Pacific Salt praise
Pacific Salt praise
Normally I carry a Para 2 or Military with me. Love their high quality feel, the ergos, full flat grinds, the blade shapes etc.
I've owned a few Salt folders since they came out. SE Tasman Salt which is my dirty job knife, the knife that cuts things I don't want to use a "nice" knife for. PE & SE Pacific Salts, which were also beater knives mostly used for manual labor jobs like roofing, landscaping etc.
Lately the Pacific Salt has made its way into a general EDC role. It's stopped being my ugly beater knife and has become my go to daily carry.
Kind of wondering why it took me over half a decade to make that call.
I love big blades but I like light folders. The Millie has been my gold standard for years, being 4.5oz with a 4 inch blade. The Pacific Salt is an anorexic 3oz! with a 3.812 inch blade, even more impressive than the Military.
The ergos are great, feels like my Police 3 with no choil and a chunkier handle. Love how rounded the corners are compared to more squared off G10 / Ti. The Endura 4 handle never worked for me, never understood if the first finger contour was meant for one finger or two, with neither really feeling right. This handle, my hand knows exactly where to go and is locked into place every time.
Great action on it. Large 14mm opening hole that's totally exposed when the knife is closed, very easy to open. Worn in backlocks are smooth, smooth smooth. Depress the lock release with my thumb and swing the blade shut with my index finger in the hole, closing one handed just as easily as it opens.
Most importantly, the blade. H1 rustproof goodness. Took some modding to get what I wanted out of it, I'll admit. Removed the hump near the tip for better penetration, since I prefer pointy tips like the Military. The saber hollow grind was much too thick for me, so I flattened out the hollow which gave the blade profile reduced drag in cardboard etc. Next I reduced the edge angle significantly. Lucky for me H1 grinds very easily, and this took very little time to do by hand. I did a very rough job that could definitely be more even, but this is my beater so it doesn't matter to me. It cuts.
I honestly wasn't impressed at all with edge retention and sharpness on this PE Pacific Salt, so much so that it was my main reason for never EDCing it. Over time I've realized I get a much sharper edge on it when its thinned out (Me or the steel? I have no idea), and that edge retention has improved as well. I don't know if the edge retention is because of the supposed work hardening nature of H1 or because of my changes to the edge geometry, but I find it acceptable now. I'm getting it hair popping sharp where before smooth shaving sharpness was next to impossible for me. Edge retention feels just a bit under my VG10 folders, which is better than it was initially.
It's weird, with VG10 and S30V I get them plenty sharp at factory edge angles and see good edge retention, I just don't like how much force it takes to cut thicker materials. With H1 it wasn't just about cutting efficiency, I needed to thin out the edge and grind it down before I could get the knife as sharp as I wanted. I've noticed this with all of my PE H1 knives so far. Spending a few minutes on some DMT bench stones and completely removing the factory edge just seems to make such a big difference with H1.
For a while I was running coarse edges on my H1 knives to help combat the low edge retention. My initial impressions were polished edges lost their bite on H1 very quick, and I was left with a glossy edge with no bite. The coarses edges would hold working sharpness for much longer, because even after the bite of a fresh sharpening wears off, the edge still has some aggression left in it instead of being smooth and rounded.
The past few weeks I've been experimenting with more polished edges again, using the Pacific Salt and aqua Salt as my testers. Pacific Salt I've been using a DMT fine stone to finish the edge with (1000-1200 grit I believe), then stropping twice per side. The Aqua Salt I've been taking up to Spyderco UF bench stone (8000 grit?) then stropping 5 times per side. I've been pretty happy with their performance so far. Honestly couldn't tell you if I just sucked at sharpening them in the past or if the years of use and re-sharpening has made a difference, but either way the more polished edges are working better now.
The Aqua Salt has been getting tested in controlled cardboard and rope cutting sessions, going back and forth between the polished edge and an edge finished with a DMT XX coarse stone. The latter definitely retains slicing aggression during a cardboard or rope cutting trial for longer periods of time, but the polished edge holds up better than my old impressions led me to expect. For general use I'd choose something in between the two extremes (250 grit vs 8000), but if I knew I had an unusual cutting task coming up, I could go in either direction to optimize it as needed.
The Pacific Salt has just been seeing EDC usage. Edge retention has been no issue at all. The most cardboard I cut in a usual day is about 10-15', so EDC knives don't get tested hard there. I'm the kind of guy that's going to touch up my EDC when it can't shave, so sharpening frequently is no issue for me, it just needs to get through a day or two without getting so dull it won't scrape off arm hair. The Pac Salt is doing that. The level of polish (DMt fine) is working well for me in an EDC role, and I don't see myself changing it any time soon. Most of my other EDC knives are S30V, and that I'll take up to the spyderco UF stones every time, but I like a lower grit finish on H1.
The rust proof nature of this knife is a really big deal to me. I'll manage to rust DLC coated stainless Spydercos even. Imagine how much you'd sweat biking 100 miles in 95-105 degree weather. Now imagine having a Spyderco clipped to your waist band while you do that, and think about what all that sweat exposure is going to do to the liners, the blade, the stop pin, the pivot bearing etc. This is one example of the ridiculous situations my folders can go through. Having a knife that is 100% impervious to things like that is a really, really big deal to me. My Para 2 needs a deep cleaning in the pivot after something like that, even with that DLC coating.
It's also just nice for peace of mind. Say I'm at work, hands are covered in oils, and I need to cut something. If my Para 2 is clipped to my pants, I'd wipe my hands off, maybe wash them first. Can't always do that. Pacific Salt, idgaf, I just grab it and get the job done. I know I can just dunk it in a tub of hot soapy water, swish it around a bit, then blast it out with some water and its good to go. No worries about a little water being in between the G10 and liner, potentially rusting. No worries at all.
I've been spoiled by higher end knives. I've gotten to slice cardboard with a CF/S90V Military. I've seen what an 8DPS ZDP189 Stretch cuts like. I EDC'd a thinned & convexed CPMD2 Millie for years. But this ugly, inexpensive Spyderco has become my favorite knife recently. Now that I've got the quirks worked out of the edge, I've gotten to enjoy its qualities. 3oz, nearly the same blade length as my Millie, and rust proof? That's a hard combo to beat, even for Spyderco :)
Planning to order one of the newer versions with the hourglass clip and finer jimping. If anyone knows who I could send it to for a full flat grind, I'd love to know!
2019 update - Here is that same Pacific Salt after cleaning up the blade grind:
Surfingringo
Re: Pacific Salt praise
Post by Surfingringo »
Great writeup that reflects most of my thoughts on this awesome model. I too prefer this handle to that of the Endura 4. Hope they don't "upgrade" anytime soon! I have never been completely satisfied with the edge retention of the plain edge model but the serrated Pacific Salt is a beast and is probably my favorite Spydie of them all.
Cliff Stamp
Post by Cliff Stamp »
Vivi wrote: The Aqua Salt has been getting tested in controlled cardboard and rope cutting sessions, going back and forth between the polished edge and an edge finished with a DMT XX coarse stone. The latter definitely retains slicing aggression during a cardboard or rope cutting trial for longer periods of time, but the polished edge holds up better than my old impressions led me to expect.
Have you found that the edge retention with a polished edge increased more than the xx-coarse edge? Or to ask the same question another way, is the edge retention with the xx-coarse edge similar to your old impressions, but only the polished one appears to have increased? Or have both of them improved?
Both have improved, but the difference is more noticeable with the polished edge.
Cliff Stamp
Vivi wrote:Both have improved, but the difference is more noticeable with the polished edge.
That is interesting, any details on the type of cardboard and rope and how you are cutting?
elena86
Post by elena86 »
Welcome to our club.PE Pac Salt is an excellent allaround work folder. SE Pac Salt is a terrific allaround work folder.This very morning I went to the post office to pick up a SE Pac Salt moded with a pointy tip for me by Lance aka Surfingringo.Great job made by a cool guy :cool:
Regular thickness cardboard, slicing cuts trying to dull the full length of the blade. Against and with the grain, no cutting board.
Rope was 1/8 inch hemp rope, slicing cuts on a cutting board.
Tested sharpness by seeing how well they push cut and sliced phone book paper and regular paper before and after.
Holland
Post by Holland »
Awesome write up! Isn't a few knives to big chris over on BF. He did an amazing job regrinding them and I would definitely recommend him.
Archimedes
Post by Archimedes »
I have been carrying a SE Pacific for a few weeks now and I really like it. H1 has become a fun steel for me.
Mine had a terrible wire burr on the edge when I received it. I was pretty unimpressed the first couple of days cutting things thinking wow this knife really needs a little extra work to get started. Then I finally looked at the edge and wow, wire Burr. Cleaned it up and now I am getting much better performance.
Cliff Stamp
That is interesting. I would expect that a significant increase in cutting ability would indirectly produce an increase in edge retention, and lowering the apex angle will do it directly. However it isn't obvious why it would favor a larger increase in a higher polish.
dubya3
Post by dubya3 »
I came very close to ordering a Pac Salt but the Endura 4 handle is that much better for me and I went with that in SE. I'm in Minnesota and while I do work outside (concrete construction) hot, muggy weather, I've never had issues with rust. Im pretty diligent with cleaning and oiling my blades but there's something to be said about having a knife you can grab in any situation, oilily or muddy hands or whatever the situation is and not caring at all. When I carry a nicer, more expensive knife, I'm in a different mindset much like you and will wipe my hands before use.. now I want a Pac Salt again... thanks!
Cory
Upgrading to a Ti ATR once I sell my stainless ATR :)
z4vdBt
Post by z4vdBt »
I started carrying my PS, which replaced my E4 FFG. The PS is slimmer, and the volcano grip does not have the large logo in the center that is smooth and texture less.
araneae
Post by araneae »
z4vdBt wrote:I started carrying my PS, which replaced my E4 FFG. The PS is slimmer, and the volcano grip does not have the large logo in the center that is smooth and texture less.
The logo is also a "landing pad" for the clip so it doesn't shred your pocket.
-Nick
Last in: N5 Magnacut
SpyderEdgeForever
Post by SpyderEdgeForever »
I like my Pacific Salt, Serrated edge greatly.
Great knife. I did some salt water tests (you can see them in the forum archives) and even immersed in concentrated salt water for weeks, the knife was easily cleaned and had no rusting to the H1 steel blade.
Belasarius Jnr
Post by Belasarius Jnr »
Thanks putting up the detailed review, I'm really liking the knife after a couple of months use. I now keep my SE Atlantic Salt in my bag for big rope work and pocket this black on black PE for.
elena86
Post by elena86 »
Belasarius Jnr wrote:Thanks putting up the detailed review, I'm really liking the knife after a couple of months use. I now keep my SE Atlantic Salt in my bag for big rope work and pocket this black on black PE for.
Just curious, how does the black TiN coating wear ?
Belasarius Jnr
Pretty tough, no loss so far.
HarleyXJGuy
Post by HarleyXJGuy »
Sigh.
Echo63
Post by Echo63 »
I have always liked the Pacific Salt - although i didn't like the average edge retention when i got mine.
after years of use it got much better.
Today i attacked mine with an Edgepro Apex - 15dps from 120grit (to reprofile) to 3000 grit tapes (for a mirror polish)
its certainly sharp now just gotta see how it behaves with the smooth edge.
heres an older pic of mine, with polished and flame coloured clip - i also rounded and polished the spine and added GITD paint to the roundel
Touching the edge up again is a piece of cake now too - a dozen or so passes on the UF sharpmaker rods, till the microbevel gets too big - then back to the apex
Belasarius Jnr
More love for the Pac Salt today.
