Page 1 of 2
Wise Man signet ring
Posted: Sun Mar 19, 2017 10:57 am
by holeshot
Has anyone bought a Delica or Endura with one of these rings or installed one? If so how do you like it? Thanks :)
Well mine came today and I installed it. So far I like the quality of the ring and it does make deployment of the knife easier. :)
Re: Wise Man signet ring
Posted: Sun Mar 19, 2017 11:50 am
by bolabeenz
Yeah, I have one on my Matriarch. The one with the Emerson opener. I still can't make up my mind if I like the Emerson mod. and was wondering if the "ring" would add anything to deploying the blade. It does feel safer grabbing the ring and pulling it out; but I end up with the knife open holding it between my thumb and index finger by the ring.
When gripping the knife though, the ring gives a very secure grip if you are holding it by the handles end.
Also, the ring would give you the ability to use the butt as a bludgeon.
Posted: Sun Mar 19, 2017 12:11 pm
by Halfneck
Kinda looked at the idea that it would make a LilMatriarch a poor man's Karambit.
Posted: Sun Mar 19, 2017 2:13 pm
by Evil D
I'd like it more if it were rotated inward so your pinky is in the ring where it would be in a normal grip, but then you'd need a shorter blade or the ring would need to be hollow so the blade can pass through it.
Posted: Sun Mar 19, 2017 3:23 pm
by funghiman
Evil D wrote:I'd like it more if it were rotated inward so your pinky is in the ring where it would be in a normal grip, but then you'd need a shorter blade or the ring would need to be hollow so the blade can pass through it.
Like this?
Posted: Sun Mar 19, 2017 4:01 pm
by Evil D
Like this?
Basically, maybe a bit further around. I'm sure it varies per hand size.
Posted: Mon Mar 20, 2017 7:22 am
by Michael Janich
One of the things that people sometimes forget about karambits with rings (not all traditional karambits had them) is that the ring typically must be used as part of the grip. In simple terms, it's one-fourth of the total handle length. For folding karambits, that means the blade must be significantly shorter than the handle so the blade doesn't pass through the ring when opening the knife.
When you add a ring to the handle of a knife that already offers a four-finger grip and a full length blade, you move your hand placement one finger farther away from the blade. Unless you have huge hands that naturally compensate for that shift, it puts your hand too far away from the blade and compromises the natural fit of the handle in the hand.
Placing the ring closer to the slot side of the handle mitigates this, but also starts to put it in the path of the blade's opening arc. To make that work, you'd need to shorten the blade.
Stay safe,
Mike
Posted: Mon Mar 20, 2017 8:16 am
by carl3989
Can that be done without incurring violations of the Syderco warranty? Is it even allowed?
Posted: Mon Mar 20, 2017 9:10 am
by araneae
carl3989 wrote:Can that be done without incurring violations of the Syderco warranty? Is it even allowed?
Well I'd guess you have to disassemble so that voids the warranty.
Posted: Mon Mar 20, 2017 1:45 pm
by kbuzbee
Michael Janich wrote: To make that work, you'd need to shorten the blade.
Or offset the ring? Say to the palm side of the scale? Just a thought.
(Generic thought, not for this specific ring)
Ken
Posted: Mon Mar 20, 2017 5:36 pm
by ZrowsN1s
You might be better off with a short lanyard.
Posted: Mon Dec 18, 2017 9:19 pm
by zeus
:spyder: The Wisemen Company doesn't make a Signet ring for the Manix yet, so I cobbled one up for my Manix 2 XL. Wanted to go with brass, but thought I'd experiment with aluminum first. (I screwed up one radius on the left side)
This model is my EDC but I haven't done any mods since 2013.
In the last picture from 2013, I had reground the blade spine, installed a Silicone Nitride ball, tapered and polished the tip of the spring perch on the polymer cage, and used three lighter compression springs wound together as one, to replace the heavy stock spring.
Cheers,
Zeus
Posted: Mon Dec 18, 2017 9:38 pm
by clovisc
Would love to see a lightweight and affordable Spyderco FRN Karambit built on the Endura platform using this concept.
Posted: Mon Dec 18, 2017 11:41 pm
by spambait11
Michael Janich wrote:One of the things that people sometimes forget about karambits with rings (not all traditional karambits had them) is that the ring typically must be used as part of the grip. In simple terms, it's one-fourth of the total handle length. For folding karambits, that means the blade must be significantly shorter than the handle so the blade doesn't pass through the ring when opening the knife.
Stay safe,
Mike
Having the Karahawk, I COMPLETLEY understand what Mr. Janich is saying. The Karahawk is the perfect length, and fits the hand well when deployed. Those wise men rings are so far off the handle that when you deploy the knife in reverse grip, pulling the knife out of your pocket with your index finger in the ring, the rest of your fingers are so far off the handle when you grip the handle that you’d be holding the knife awkwardly.
That being said, the Karahawk needs to lose weight, so I like the FRN suggestion. Coming in at less than 3 oz. (with an FRN ring?) would be ideal! Having a Salt or LC200N blade would make it even better! But I know this knife is too specialized for those kinds of upgrades.
Posted: Tue Dec 19, 2017 12:47 am
by Bill1170
As Mr Janich said, the ring needs to be part of the grip and also out of the blade opening arc. My first thought seeing the OP waved knife was, “Will the tip slice the digit in the ring when the blade is waved open?”
Posted: Tue Dec 19, 2017 1:52 am
by The Deacon
Evil D wrote:
Like this?
Wouldn't that put whatever finger was in the hole in harm's way when drawing a waved knife from your pocket? Or prevent the knife from being able to open and close? At least unless you chopped an inch off the blade.
I can't speak for Spyderco, but if the ring replaces the backspacer and you sent the knife in with the ring in place, I'm fairly certain they'd consider it an alteration, and those have always voided the warranty.
Posted: Tue Dec 19, 2017 4:04 am
by Surfingringo
Cheers,
Zeus
I’ve got no use for karambits but I sure do like what you did with that blade! :)
Posted: Tue Dec 19, 2017 8:02 am
by ThePeacent
zeus wrote::spyder: The Wisemen Company doesn't make a Signet ring for the Manix yet, so I cobbled one up for my Manix 2 XL. Wanted to go with brass, but thought I'd experiment with aluminum first. (I screwed up one radius on the left side)
Cheers,
Zeus
those mods are awesome! I like the Wisemen ring a lot, and would've liked to see it available for more models.
I find it visually and mechanically appealing even though I don't have any traning in knife arts and wouldn't know how to use one adequately,
but on my non :spyder: hawkbill folder with it I can have a much better purchase, put my pinky through it and wave the knife open in a quick, smooth motion thanks to the ring
and I tried the bottom spike on some glass this Sunday, it popped like it wasn't there.
I'd sure like to try it on some of my Spydies :spyder:
Posted: Tue Dec 19, 2017 8:47 am
by curlyhairedboy
If I get a matriarch, I'll probably grab one of these too, just for ease of pocket retrieval.
Posted: Thu Oct 24, 2019 8:11 am
by S2Klay
Sorry to revive this thread but does anyone know where these can still be found? I’ve contacted Wise Men Company but I have received a response yet. It seems they’re sold out everywhere.
