterious about the eccentric pivot. The pivot sleeve (into which the screw fits) is the eccentric part, and is designed (at least in my Lum Chinese) with tiny flats which contact the side scale or liner and prevent it from turning. To adjust this, it is just necessary to unscrew the pivot screw, tap out the sleeve to the point that it can be rotated slightly, and then push it back in place. I think it can be done without disassembling the knife, although the disassimbly of the Lum is no problem - just don't drop any of the tiny screws on the floor!
Posted: Sun Apr 13, 2003 12:58 pm
by jjcoolay
I messed up my chinook by taking it apart. The backlock spring had slipped out but I failed to notice. When I put it back together, it hung very loose when it was closed. I sent it in to spyderco with a note of my stupdity and they took pity on me and replaced it free of charge.
Not only did they repalce it, they gave me an old style chinook with cps30v instead of 440v.
