Anyone ever tried Blueing Wire Pocket Cips?
- toxophilus
I like the way the dark wire clip disappears when wearing darker pants or jeans when I carry my Chaparral; wondering if anyone here has had success in doing this mod?
Thx in advance, RSilva
Re: Anyone ever tried Blueing Wire Pocket Cips?
No but I wonder how it would hold up to wear...if you're talking about gun-blue stuff? That stuff scratches pretty easily.
Or are you talking about something else?
- toxophilus
Was pondering cold Blueing :)
I've done it. Looks good but wears away. Not so that it gets on your hands or marks up clothing but after a couple weeks it will look new again. I've found using gun blue in combination with ferric chloride gives a nice look and doesn't wear away. I don't have any pics handy but I'll try to remember to post something.
- toxophilus
Thx Spyderg;look forward to pics when you have time.
No but I dang sure have bought black ones for a Sage and put them on Pingos and Caly 3.5s! They look amazing and are a bit grippier than the uncoated ones
Have heat-darkened the wire clip on my Urban which makes it stand out much less, an Urban should be hardly seen on jeans.
I was thinking of putting some of that rubber dip on one, that stuff you put on tool handles and etc. It would make it grip clothes more but would be easier to grip in the hand.
Acid etch ferric in chloride gives a gray look as in blasted titanium (Slysz Bowie or Techno).
SCARAMOUCHE!
Intersting if it's not wearing away with that method.spyderg wrote:I've done it. Looks good but wears away. Not so that it gets on your hands or marks up clothing but after a couple weeks it will look new again. I've found using gun blue in combination with ferric chloride gives a nice look and doesn't wear away. I don't have any pics handy but I'll try to remember to post something.
Yes please, some pics !
Last idea from Gull Wing sound nice/interesting too :)
:spyder: adds color to your knife addiction :D
If I understand correctly, gun bluing is a form of corrosive conversion that leaves behind a less reactive oxide barrier on the surface of the steel, my bet is that bluing simply doesn't convert much of the stainless clip wire to the black oxide (or phosphate or whatever the particular process creates), so it wears off quicker than it would from non-stainless steel.
-David
Well with poor lighting in the kitchen this eve, this is the best I can do right now. The clip started out as a super shiny Dragonfly clip, in sunlight it has a slight blue tint to it. It is not very noticeable against jeans light or dark. Since I did it, right after I got it, (first batch that made it to Canada) it has lightened up a little.
- toxophilus
Very nice, I will experiment with that!
SCARAMOUCHE!
This is not my idea, but I can't remember where I saw it. I just took about 10 minutes to go out into the shop and put some shrink tubing on my Caly. The kind of tubing that you use in electrical work. I think the example that I saw had one larger piece of tubing over the entire clip.
remnar wrote:This is not my idea, but I can't remember where I saw it. I just took about 10 minutes to go out into the shop and put some shrink tubing on my Caly. The kind of tubing that you use in electrical work. I think the example that I saw had one larger piece of tubing over the entire clip.
That might have been one of mine. I've posted a couple like that if I recall, blue heat shrink on my lava and techno, and maybe another in black. It looks good and works well but rather than slowly fading, it works till one day it rips and looks like **** and you have to redo it, about a month of pretty regular carry for me.
I would LOVE for someone to make a blue anodized titanium wire clip for my Sage. Would be awesome.
I turned it to red with a good lighter :D
And cooled it in some oil.
Look good to me and following how you do it you will have different "colors". :)
After long use, no problem with it at all.
This won't wear off I think :D
- dj moonbat
I did the heat-shrink job on my Chaparral wire clip, and it's just like you say: it's grippy and looks great until the tubing fails. On the plus side, it keeps the wire from marking up the carbon fiber scale.spyderg wrote:remnar wrote:This is not my idea, but I can't remember where I saw it. I just took about 10 minutes to go out into the shop and put some shrink tubing on my Caly. The kind of tubing that you use in electrical work. I think the example that I saw had one larger piece of tubing over the entire clip.
- KnickKnackCity
Does anyone think a full DLC coating on the clip would hinder how it seats in the slots on the scale?
