Page 1 of 1
Dragonfly 2 blade swap
Posted: Fri Jun 30, 2017 9:51 am
by mad german
I've got a G-10 (VG-10) Dragonlfy 2 and a FRN (ZDP 189) Dragonfly 2. Can I swap the blades? Do I need to also swap the lock bars? Will these parts from the FRN be a direct fit into the G-10 model?
Thx
Re: Dragonfly 2 blade swap
Posted: Fri Jun 30, 2017 9:53 am
by Evil D
I would swap lock bars with blades. I'm pretty sure they swap with no problems.
Posted: Fri Jun 30, 2017 11:02 am
by dplafoll
I do wish they'd offer the G10 DF in a better steel. Maybe a permanent upgrade to HAP40?! :p
Posted: Fri Jun 30, 2017 11:05 am
by Evil D
dplafoll wrote:I do wish they'd offer the G10 DF in a better steel. Maybe a permanent upgrade to HAP40?! :p
Probably would only make an expensive knife more expensive. Might not be the best seller. I'm torn on the G10 anyway as I hate the added weight. I would rather see them do a linerless G10, sort of the best of both worlds.
Posted: Fri Jun 30, 2017 11:13 am
by dplafoll
Evil D wrote:dplafoll wrote:I do wish they'd offer the G10 DF in a better steel. Maybe a permanent upgrade to HAP40?! :p
I'd be willing to pay a little extra for the better steel TBH. But oh man if they did a linerless G10 DF2 in HAP40 or ZDP, that would be a must-have for me. I don't hate VG10, but it's always felt a bit underwhelming on the 40% more expensive G10 version.
Posted: Fri Jun 30, 2017 11:19 am
by Evil D
dplafoll wrote:Evil D wrote:dplafoll wrote:I do wish they'd offer the G10 DF in a better steel. Maybe a permanent upgrade to HAP40?! :p
Apparently that 40% is all for the G10 too. Sal commented a while back about (for whatever reason) G10 models are more expensive to produce out of Japan. I assume this is also why knives like the Kiwi 4 were so pricey.
I'm in the process of trying out my Dfly Salt as a keychain knife. It's a bit bulkier but I carry my keys clipped on my belt loop and tucked into my back pocket so it really hasn't been much of a problem, and when I go to use it I have a lot more knife to work with. I wouldn't want the G10 version for this, but I think it's a great knife for those who have blade length laws and such. I especially like the foliage green G10 and I REALLY wish they would offer it in more models. I would probably choose foliage green over black G10 nearly every time.
Posted: Fri Jun 30, 2017 3:54 pm
by dplafoll
Evil D wrote:dplafoll wrote:Evil D wrote:dplafoll wrote:I do wish they'd offer the G10 DF in a better steel. Maybe a permanent upgrade to HAP40?! :p
Yeah. I just think that's a model that's ripe for a very desirable sprint run, if not a production change. What would you think about a HAP40 sprint, maybe in the forest green G10 like the Caly 3? I only say that because I'd think they'd change the handle color for a sprint from the foliage, but I'd be fine either way. :p
Posted: Fri Jun 30, 2017 4:03 pm
by Evil D
I haven't tried HAP40 but I like what I've heard and I tend to love carbon steels so I'm sure I'll like it. I'm not really excited for clad blades but I guess I could live with it. I don't think foliage green was ever "assigned' to a sprint/steel, I'm really kind of surprised it has stuck around on this knife as long as it has. It's one of my favorite G10 colors and I would love to see it used more often especially on the Golden models.
Posted: Mon Sep 28, 2020 5:20 pm
by kennethsime
Well, my K390 Dragonfly came in, and while I managed to get the VG-10 blade & lockbar into the FRN handle, I couldn't quite manage to get the K390 blade & lockbar into the G-10. Going to give my thumbs a break and try again tomorrow!
To anyone who tried a similar swap successfully:
Did you swap the blade, lockbar, and spring? I feel like the VG-10 lockbar may not be engaging all the way.
Posted: Mon Sep 28, 2020 6:01 pm
by Cambertree
I have a friend who uses knives quite a bit for craftwork (traditional Maori weaving from NZ Flax) and general use.
She swears by the G10 Dragonfly. I recently acquired the KC HAP40 Pakkawood Dragonfly at her request, and I thought it was a really well rendered and beautiful knife.
I’ll be interested to hear what she thinks of the two knives in comparison, as she really uses her knives hard.
As for a sprint for the G10 model, how about K390 or SRS13?
You could probably put the G10 scales on the HAP40 Pakkawood DF and dye them darker green if you really wanted to.
Posted: Mon Sep 28, 2020 6:16 pm
by Cambertree
I don’t do bladeswaps, so I can’t help you there, sorry. I put custom scales on a FRN Dragonfly once, and that’s probably the last time I’ll be messing with modding a Dragonfly.
![wink ;)](./images/smilies/winking-face.png)
:D
Posted: Mon Sep 28, 2020 7:38 pm
by Evil D
kennethsime wrote: ↑Mon Sep 28, 2020 5:20 pm
If you swapped springs just make sure 1) it's in correctly, you can put them in from the wrong end and I'm sure that'll screw things up and 2) that it's pushed as far into the handle as it goes. Probably smart to compare all the parts and see if they're all the same sizes too.
Posted: Mon Sep 28, 2020 7:58 pm
by RadioactiveSpyder
There should be no problems swapping any Dfly blade into any frame including the G10 version. You ALWAYS swap the mated lockbars with any blade swap like this, but no other parts need to be traded. I have swapped many of them around in various frames with zero issue. Swapping into the G10 frame is rather challenging due to the stiffness of the lockbar spring, but the lockbar will go in properly with just the right amount of pressure and luck! It is more difficult to do these swaps with G10 Dragonflies versus G10 Delicas because there isn’t as much tension on the Delica lockbar spring as it’s spread over a larger distance. Good luck and cheers, Radioactive
![Image](https://i.imgur.com/NQzLoIV.jpg)
Posted: Mon Sep 28, 2020 9:17 pm
by kennethsime
Thanks guys! I will try again tomorrow. Thumbs are quite sore! :o
Posted: Tue Sep 29, 2020 11:06 pm
by chivaceae
I did this swap (ZDP189 on a G10 w/SSliners frame) last year, and it went very smooth, and I love it! I'll see about posting a pic later. Raul
