In my opinion, it performs nothing like bd1. I don’t even think it performs like a “harder” bd1. Maybe that’s a result of the nitrogen giving it a different carbide structure? Anyway, the only similarity I found in those two steels was the name.Vivi wrote:Sounds like an interesting steel. Maybe it would be a good choice for a mule?
I'm not sure how similar they will perform, but I've been very happy with CTSBD1. I'd like to see it used in more Spydercos.
S90V? Interesting.Surfingringo wrote:Phil Wilson made me a test knife in bd1n a couple of years ago. I tested I and passed it around to Ankerson and another forum member for further testing. On the positive side, it showed excellent edge retention, holding a working edge very similarly to s90v. It also responded to sharpening much like s90v which isn’t sally a plus in my book. Cossosion resistance was also very similar to steels like s90v and cpm154. That’s pretty good but nothing remotely like Lc200n, H1 or Vanax. One of the guys that did hard cutting tests also had some light edge chipping.
All in all, it’s a good steel and if you like steels like s90v then you will brobably like bd1n. I just didn’t find that it showed any real advantages over steels we already have. I would “use” it but I wouldn’t “choose” it. Of course, I could say the same thing about s90v and that steel seems to have done just fine without my love. :rolleyes: :D
Thank you for the info Shawn! Jim and I both tested the steel endurance cutting with a coarse edge and formed similar opinions. It is interesting hearing your observations on performance with a polished edge.Deadboxhero wrote:S90V? Interesting.Surfingringo wrote:Phil Wilson made me a test knife in bd1n a couple of years ago. I tested I and passed it around to Ankerson and another forum member for further testing. On the positive side, it showed excellent edge retention, holding a working edge very similarly to s90v. It also responded to sharpening much like s90v which isn’t sally a plus in my book. Cossosion resistance was also very similar to steels like s90v and cpm154. That’s pretty good but nothing remotely like Lc200n, H1 or Vanax. One of the guys that did hard cutting tests also had some light edge chipping.
I didn't have the same experience but I didn't use the Phil Wilsons knife. I've been using it on kitchen knives and have been very impressed. Takes the polished edge I want, s90v on folders didn't seem to keep up with the edge I like, that was more of a low grit working man's edge for cutting stuff that you throw away which is fine.
I attribute some of that to the lower HRC and it being packed with carbides
I find I like cutting quality, precision and finesse over raw endurance.
15dps, no microbevel , 2-3k finish with a 1 Micron diamond comp.
I find BD1N to hold that for me.
Just crispy
I got a piece of VANAX as a curiousity to play with but I'm worried it will be more of a working edge steel since the hardness doesn't go as high and might just be an lc200n that doesn't go blunt. Also I don't need insane corrison resistance if it costs edge performance.
But I gotta have it in my hands to form an opinion so I can't speculate too much from ignorance and it's still a very exciting and exotic material
Haha with so many variables I just have to look for what I like with how I Sharpen and use my knives, nothing is universal.
Thanks for sharing Lance,
Btw cool knife in the 2018 catelog
-Shawn.
I could be wrong but I think it’s been mentioned that bd1n is less expensive than some steels with comparable performance so I might have to retract my statement where I said it showed no advantages over steels we already had. A cheaper price point would definitely be an advantage. If this steel can be offered in some of the more economically priced folders, I think people will be very happy with it.goonielife wrote:See if this link works //forum.spyderco.com/viewto ... n#p1170847
Sal has said they were going to start doing the UKPK in BD1N.
Perfect. Thank you!bearfacedkiller wrote:It is a resistance to galling. Google that term if you are not familiar with it.
Basically when two metal surfaces rub against each other under pressure the friction can cause some plastic deformation and some transferring of material from one surface to the other.
It doesn't really apply to knives if I understand it right.
YES! Very cool, I'd love to have a piece to carry around with me at all timessal wrote:We'll probably slowly convert from BD1 to BD1N. I would not put it on a level of S90 though.
What brand of kitchen knives with BD1N did you use?Deadboxhero wrote: I've been using it on kitchen knives and have been very impressed. Takes the polished edge I want,
-Shawn.
Darby, that's a sweet looking steel.bearfacedkiller wrote:I am curious about steels that combine both carbon and nitrogen. What is the reasoning behind that and what are the advantages and disadvantages?
I was looking at various steels and came across Vancron 40 Superclean.
It has the following composition:
C 1.1
N 1.8
Si 0.5
Mn 0.4
Cr 4.5
Mo 3.2
W 3.7
V 8.5
What can we speculate about the properties of this steel? Could it be a viable blade steel? The data sheet states that it has high adhesive wear resistance which I do not think is needed in a blade but I assume is should also have abrasive wear resistance as well. I guess I am mostly wondering about the combination of carbon and nitrogen.
Yata Knivesbh49 wrote:What brand of kitchen knives with BD1N did you use?Deadboxhero wrote: I've been using it on kitchen knives and have been very impressed. Takes the polished edge I want,
-Shawn.
