Sal allows you to tweak ONE thing on any existing model...
twinboysdad
Which model do you change and what feature. For the enjoyment on the exercise, let's keep it at one. Go
Re: Sal allows you to tweak ONE thing on any existing model...
Compression lock LW Manix 2
M4 or maxamet sage 1. I can do the rest. :)
Milled out Slysz Bowie.
Urban in LC200N.
Or Chaparral in s110v.
Or CBBL Manix LW (s110v).
Maxamet blade Sprint Run on the Blue Stepped Titanium Chaparral.
Wire clip on Native 5 LW
Make the Delica tip pointier again out of the box
Offer Pac Salt in LC
Make a liner lock PM2 (mini Millie, I love the lock on it)
Return the Caly Jr and Jester from oblivion
Burgundy FRN Chaparral please
Move or eliminate the lanyard hole on the Para 3
4' Spydiechef.
Rock Lobster re-release?
Oh, yeah, tip-up Millie.
Deep carry wire clip for Para 3.
LC200N PE Dragonfly.
M390 Sage 5.
M390 Sage 5.
Liquid Cobra
Compression lock Bob Lum Tanto.
@liquid_cobra
@liquid_cobra
I'd give the Police 4 the Salt treatment, buy four (Two SE two PE) then stop buying knives. H1/FRN, liners if need be just make them corrosion proof.
The P4 is my favorite pattern but I won't buy one until it's offered in a highly corrosion resistant steel. DLC VG10 would work too if the liners, lock bar etc are coated too.
FRN Stretch 2 linerless? :)
Rounded/contoured scales on everything.
Scales on the Manix 2 LW done like the scales on a Delica - rounded edges and milled slots for jimping instead of the ridges.
Lil'Temp 3 LW.
Lil'Temp 3 LW.
Deep carry wire clip on the Manix 2 LW instead of the high-rise wire clip that ships currently.
-Ivan
Compression lock on military
Ryan
“Every created being is so constituted as to be capable of vice and virtue. For he can do nothing praiseworthy, if he had not the power of turning either way.” - Justin Martyr
I'll play.
Caged ball bearing lock on a GB 2.
More CBBL please!
Delica 4 Brown, Manix 2 G10 S110V, Gayle Bradley 2, Manix 2 CF Cruwear, KC Endura HAP40 pakkawood, Sliverax, Kapara, Manix 2 Rex45, Manix 2 4v, Ivory Straight Stretch
