The owner of this Maxamet PM2 had given his knife a forced patina treatment, and besides coming out a bit uneven the acid had also completely eaten away the factory apex as well as the very tip of the blade.
To say that the knife was completely blunt would have been an understatement.
The request was to give the knife a new toothy edge with a lot of bite while making it as sharp as possible.
(You can click each pic 2 X for a bit more detail)
Before sharpening:
After sharpening
Flattened the acid damaged "apex" some more on a 3000 grit diamond plate so i could start with fresh steel, then made a new edge on a Rubber Wheel coated with +/- 230 grit diamond powder & wax, then deburred on a Paper Wheel with 1.0 micron diamond paste & oil.
The new edge is ever so slightly convex, the new apex fits almost exactly in the 30 degree inclusive slot of my Tormek WM200 Angle Master, plus it can whittle one of my chest hairs at about 5.5 centimeters from the point of holding. (i don't own a BESS tester)
The somewhat "fuzzy" shoulders of the new edge show how deep the acid has eaten away into the sides of the blade in some area's.
PM2 Maxamet & forced patina
- Johnnie1801
Re: PM2 Maxamet & forced patina
Nice sharpening job! Just don't understand why someone would acid wash a knife that comes stonewashed when new....
Jon
Jon
- Loudenboomer
I suppose patina is OK. What ever floats your boat. PM2 Maxamet production and delivery is much higher on the list for me! :)
- SpyderPhreak
Wow, acid!?!?!? :eek: Warm vinegar would have been more than sufficient...
"Engineers don't idle well."
Thank you to our Veterans!
