52100 steel
elena86
52100 steel
Postby elena86 » Fri Jul 10, 2015 6:34 pm
I am on both sides of the spectrum; as much as I like H1 steel as a great allarounder I love carbon steels as well for their inherent qualities.I own and use a few fixed blades in 1095 and 1075 carbon steels.They are good performers and very versatile in the field.A friend of mine owns a custom fixed blade in 52100 steel and he swears by it.I'd very much like to see a Spyderco folder released in that steel.Who else ....?
Fancier
Re: 52100 steel
Postby Fancier » Fri Jul 10, 2015 6:36 pm
Didn't super blue cover the need for a rust prone alloy?
MacLaren
Re: 52100 steel
Postby MacLaren » Fri Jul 10, 2015 6:39 pm
Ive heard that 52100 is really nice.....
Not that that means much lol....
tvenuto
Re: 52100 steel
Postby tvenuto » Fri Jul 10, 2015 6:48 pm
Fancier wrote:Didn't super blue cover the need for a rust prone alloy?
Ha I know this was somewhat of a flip response, but I can't say I totally disagree. I'm of the mind that loss of corrosion resistance is far more noticeable than some of the other properties supposedly gained in the trade.
The truth of the matter is, most of the other factors that go into a knife are more important than the steel (assuming proper and reasonable heat treat). Your friend's fixed blade is probably properly ground for the scope of work, comfortable in hand, well balanced, etc, and these most likely contribute far more to his enjoyment of the knife than the particular steel used.
bdblue
Re: 52100 steel
Postby bdblue » Fri Jul 10, 2015 6:51 pm
52100 is good stuff but so are lots of other carbon steels. If you want a primo carbon steel, there have been plenty of Spyderco's made with M4 steel. In the recent past they have made several models with Cruwear steel and even one model with 3V.
Cliff Stamp
Re: 52100 steel
Postby Cliff Stamp » Fri Jul 10, 2015 7:02 pm
bdblue wrote:5 If you want a primo carbon steel, there have been plenty of Spyderco's made with M4 steel. In the recent past they have made several models with Cruwear steel and even one model with 3V.
M4 is a HSS, it has little in common with 52100, CruWear and 3V are also very different. It would be like saying there is no need for a Spyderco Military because there already is the Spyderco Endura.
52100 has near optimal :
-apex stability
-ease of sharpening
-maximum hardness
It is the non-stainless equivalent of AEB-L.
elena86
Re: 52100 steel
Postby elena86 » Fri Jul 10, 2015 7:15 pm
-apex stability
-ease of sharpening
-maximum hardness
^^^ That.
Able Dog
Re: 52100 steel
Postby Able Dog » Fri Jul 10, 2015 7:40 pm
It does, but given SuperBlue is a Japanese made steel, it is only available on Japanese made Spydercos (and sprint runs none-the-less). Using a carbon steel from a different country/foundry, Spyderco would not be as limited in the variety of knives they could potentially use this steel on.
Cliff, would those properties make 52100 a good steel choice for a very thinly ground knife such as the Nilakka?
W.O.T.W. - Way of the Wharncliffe
Able Dog
Re: 52100 steel
Postby Able Dog » Fri Jul 10, 2015 7:41 pm
Double post.
Liquid Cobra
Re: 52100 steel
Postby Liquid Cobra » Fri Jul 10, 2015 8:10 pm
Sal had teased a UKPK sprint using 52100. Not sure if he was serious or not, but I'd buy a few.
Most recently acquired: Paramilitary 2 Tanto, YoJUMBO, Swayback, Siren, DLC Yojimbo 2, Native Chief, Shaman S90V, Para 3 LW, Ikuchi, UKPK, Smock, SUBVERT, Amalgam, Para 3 CTS-XHP, Kapara, Paramilitary 2 M390
@liquid_cobra
Re: 52100 steel
Postby sal » Fri Jul 10, 2015 8:44 pm
52100 is a ball bearing steel. Most ball bearing steels make pretty decent blade steel. Especially where edges are concerned. It is my favorite steel to forge. It is hard to find in sheet. Actually, I would like to do a run of a model in 52100, but I'd prefer to make it in Golden, so it will be a year or so.
v8r
Re: 52100 steel
Postby v8r » Fri Jul 10, 2015 8:54 pm
I can't really explain why, but I would rather have a carbon steel blade than stainless. They especially look good when they take on a natural patina.
The Mastiff
Re: 52100 steel
Postby The Mastiff » Fri Jul 10, 2015 9:05 pm
52100 has been one of my favorites for over a decade now. I've never seen a folder made with it in a production facility. It would be super rare, very good to sharpen and slice with and should sell well because of these factors. There are a lot of 52100 fans out there. I'd sure want to grab a few.
Joe
HarleyXJGuy
Re: 52100 steel
Postby HarleyXJGuy » Fri Jul 10, 2015 9:39 pm
-apex stability
-ease of sharpening
-maximum hardness
Hmm might be nice to make some Spydies out of AEB-L then, just saying.
tvenuto
Re: 52100 steel
Postby tvenuto » Fri Jul 10, 2015 9:54 pm
I'd darn sure buy an AEB-L spydie.
If "ease of sharpen" was high on our list, we've certainly gone in a strange direction. Don't see much clamoring for an 8Cr13Mov sprint, for example. Interesting how when a steel is liked it gets "easy to sharpen" or "takes a keen edge". When disliked it gets "low wear resistance". All a matter of perspective I guess.
Cliff Stamp
Re: 52100 steel
Postby Cliff Stamp » Fri Jul 10, 2015 10:01 pm
Able Dog wrote: Cliff, would those properties make 52100 a good steel choice for a very thinly ground knife such as the Nilakka?
Exactly right.
Able Dog
Re: 52100 steel
Postby Able Dog » Fri Jul 10, 2015 10:06 pm
Exactly right.
Thanks. Now I have a dream Sprint Run.
I'm very excited to hear more about what Spyderco ends up producing in 52100.
Cliff Stamp
Re: 52100 steel
Postby Cliff Stamp » Fri Jul 10, 2015 10:21 pm
52100 is likely not trivial to get in knife stock, 50100-B or similar steels likely would be far easier.
ohcyclist
Re: 52100 steel
Postby ohcyclist » Fri Jul 10, 2015 10:21 pm
I have some experience with the this steel in chef knives. It has served me very well in that role and I would always be open to trying it in another application.
SpyderNut
Re: 52100 steel
Postby SpyderNut » Fri Jul 10, 2015 10:27 pm
A folder in this steel would be a nice offering. I'd definitely be interested.
:spyder: -Michael
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot], Mushroom and 50 guests
